Question about Countryman (MEMWF05BS1) Professional Microphone
Intermittent "popping" sound through the PA - Countryman (MEMWF05BS1) Professional Microphone
    Scholar:
  • 113 Answers
Hiya, try to isolate the fault first, ( amp, mixer, whatever else is in) Easiest way is to switch of mixer, if still there, then probably the amp if those are the only 2 items in the PA. Once isolated, it might need repair as this often power supply issues. Before sending it in though just make sure all connections, plug wires etc are good as well. Bets of luck
Posted on Jul 13, 2009
Monitor Channel Making static sounds
Without hearing it it is difficult to be sure what is going on. What happens if you plug the main PA into the monitor channels, do you get the same? Are you trying to get too much into the monitors? static and popping are not the same to my ears, popping sounds more like you are hearing something that's there through the monitors that you're not hearing through the main mix as it may be masked. What frequency is the popping? Does it only happen when levels are high or when the singers are doing 'p' and 'b's etc? do you get it if you put the monitors on the main mix? Are you running the monitors into clipping (although I wouldn't expect this to create a popping? It sounds like a mix issue rather than a fault with hardware.
Aug 09, 2014 | Mackie 1604 Vlz3 16 Channel Mixer
Gemsound pa 1005 exa keeps shutting off
I Think that something like a transistor is getting hot and then shutting down. Exploring inside might solve the problem of what's getting really hot. You could even get some Servisol Freeze Spray, and wait for it to go off then spray it on the suspected part. That will cool it down and it should start up again. If it does come on, that part will have to be replaced.
Jun 28, 2012 | Gem Sound GemSound PA-585 2-Channel...
I have the old 3way 600 watt pa speakers x 2,which amp would you suggest, for this speakers.Because I m having trouble with my amps,that keep on clipping and burning out.
DO NOT run amps into clipping. Also, while the speakers are rated at 600 Watts, you don't want to use an amp that delivers that much RMS. Use about 300 Watts per side. Unfortunately you did not mention the brand of amps you are using. I will also caution you that the speakers have protection networks that if you are getting supersonic feedback that you can't hear that can burn out the amps. DO NOT boost the highs if the mics can "hear" the speakers or the reverberations from them. Solid connection of speaker cables is important. Intermittent connections can fry amplifiers... I won't go into the technical reason for this other than to say the amp's feedback circutis get confused when the load shifts.
You might also have the speakers checked since they can have an intermittent that is popping the amps. If you happen to be using BERHINGER PMP amps, please read my tip about the grounding hazard where the sleeve of channel A is hot and the tip the cold that I have in the Fixya tips.
Mar 25, 2011 | Peavey New Peavey Sp3 15" 3 Way PA Speaker
The sound on my mg100hdfx cuts out sometimes then its fine what could this be
Common problems are broken or intermittent input jacks or cracked circuit board or soldering or broken volume controls. Another one is a bad switch contact on the jack for PA input connection. All these are internal and require servicing.
External problems are guitar and cable problems.
Jul 15, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
HP Mini 1033CL intermittent or no sound
Probably something was touching the speaker cone and you snapped the speaker back so it no longer touches.
Oct 22, 2009 | HP Mini 1033CL Netbook
Intermittent fuel problem with 1.9dCI Laguna
it sounds like a cracked diaphram on your fuel pump.have the pump checked.
Apr 06, 2017 | 2003 Renault Sportwagon
Signal to speakers periodically drops out
I can not tell for sure without seeing the unit; however, this often happens with stereo receivers when the contacts on the protection relay start to go bad. You can try to polish the contacts with emery cloth or a fiber brush but it is best to replace the relay if you can find one that will fit.
Jan 01, 2018 | DBX Driverack-Pa Eq/Speaker Control System...
89 people viewed this question
Top Countryman Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Countryman Audio Player and Recorder Expert? Answer questions, earn points and help others
