Why does this model ''whp12a02oba000c'' read low batterie? If there is a batterie where is it located?
  • 53 Answers
Vulcan Powerhouse or similar???
Batteries (3xAA) are in the thermostat on the wall. Undo 2 screws at bottom of control and pull open from the bottom.
Posted on Jul 18, 2009
What is wrong if the camera is not reading that it has a battery?
Make and model of camera? Make sure battery isn't in upside down
Sep 19, 2014 | Photography
Home Thermostat reads low batt
I have ran into this problem before. I have actually had low batteries I thought were good too ha! I have had to actually reset the stat to get the low battery to stop flashing. There are multiple ways to reset the thermostats, depending on model, but removing the batteries and waiting has worked, along with actually having a reset button somewhere on the stat. Hope this helps!
Nov 30, 2013 | Honeywell Programmable Thermostat Heater
Low RNG
Hi Anonymous, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12 volts or better after charging.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor. Good luck
Nov 14, 2013 | 2011 Harley Davidson FLSTF Fat Boy
2003 mazda tribute, occasionally won't start. fuel pump replaced about 1 month ago. bad starter?
Many batteries may only last around three years. Check battery voltage at rest before starting. Any voltage in the low 12v range may be a sign of a faulty battery.If low voltage present, then perform a parasitic drain test:1) Disconnect battery POSITIVE terminal and connect ammeter in series, between battery positive terminal and positive lead.
DO NOT START THE VEHICLE!!
2) With all vehicle doors closed, alarm off, lights off, radio off, and all other accessories off, wait for around 20 minutes and then read the ammeter. A healthy system should read about 0.03 amps and little more. If reading more, then the vehicle could be suffering a parasitic amp drain, and you will need to locate this issue.
3) Reconnect battery when finished.
If no major parasitic drain present, yet low battery voltage then:
4) With vehicle started, check the voltage charge from the alternator. Connect voltmeter to battery terminals and take reading. A healthy system should be charging in the range of 14volts or down to around 13.5 volts. If reading around 12 volts only, then check and replace alternator.
Nov 03, 2012 | Cars & Trucks
2007 Harley Davidson FLHTCU Ultra Classic Electra Gilde low battery sympyoms
May 07, 2012 | 2007 Harley Davidson FLHTCU Ultra Classic...
Pheonix plus batery flat,charged up,now it is mobile but all i have on dial is single red flashing led.
John the red flashing light indicates a low battery When you charge the battery your charger should be showing a red light for power and a yellow light. When the batteries are fully charged you should show a red and green light on the charger. Now if you have a voltmeter plug the leads into the two outter holes of the charger port located under the front of the joystick.Without the charger plugged in you will be reading the battery voltage. Fully charged it should read 27-30 volts if you are only reading 20-24 volts then the batteries are low. If you have an onboard charger plug it in and you should read the charger voltage of 29-32 + volts If you aren't getting that voltage then you have a bad charger if you are getting the charger voltage then you have bad batteries and they need to be replaced Hope this helps you
Apr 18, 2011 | Health & Beauty
When I turn the key it only clicks, starter does not engage
It's either a bad battery (low on charge) or a loose ground wire. If you are SURE that the battery has 12 volts (yes, even a low battery will run your lights, radio, door ajar chime, etc., but won't have enough to start the car). If the battery is fully charged and your volt meter shows 14.4 volts (fully charged battery reading), then it's a ground wire. There are two locations. The negative battery cable itself on the battery, and the location on the frame or engine where the cable connects to.If these are ok, check the positive cable connection on the starter.
May 11, 2010 | 1994 Lincoln Town Car
RFA battery low. What does this mean
Check you Key FOB for a low battery.
May 20, 2009 | 2003 GMC Sierra 2500HD
Low battery
Dont know your model but on mine the battery is located behind the key pad. turn it clockwise and pull it strait out to access battery.
Mar 29, 2008 | Sentry Fireproof Safe
Power consumption/in watts
Most likely 350 or there abouts.
I tried to look up the specs but VGN -NR17G is not a known model number.
Jan 28, 2008 | Toshiba Satellite M35X-S111 Notebook
Heating & Cooling Logo
117 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
