Question about Telescopes
Replace heater core 1991 volkswagen jetta
Directions to replace heater core on 1991 volkswagen jetta
0 characters
1 Points
How do i upload the manual
Do you mean upload to Fixya here? Or to somewhere else?
If to Fixya, you must sign in, then go to the category Telescopes, then click on the link 'Upload a manual' at middle right.
Mar 20, 2016 | Edu-Science Edu Science Core 60mm...
What does plate tectonic theory mean
Plate tectonics is the theory that Earth's outer shell is divided into several plates that glide over the mantle, the rocky inner layer above the core. The plates act like a hard and rigid shell compared to Earth's mantle.
Feb 20, 2015 | Edu-Science (10166) Telescope
No motors running in my goto celestron mount
Most likely the connector at the base of the scope. You will need soldering skills to repair.
Apr 16, 2013 | Telescopes
The hand control isn't working properly. Haven't used the telescope for 12 months. I have replaced the batteries. When I try to align to a star or other object, the direction buttons only work in one...
First thing to do is to buy a new hand controller cable from Meade, If this does not correct the problem then either the hand controller is defective, or something is broken inside the scope.
Cables are not expensive, call Celestron:
Jan 23, 2011 | Celestron NexStar 130SLT (31145) (306 x...
I just bought a new etx-80at... and the az. slew seems to bind up (rotating left) for a moment, then will suddenly release & slew quickly past where I'm trying to take it. I have also noticed that once...
Take it back and get a replacement, something is wrong either with the internal gears or the clutch.
Don't mess around with it-- take it back and get a replacement or refund.
Dec 28, 2010 | Meade ETX-80AT (240 x 80mm) Telescope
I have a nexstar 6 SE and before my wife and I even used it once,some jealous idiot started playing with it in the extra room,and turned the manual focus adjustment knob so far in one direction that He...
Contact Celestron for replacement parts here:
See if they have one.
You can also send it back to them for repair.
Nov 23, 2010 | Celestron NexStar 4 SE Telescope
Need replacement power supply for Mead Model
Contact Meade directly for a replacement at this web site:
May 07, 2010 | Meade DS-114EC (325 x 60mm) Telescope
Daughter dropped her tasco luminova and broke the yoke mounted stabiliser bar which connects to the tripod and telescope casing, where can i get a replacement from, kind regards, carl.
You can contact Tasco directly through their web site, Depending on the specific Luminova model, virtually identical models are offered by Celestron and Meade. In any event, you should be able to get the replacement yoke directly from Tasco. Give them a call at (800) 423-3537and I would think that their customer service department will be happy to help you out. Replacing the yoke is pretty easy to do.
Apr 13, 2009 | Tasco Luminova 40114675 (675 x 114mm)...
I need a cradle for my 40-114675 telescope as it fell out of the box on holiday and could not find it could i be directed to a place where i can get a replacement thanks
solomon483 : HI, there are many extra parts on have a look there .or try
mind you , it may be hard to replace...
Sep 10, 2008 | Tasco Luminova 40114675 (675 x 114mm)...
Telescopes Logo
349 people viewed this question
Top Telescopes Experts
Joe Lalumia aka...
Joe Lalumia aka...
Geoffrey White
Geoffrey White
kenneth njonjo
Are you a Telescope Expert? Answer questions, earn points and help others
