Hi LiLo
Is this unit designed to pre heat the water to a given temperature or is it On-Demand. Eg the heater turns on only when a tap is turned on?
Either way, you need to check if AC is getting to the heater by using a multimeter of a Neon Light tester.
Once you find out if it's got AC at the heater then it's a simple matter of following the AC to the actual element.
If the Element shows 240v across the element but does not heat up then the Element is open circuit and will need replacing.
If there is some control mechanism stopping the element from getting 240v then you've found the problem. The Control circuit or temperature sensor.
Good Luck
SOURCE: 6 yr old electric rheem fury 50 gallon all of a
you have a couple things that may cause this. you may have a bad element a bad thermastat a tripped eco (emergency cut off ) or problem with electric suppling heater.if you have no electric backround or training you should call a pro
SOURCE: Our electric water heater doesn't work.
make sure it is wired correctly, check circuit breaker, check breaker built on to element. If all fails, and it is determined your not getting power to it, you may need a electrician. Be careful. good luck.
Steve
SOURCE: Water does not stay hot for very long. Runs out
The lower element probably needs replacement. It would probably be best to replace them both at the same time.
SOURCE: 1992 Reliance electric water heater model 501 has
Check the breaker and top thermostat and make sure they are not tripped. Move onto replacing elements if above is not the problem.
Turn water and power off to heater and attach a water hose to bottom of heater to drain down tank. May have to open hot side on a facuet to get it to drain.
Once drained remove elements with 1 1/2" found at local hardware stores. once elements removed and new ones in place. Turn water on and get the air out of the system. Once water is flowing from the hot side from all of facuet's in house.
Once all air is out now yaou are resady to turn power onto heater.
