Question about GS Magicstor GS1022C 2.2 GB Hard Drive
GS1022C problems with my Canon 20D SLR
Have been using the GS1022C in my Canon 20D SLR in a week without any problems. Suddenly the camera reported an error, and since then I haven't been able to read the drive on my computer. Is there any way I can save my holiday pictures?
Canon digital 20d manual needed can not find one any where
You can download a PDF copy of the manual from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/eos_slr_camera_systems/eos_digital_slr_cameras/eos_20d#BrochuresAndManuals
Nov 07, 2010 | Canon EOS-20D Body only Digital Camera
Slr 20D canon camera
There should be a setting (usually in "image settings" or similar) to change the image quality between low, medium, high and RAW.
You probably want high.
Turn the wheel to the tool-icon (settings) and have a browse through the options. You'll find it without much fuss. =-]
Aug 20, 2008 | Cameras
EOs 20D digital camera
Prior to models made in 2007 or later, no SLR camera (film or digital) was able to let you compose the picture before shooting it other than through the optical viewfinder. SLRs are different in this respect from compact digital cameras. You will only be able to review your pictures on the LCD after they are taken.
Jul 29, 2008 | Canon EOS-20D Digital Camera
Canon 20D error 99 shutter stuck
Exactly same problem, shutter clicks until battery removed. Power may be on or off.
Apr 04, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Help me
The sensor in most digital SLR cameras has an aspect ratio of 2 to 3. This is based on the aspect ratio of the film used in 35mm film SLRs, which was 24 x 36 mm. This works fine when you print on 4 x 6 paper (a 2 to 3 ratio), but not on 8 x 10 (which is a 4 to 5 ratio). Something has to be cropped in order to fit. You can't change the physical size of the sensor in the camera, so you will have to allow for some cropping if you are going to have your images printed on 8 x 10 paper.
For information, the 8 x 10 size became popular when many portrait photographers used large format 4 x 5 cameras. This obviously can fit perfectly on 8 x 10 paper without cropping.
Mar 22, 2008 | Canon EOS-20D Digital Camera
Error report 99 on my Canon 20D
take out battery for a few mins and that resets the error, well it worked. or Before I reset it, take off the lens and put it back on.
i heard that some have problems with the lexar cards.
http://www.lexar.com/support/cust_advisory.html
in short, format the card every so offten in the camera and see if that fixes it.
also
try a firmware upgrade if your 20D has highest version get this at canon website
Feb 22, 2008 | Canon EOS 20Da Digital Camera
Canon EOS 20D SLR CAMERA LENS - ERROR 01 ON SCREEN
Clean the contacts between the lens and the camera.
Dec 30, 2007 | Canon EOS Elan 7ne 35mm SLR Camera
Battery Problems
This suggests a major short circuit. Check the the battery contacts in the chamber are clean and not obstructed. Then post this query to the Canon Technical Help team
Jun 06, 2007 | Canon EOS-20D Body only Digital Camera
"busy" Error
check your firmware version and update if necessary. Usually you get the "busy" message when your camera is writing to the card and it's possible the card isn't quite right - a format should fix it. Alternatately you might try a different CF card to see if the problem goes away. Good luck!
Sep 14, 2005 | Canon EOS-20D Digital Camera
GS Magicstor GS1022C 2.2 GB Hard Drive Logo
24 people viewed this question
Top GS Magicstor Computers & Internet Experts
David Payne
David Payne
Are you a GS Magicstor Computer and Internet Expert? Answer questions, earn points and help others
