Question about Digidesign Mbox 2 Barebone
Mbox 2 no power not recognised
My mbox 2 wasnt working had 6. something, i then upgraded to pro tools le 7.4.2, as iv got mac pro intel then the mbox began to work for a couple of weeks, tried to use gr2 as a plug in system crashed so turned it all off and now when i just plugged it in today no power again, iv heard these things are fragile, its way out of warranty so no chance of replacement any ideas other than send it in for repair....... so many dramas with these things when i googled mbox problems....... help...... havnt got the cash for replacements.....
4 Suggested Answers
when i plug in my mbox 2 a message pops up saying audio device is drwaing to much power.. what the hell does that mean
Posted on Mar 08, 2008
  • 243 Answers
SOURCE: Mbox 2
well if you had your mbox setup previously and used protools. you most likely wont be able to load protools if the mbox is not working. can you tell me what happens when your mbox gets plugged in is there any sign its even getting power? even if its not installed properly a light will be on. to show that its working. it sounds like your mbox 2 went dead i have had this happen a few times.... im on my 5th mbox... did you just purchase this if so. it could be defective or broken.. mbox's are very fragile can you think of a time when it couldve been disrupted and caused damage lately? comment back and ill be glad to help more.
Posted on Jun 13, 2008
SOURCE: Mbox 2 and new macbook pro
my Mbox isnt being found by my mac. when i try and install protools it tells me the mbox carnt be found. i have tried different usb cables ect but nothing seems to work.
Posted on Nov 13, 2009
I'm missin the drivers for my mbox1
Mbox USB Driver Update v.1.0.1 NON-PUBLIC
along with the CollabInfoFix, PT LE 5.2.1 link, and the previously posted
Firmware rev 18 update...
Digidesign Mbox USB Driver Update v.1.0.1
" What Fixed with Digidesign USB Driver v1.0.1 "
The USB Driver Update fixes a problem that could result in corrupted audio
recordings. Typically, the recorded audio would contain clicks and pops after
long periods of recording time. Digidesign recommends that all Mbox users
replace their "Digidesign USB Driver" version 1.0 (located in the System Folder
/Extensions Folder) with this version 1.0.1 driver.
Who Should Use this Update?
All Mbox Users with either Pro Tools LE (Mac) v.5.2 that shipped with Mbox, or
the 5.2.1 web update for Mbox users from DigiProNet
To Download Digidesign USB Driver v1.0.1:
Go to the Support/Downloads/Mbox section of the Digidesign website:
May 12, 2011 | Digidesign Mbox External Sound System
I am using pro tools 8 LE. I have a blue bluebird condenser microphone. the cable going into the mic is a male 3 pronged end. and the end going into my avid mbox mini is a normal ending (the ones that look...
The mbox mini is usb powered, wont work without power so your mac or pc must be powered on and connected. The blue led will be on when powered. Assuming you have the the appropriate cables, you want to make sure the condenser is plugged into the Mic/Line input. (Input 1 on the back of the mbox mini). All condenser mics require phantom power, so engage the +48V switch. Also make sure the DI (direct input) switch is not engaged. The input gain control is located on the front of the mbox... There needs to be speakers connected to the 1/4 output jacks on the back of the mbox or headphones on the front for sound output. Use the large knob for monitor volume control.
In protools: Create a Stereo Master fader track
Create a mono audio track
Set the input of the mono audio track to Mic/Line 1 Arm the track for record (click & make sure the R is red)
You should getting levels and sound output from your condenser.
Apr 01, 2011 | Blue Microphones Blue Bluebird Condenser...
Installed pro tools 8 on macbook pro. when i try to open pro tools it says the hardware cannot be found. mbox2 is connected but the usb light is not on.
I had this problem as well... If this is a 2011 macbook pro you have os 10.6.7 which is not supported by avid at this time. We actually need to down grade to 10.6.6. You installation cd with your macbook pro is 10.6.6, so you'll need to install that, then go to the avid website and download pro tool le 8.0.5. Everything should work fine just don't upgrade to 10.6.7 until it has been approved by avid. If you need detailed steps look at the avid forum for pro tools. Step to uninstalling and installing the os can be found on Do not have your mbox plugged in when you install pro tools. I hope this helps!!!
Mar 29, 2011 | Digidesign Mbox 2 Barebone
MBox 1 Compatibility with new Macbook Pro Unibody and OSX 10.5.6?
unfortunately any pro tools application below version 7.4.2 is not compatible with leopard and I don't think you can use mbox 1 with the universal mac I may be wrong but I wanna say I tried a while back and even garageband wouldn't find it anymore but you can check for sure by going to the applications folder then open the utilities folder in there is an application called "Audio Midi Setup" and you can select the mbox in there if you see it but if not there is no patch or driver that I know of to get it working unless you upgrade pro tools which if you do upgrade I suggest getting mbox 2 and getting LE with it
Mar 12, 2009 | Digidesign Mbox External Sound System
Mbox 1 Compatibility with new Macbook Pro Unibody and OSX 10.5.6?
it could be this mbox thing isnt compatible with intel chiped macs. did you check their website for minimum requirement and compatibility? any of your friends have the same laptop of yours and theirs is working?
did you google "macbook pro not working mbox 1" for forums that relate to you
Mar 12, 2009 | Apple MacBook Pro Notebook
Using Keyboard for Mbox 1
You have to select the port in Pro Tools, but the computer has to recognise the MIDI port first.Does P.T. see that you have a MIDI port installed? Did you select an instrument plug in and map the keyboard as the controller for the plug in? You may need to use a utility like MIDI Yoke or MIDIOX to map the port if you are using Windows. You also have to have the drivers installed so that Windows recognises it as a MIDI port. If it is on a Mac you may have to use the Audio/Midi setup up utility to add the midi port.
Best of luck, Let me know if I can help further.
Dec 25, 2008 | Digidesign Mbox External Sound System
Macbook pro does not detect digi 002 rack
yeah i have an intel imac and had the same problem. I upgraded to pt le 7.4 and now pro tools recognizes the 002 rack and it works fine, but still the core audio manager does not recognize the hardware. It says in "use" when I first turn on the 002 rack, then it says not connected after about 20 seconds. I don't think this really matters though because I have beeen able to do everything fine without having the core audio managr recognizing the 002 rack. I hope that helps
Dec 04, 2008 | Computers & Internet
Jul 22, 2008 | Digidesign Mbox 2 Barebone
Digidesign Mbox  2 Barebone Logo
349 people viewed this question
Top Digidesign Computers & Internet Experts
Zhenya Ogorodnikov
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
