Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
My Sears Craftsman Garden Tractor 22HP, dies after it gets hot
Wow, my Sears Riding lawn mower has just started this little problem this year. It starts right up, but after 40 minutes (1st time), 20 minutes (2nd time) it starts reving/stalling, just like when they run out of gas, though it has plenty of gas in it. I changed the fuel filter as well as buying it a new battery at the start of the season this year. After I let it sit a while, it'll start up again and run for a short period of time, like 20 minutes and starts that dying business all over again.
I'm not sure how long I've had this mower, it's a 917.273080 model. Last year I had the fuel pump replaced through a small engine repair shop. I'm taking it to another small engine repair shop. My fuel filters I buy are clear plastic so you can see how things are going. My brother says it sounds like it's vapor locking.
If my repair man can solve this problem, I'll come back and report. Anybody else dealing with this exact problem?
Thanks, Sue
Sue your brother is right! I had the same problem and it turned out to be the gas cap. the small breather hole on the top was plugged with dirt. once I cleaned it out I took the rubber gasket out from the bottom of the cap and cleaned that as well. runs great now.
Posted on Jul 14, 2009
    President:
  • 1,776 Answers
It could be vapor lock. Vapor lock is a condition where the hot gasoline turns into vapor bubbles either in the fuel line or carb. When it happens, the vapors will cut off fuel flow thru the carb, essentially causing the engine to run out of fuel. You should re-route or isolate the fuel line away from the heat of the engine and install an inline fuel filter close to the carb. Also make sure that the cooling fins are not clogged up with trash or something that is causing the engine to overheat.
Defective Ignition Components
Although this is more common on older point style engines, there is a possibility that an ignition component is breaking down after the engine reaches a certain heat range. While not exactly easy, you can diagnose this situation by installing a spark tester between the spark plug and the spark plug wire and watching to see if spark is present when the engine dies.
If the engine is equipped with a point style ignition, there is a very strong possibility that the condenser is failing and should be tested or replaced.
Posted on Jul 13, 2009
GM Elec
  • 1000 Answers
SOURCE: Need parts manual for Craftsman 22HP 50 inch deck lawn tractor
Go to "sears.com", have your model number ready and go to the parts link. You will beable to view an exploded view of your mower and order parts on line if you like.
Hope this fixes your question, let me know.
Regards,
Posted on Jun 12, 2009
SOURCE: Repair Parts Manual / Book Service Garden Tractor
C I am thanking a lot for dealing with my matter and very much I am counting for your help in getting the list of the spare parts with catalogue numbers of my model of the garden small tractor.
I am greeting Ted
Posted on Nov 25, 2008
  • 11 Answers
SOURCE: Does not continue to run when choke is not in use.
is the high flow ports on the carb clean? does the engine have good compression?
Posted on May 23, 2009
huffman49
  • 235 Answers
SOURCE: cant find our owner's manual this spring; how much
start out with a pint and check it if it's still reading low add a little at a time until it gets to the full mark..good luck
Posted on Apr 10, 2010
  • 420 Answers
SOURCE: john deere 300 garden tractor hydrostatic drive will not work
check two things, make sure the by-pass rod is pushed all the way in and the drive belt from the engine to the rear end (tranaxle). If both check out ok do not attempt to service the tranaxle at home. have thet serviced by a dealer.
Posted on Jun 02, 2010
Tip
2008 Craftsman lawn tractor
Tip for 2008 Craftsman lawn tractor that runs for about 30 minutes then starts to cut out and dies, and will not restart. These tractors have a defective gas cap that will not vent. Simply remove gas cap and reinstall loosely. The best fix is replace gas cap. If your tractor is less than two years old Sears will replace it free. preview_graphic.jpg
on Jul 30, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
Where can I find the model number on my Sears riding lawn mower? It is about 6 or so years old.
Sears puts the model numbers under the seat on most machines since 1990. They are in the format
xxx.xxxxxx
example 538.678567
Good luck
Mar 28, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
Engine hesitates and dies when hot, restarts fine, then dies agai
Check the fuel pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Craftsman Garden
Craftsman 22hp lawn tractor when its hot i loose half the power and backfires on cold months it run fine ...brigs and stratton engine
not a expert just trying to help,, sounds like you have heat problem with the carb or the fuel line,,make sure all the heat sheids are there,, if not repllace them,,cause it will cause the gas to try to vapor lock. hope this help you
Feb 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower cutting off when the engine heats up (Sears Craftsman)
sounds like you have magneto getting hot,,, next time it do it,, let it cool off for about 2 hours see if crank and run again till shut off,, if if does replace magneto,, hope this help,, good luck
Aug 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Regards,
Jun 12, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
3,049 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
