Question about Amcor MD250 Dehumidifier
Dehumidifier 'cuts out' after about an hour - no water has been extracted.
  • Amcor Master
  • 43,501 Answers
There are many reasons for a dehumidifierDehumidifier 'cuts out' after about an hour - - 2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on Jul 13, 2010
5 Suggested Answers
  • 225 Answers
SOURCE: The dehumidifier runs a long time & does not remove much water.
If you haven't done so already, try removing and cleaning the inlet filter screen which is almost certainly just behing the inlet grille. If this is blocked with fluff then no moist air will get to the cold pipes, so little or no water will be extracted.
Hope this helps. If this "fixes ya", I'd appreciate a rating for my reply, If not, please delay the rating and add a comment with any extra info you have and I will try to think of something else.
Posted on Jul 13, 2008
  • 4 Answers
SOURCE: Delonghi DE220 dehumidifier stopped extracting water from the air
You probably have a dirty heat exchanger. Write to me at j_sjohn@hotmail.com for free maintenance instructions on a smilar unit. Cheers.
Posted on Jan 05, 2009
Dittoz
  • 3 Answers
SOURCE: Dehumidifier headaches!
There are three things that must be working to extract water. The 'coil' (a finned metal part that allows air passage) if it's filled with dust and obstructions, no air can move...no water. There is a blower motor that mus move the air. If it is seized up an not blowing air...very little or no water. The compressor uses condensation from the air moving across its coils (like the moisture than forms on a cold glass on a humid day) to extract the water from the air. If it's not working then no water.
So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not working. If it's real hot air, and the humidifier keeps cycling on and off quickly, the coil is dirty. Those are the 3 things that need to be working.
Posted on Jul 31, 2009
  • 4736 Answers
SOURCE: dehumidifier keeps running but extracts
There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this help you troubleshoot and solve the problem. Thanks for choosing FixYa.
Posted on Aug 03, 2011
RUNS BUT NO WATER
How humid are the conditions? if dry, will not extract water, can only extract water from humid conditions
Aug 05, 2014 | Haier HD306 Dehumidifier
LD451EGL no water extraction
Apparently, the fans are running, but the compressor has shut down. It could be a failed compressor, or the charge in the system could have leaked out causing the compressor to shut down.
Aug 01, 2014 | LG Electronics Ld451egl 45-Pint...
I have a goldstar DH40 , just bought it at a yard sale -
Give it a good cleaning before you do anything else. If the fins or filter are dirty, you won't get good service from it. Make sure the drain path is open.
Feb 05, 2013 | Goldstar Dehumidifiers
The dehumidifier motor is on but only extracts tablespoonfuls of moisture from the air every 48 hours. In other words it isn't functioning as it should. Model #DH40; traceability code GR and barcode...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Sep 10, 2011 | Goldstar DH304 Dehumidifier
I have had the machine on for 5 days on high and have extracted less then a 1/4 inch of water. The back side of the machine is hot and blowing hot air - the motor runs but does not extract water Is it...
heatman101
Jul 31, 2011 | Whirlpool Dehumidifiers
My Amcor AHD 45E dehumidifier sounds like it's running, but it doesn't extract any water
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Oct 13, 2010 | Amcor AHD45 Dehumidifier
The dehumidifier runs but does not extract any water, and there is a slight burning smell
heatman101 ]
Aug 17, 2010 | Maytag M7DH45B2A Dehumidifier
My dehumidifier runs but does not extract water from the air.
heatman101
Jun 27, 2010 | Goldstar DH504EL Dehumidifier
Dehumidifier does not extract water. Fan works and I've cleaned and checked all connections. How do I tell if tis a bad compressor or coil?
It could be a abad compressor, circuit board, or maybe even a sensor or dehumidistat...
Here is a tip about dehumidifiers that run but do not extract water from the air..
heatman101
May 03, 2010 | Whirlpool AD25BBR Dehumidifier
Jul 27, 2009 | Kenmore 54501 Dehumidifier
Amcor MD250 Dehumidifier Logo
226 people viewed this question
Top Amcor Dehumidifiers Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you an Amcor Dehumidifier Expert? Answer questions, earn points and help others
