Question about HP Officejet 5610 All-In-One InkJet Printer
Just my black ink isn't working, even though it is full. What can I do?
  • 102 Answers
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab15
Posted on Jul 17, 2009
    President:
  • 627 Answers
Try head cleaning from printer tools
Posted on Jul 13, 2009
rhoncruz
  • 134 Answers
SOURCE: Full black ink cartridge - but says there is no black ink
To run a nozzle clean, perform the following steps:
  1. Verify the All-In-One Printer 924 is powered on and connected to a computer.
  2. Verify that the paper support (input tray) has clean, plain white paper loaded.
  3. Press the Menu button.
  4. Press the Down button until Mode: Maintenance appears on the LCD screen.
  5. Press the Menu button.
    The Dell 924 Maintenance Menu appears on the LCD screen.
  6. Press the Down button until Clean Cartridges appears on the LCD screen.
  7. Press the Start button.
    The AIO 924 prints the cleaning page. This process cleans the ink cartridges and resolves many print quality issues.
Wicking the cartridges and cleaning the contacts on the back of the cartridge should be performed if the nozzle clean was performed and the quality was not satisfactory.
Wicking the Cartridge
  1. Ensure the printer is powered on.
  2. Lift the scanner unit.
  3. Open the cartridge latches and remove the cartridges from the carrier
  4. Take a clean, damp cloth and wipe the nozzle of the print cartridge from front to back
Cleaning the Contacts
  1. Turn the cartridge so that you are looking at the contacts on the back side of the cartridge
  2. Using a clean dry cloth, wipe the contacts in the direction, so that no dust or other contaminants are visible.
  3. Clean the contact inside the printer with the dry cloth used to clean the cartridge contacts.
  4. Replace the cartridges in the carrier and close the scanner unit.
  5. Print the document again.
  6. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times as needed.
Verify the Ink Cartridges Are Installed in the Proper Slot
  1. Remove the ink cartridges from the printer.
  2. Read the label on the side of both cartridges to identify which is color and which is black.
  3. Install the black cartridge in the slot on the left and the color cartridge in the slot on the right
  4. Close the ink cartridge lids and make sure they lock in place.
I hope it helps!!!
Posted on Dec 02, 2008
deepfunktion
  • 18 Answers
SOURCE: My printer won't print black ink even though the cartridge is full
try to clean the nossles with software from the manafactures website
Posted on May 06, 2009
  • 164 Answers
SOURCE: dell 926 will not print black and gives alignment error
Has this printer been sitting for a period of time? Inkjet nozzles will dry up...replace the cartidge, even tho it may be half full, it prolly has dried out
Posted on Jul 24, 2009
sys_admin
  • 829 Answers
SOURCE: error e16 - cannot print even in black or white
Hi Follow the below steps .
E16 -E19 Failed to scan head alignment sheet
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
Posted on Jan 16, 2010
jbriner
  • 130 Answers
SOURCE: the black ink wont work, even though i have put in
Try the following things:
  1. remove the cartridge make sure that you have removed any tape or guards that came with the cartridge to keep the ink from leaking
  2. try gently squeezing the cartridge. if you can get a drop to come out of the cartridge.
  3. if you cannot get a drop out, put the head of the cartridge on a piece of a dampened napkin or paper towel. You should see some black bleeding out of the head. Sometimes, it can take awhile for the ink to loosen up.
  4. reinstall the cartridge and run the head cleaning program for your printer if you have one
Posted on May 27, 2010
I can't print with the black ink. I performed a print head cleaning, and then I printed the nozzle check pattern. I noticed that the Cyan, Magenta, and Yellow shows up. However, the black checkered...
Simple problem that print head cleaning will typically not fix. The black ink is pigment based so it tends to form more stubborn clogs. Just remove the print head and if you have a steamer hit the black printhead nozzles with some pressured steam. If not available, soak the surface of the printhead in shallow hot water (try not to get the contact wet or be sure to dry them if you do). You can tell if the printhead nozzles are open by folding a section of wet paper towel like 5-10 layers and then soak it, press the printhead surface up and down lightly on the wet paper towel and if the nozzles are open you will see some ink pulse in the black port screen (the colors will also pulse from the pressure of the liquid under the printhead). It's easier than it sounds so give it a try. I've saved 100s of Canon printheads this way.
Note: if you have a really dried out head, you sometimes have to soak from the top inlet ports and the bottom nozzle surface to clear, but unlikely in you case since you had a black cartridge installed with ink in it (this keeps the top port from drying).
Sep 15, 2011 | Canon MP520 All-In-One InkJet Photo...
Hp photosmart 8050 won`t print black even though it says it full
Hi there! If you haven`t used the printer in 2-3 months the black ink cartridge has gona dry.Wich means the printer is seeing full ink but the ink isn`t actually coming out from the ink head.Take a peace of clean cloth or cotton and clear the bottom part of the ink head(be verry carfully while cleaning it cuz you may dmg the head.If that doesn`t help just go and buy a new ink cartridge and it will solve your problem.
Nov 10, 2010 | HP Photosmart 8050 InkJet Printer
Black ink won't print even though the cartridge is
It could be you just have a bad cartridge, If it's new, take it back and get a new one to make sure it's not the cartridge. If you get the new one and it still doesn't print black, then you have a bad print head. Meaning it would need to go to a service dealer to replace or repair the print head.
Thanks Mark
May 14, 2010 | Brother DCP585cw AllInOne InkJet Printer
Dell 968 aio printer won't print black
I replaced the ink cartridges even though the levels still said they were half full. It worked perfectly.
Sep 22, 2009 | Dell 968 All-In-One Printer
May 06, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
Maybe you can try to rest the black ink level 1st. To reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
Jan 14, 2009 | Lexmark X2500 All-In-One Printer
Printer says ink near empty
Black electrical tape works like a charm on a Brother MFC-465CN. Thanks for the tip! :-)
Jan 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
532 people viewed this question
Seeker5211
Seeker5211
