Question about Dishwashers
DISHWASHER WONT POWER UP
ELECTRICTY GOES TO DISHWASHER BUT WONT POWER UP WHEN TURNED ON
  • 6,784 Answers
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Posted on Jul 13, 2009
Husqvarna 323hd60 wont start when hot
check/change oil, try not to over load which casus engin to over heat.
at high tempurature Magnets losess their Magnetic power which results in less electricty power to the spark plug
Apr 03, 2014 | Garden
Why it want make electricty are load up?
Must be up to full running RPM to generate the right operating voltage. If it is running at full throttle and there is no power out, then the generator head needs to be repaired.
Feb 06, 2014 | Coleman Electrical Supplies
My dishwasher won't turn on
Sorry to hear about your dishwasher problem. If the dishwasher will not turn on and you do not have any lights blinking or coming on the first thing to check is the circuit breaker in your home. Turn it off and back then retry the dishwasher. If that does not help make sure there is not a wall switch that controls the dishwasher that has been turned off.
If these are okay and you have power to the dishwasher the most common part to have failed is the thermal fuse, shown below with the part number, there is a diagram below that to show where the fuse goes in the console, it is part 6 in the diagram.
If you have flashing lights or some other symptom than just dead and wont start please let me know what you are experiencing so I can assist further.
May 04, 2010 | Kenmore 16602 / 16604 / 16609 Built-in...
Diswasher will not start I had been running it and pushed the start button and it will not run. Checked to make sure was shut tight and if electricty was on,
My dishwasher will not start: Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Each manufacture has different designs.
Nov 07, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Wont go through cycles or drain the 3inches of water.Is getting power
turn on the dishwasher then go to your circuit breaker and, switch off the power to your dishwasher next: reach in to your dishwasher and remove the cover on your pump then remove any broken glass etc. that has fallen into the pump then put the cover back on and, close the dishwasher turn it on and, turn on the breaker you turned off earlier your machine should work again let me know how it goes...
May 02, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Whirlpool Dishwasher,serial number 330251002448 wont stop beeping
The main controller appears to be very confused or failed.
To test, fully remove power from the diswasher for at least 90 seconds. Power back on and test. If the same behaviour is seen, the controller card has almost certainly failed. A service call is the next step to repair.
If you reply, please include the model number of your Whirlpool Dishwasher. Good Luck!
Mar 30, 2009 | Dishwashers
Sears Dishwasher in " Lock" position
unplug the power longer, or its sounds like a wash delay setting is programmed
Feb 11, 2009 | KitchenAid 23 in. KUDD01DPPA Stainless...
Akai tv wont come back on
Nothing......bad capacitors in power supply need replacing.....T.
Jul 16, 2008 | Akai LCT2716 27 in. LCD Television
Stopped working altogether
Check the door switch, it may have gone bad or maybe isnt connecting with the catch, making it look dead. They wont do anything when the door is open, as you know. Also remove the lower panels to get to the inside of the dishwasher. Check for power where the cord is plugged into the machine. If you have power, unplug it and look at the terminals to the heaater element. They are on the right side, facing down out of the dishwasher tub. Just look inside the dishwasher to see where the heater goes through, then look in the same place underneath, Check the condition of these connections. The timer gets power through the heater element (strange but true) so if the heater is bad or these connections have heated and melted, it will cause a dead dishwasher. if tis just the connectio, pu t a new terminal on it and you should be good to go. Hope this helps
Jun 19, 2007 | Asko D1716 Built-in Dishwasher
Dishwashers Logo
296 people viewed this question
Top Dishwashers Experts
Owen Barnes
