Question about NetGear DG834G Router
Getting on the network
On my ipod touch i ahve the DHCP part highlighted and i have the ip address filled out the subnet mask and the dns filled out and still cannot seem to get on the network what do i need to enter to get on the network without entering a password
  • 1,272 Answers
Hi, if you do not want to enter password to cnonect the wireless ipod to the network then you will have to disable the security encryption on the router itself.
Follow the steps below to disable encryption:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router with the User Name as "admin" and Password as "password" (please note that the username and password is case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as None/Disable.
6. Apply the settings.
Set the ipod to default setting and scan for the wireless network and connect to the wireless network without encryption.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 13, 2009
Hotspot on iPhone and iPad. Why does it only work half of the time?
Future iOS update is going to address this ....in the meantime you need to prevent personal hotspot from assigning dchp automatically by doing the following....
  • Open "Settings" and tap "Wi-Fi", join the Personal Hotspot wi-fi network as usual
  • Now tap the "(i)" button to get more information on the network, make note of the network details under "IP Address", including the IP, subnet mask, router, and DNS
  • Now tap the "Static" tab and enter in an IP address higher in the range than what was set in the prior step, enter the router and subnet mask so it is the same, and set DNS (you may want to use 8.8.8.8 for Google's DNS servers, it's easy to remember and very fast)
You've just set a manual IP with DHCP, circumventing the DHCP servers automatic assignments which seem to be the source of the connection troubles. Exit out of Settings and enjoy Personal Hotspot as usual.
On a side note, you may be able to temporarily remedy the solution by renewing the DHCP lease or resetting network settings on the iOS device, but in our experience it will eventually suffer from the same dropped connection and packet loss. Thus you'll want to go with the static IP approach, it works.
Feb 10, 2015 | Apple Iphone 4s I Phone 4 S Factory...
Have a Intel(R) 82578v Gigabit Network Connection adapter it shows me that i does not have a valid ip configuration
Generally speaking HomeHubs have the IP address 192.158.1.254
In order to get onto the Hub your IP address must be something like 192.168.1.xxx wth a subnet mask of 255.255.255.0.
To check this go to Control Panel, Network & Sharing Centre and click on the connection you are using. When the status box comes up click on details you will be able to see your IP address, subnet mask, Gateway IP address, DHCP server address etc. If the results do not correspond with the details above, go back to the status box and click Properties, highlight Internet Protocol ver 4 and click on Properties. Here you can change the adaptor properties to correspond with those given at the start, or just click on the automatic options for IP and DNS server addresses.
Good Luck
Aug 12, 2014 | Acer Black AX3400G-U4802 Desktop PC with...
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
Can't connect to router interface 192.168.1.1
Took another look by fixing word wrapping in notepad.
It's missing DNS Servers. Check your NIC settings and make sure you don't have a DNS server manually set to another IP. Plus, you might try resetting the router to default in case there is a DNS modification there.
I'm not sure if this is the cause, but I couldn't hurt. It's part of trouble shooting.
Good Luck!
JD
Oct 02, 2012 | Computers & Internet
Unable to establish connection between PC and router.
Check your PC NIC card is installed properly in device manager or connect your PC directly to MODEM and check if IP, DG and DNS would appear.
If that works, then you know its the router (Belkin). Try resetting it to factory defaults by pressing the RESET button.
Jul 26, 2010 | Belkin Wireless G Router
How do i use my wireless ethernet? it recognizes the 1394 net adapter and i have the needed drivers with no splat problems. do i need to set up a wireless connection through the connection settings? i have...
If you are in a network, you need to have a thing called IP address which is usually assigned by a DHCP server or a wireless access point.If DHCP Server is not available in your case then you need to configure evreything manually.If DHCP server is available then you don't need to configure anything.Just search for the WI_FI signal and connect with it.
For manually configuring Wireless Network Setting
Go to control panel and click "network and Sharing Center", click Change Adapter settings" Right Click on the wireless adapter, Select "properties", click on "Internet Protocol version 4(TCP/IPv4)".
Select now use the followinf IP address,
Manually fill the IP address :
                       Subnet mask :
                       Default Gateway:
Select "Use the following DNS address "
Manually fill Preferred DNS address:
                Alternate DNS address:
For example :                           IP address               : 192.168.0.10
                       Subnet mask               : 255.255.255.0
                       Default Gateway           :192.168.0 1
                    Preferred DNS address    :218.248.234.117
                     Alternate DNS address   :218.248.136.142
IP address is needed for communications between devices.
subnet mask is needed for identifying your Network Address Node.
Default Gateway is usually your Router or Wi-Fi access point IP Address.
DNS address for resolving domain name(mostly for Internet browsing)
Hope you can connect it now.
HAPPY NEW YEAR.
Dec 31, 2009 | Gateway 4525GZ Notebook
No connection to laptop.
I would imagine that you have the desktop wired to the 2wire router... Does the desktop have a static or dynamic IP? If you want it to be dynamic you will have to setup DHCP on the router to give the laptop an IP address... Otherwise set the IP on the laptop to the same subnet that the desktop and router are on, i.e 192.168.1.0... Make sure that the laptop is has a static (doesnt change) IP or its setup to receive an IP from the router or another DHCP server, if you have a DHCP server on your network... To make the laptop a DHCP client, set the wireless NIC to automatically select an IP and automatically select DNS servers, this can be done thru the control panel>network connections, then select your wireless NIC, right-click on it and select properties, on the first page of the properties menu, highlight TCP/IP then click on the properties button and when that screen appears, select the radio button for automatic selection of IP and DNS... if you will not be using dynamic IP/DHCP, you will manually have to enter the IP address, subnet mask, default gateway and DNS server IPs.... Let me know if this helps or if I can clearify something for you! Best of luck!
--Joshua79
Apr 02, 2009 | 2wire 2700HG-B Router (2700HGB)
Connecting Ipod touch 8(GB) to Wi-fi
I want to tell you that there might be two problems for your concern.
1. Your router is not working properly
2. Your Ipod Touch is not working properly
But it might be possible that both devices working fine just the compatibility issue.
First of all i can suggest you that you can upgrade the firmware for your router.
Then you can reconfigure your wireless setting on your router.
Then tried to put static ip on your ipod touch in the network setting option
IP address: 192.168.0.15
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.0.1
Primary DNS: 192.168.0.1
Secondary DNS: 4.2.2.2
Then tried again to connect wirelessly with your ipod touch make sure you dont required to add mac address for you ipod touch and also you can click on the option called "Wireless Access Point"
Then you can see the option " Turn Access Control On" you can uncheck this option.
Try again i believe that will resolve your concern.
Thanks & Regards
Jaspreet Singh Saini
Jan 06, 2009 | NetGear RangeMax WPN824 Wireless Router...
Cannot connect to internet
Make the Ip address similary to the router, example 192.168.1.25 should work.
SUbnet mask will then fill in automaticaly, just leave it
then Default gateway will be the routers IP. 192.168.1.1
the dns server would be the ip of your internet provider. I would leave it blank at first, see if it will work then. If not, then ask your service provider for it. If they give u a number, then you will have to go into the router properties, and change the dns and stuff like that in there aswell.
good luck
Dec 25, 2008 | Computers & Internet
Wrong ip address
Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
Mar 28, 2008 | Computers & Internet
NetGear DG834G Router Logo
51 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
