Question about Sanyo HT32744 32" TV
Sanyo tv wont stay on
My 6y/o 32" sanyo tv has a problem with the on off button. if you press the button to turn it on, once you let go of the button it turns back off? whilst you're holding in the button, and it is on, you get full sound and picture
    Problem Solver:
  • 15 Answers
The problem of your TV is the power switch, and best solution for this is replacement with a good one.
Warning: The next procedure must be done by an expert to avoid risk.
1.Open the the back cover of the TV and detached the board.
2.Try to see any broken solder or cut PCB lay-out on the board.
3.Get a continuity check to the switch.If the switch is defective replace it with a good one.
Posted on Jul 13, 2009
Need remote codes for sanyo tv
press the helpful button Step 1 Insert two AA batteries into the universal remote control if you haven't already done so and then turn on your Sanyo TV. Press and hold the "TV" button on the remote until it lights up.
Step 2 Input the following three-digit codes into your remote control one by one using the remote keypad: "004," "013," "049," "108," "110," "180" and "209." The TV will turn off when you enter the correct code for your particular Sanyo model.
Step 3 Press the "TV" button on the remote once more to confirm the code after you've identified the correct one. You can now use the universal remote to control your Sanyo TV.
How to Set Up the Codes for Sanyo Television and Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
Jan 27, 2016 | Sanyo Televison & Video
Where is the reset button
Sanyo Service Menu - Factory-Reset.com
factory-reset.com/wiki/Sanyo_Service_Menu
Jump to Sanyo TV Service Menu Method 2 - Unplug the power cable. Press and hold the {VOL -} button on the TV while plugging the power cable back ...
Sanyo TV reset button location? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 27, 2007 - Does anyone know where to find the reset button on a 32" Sanyo TV? The thing is just totally dead and I am thinking maybe if I push the reset it ... I have a Sanyo TV, I accidentally hit the reset button twice. I ...
Aug 6, 2012
36 inch sanyo tv won't change off video 2?
Apr 17, 2010
I accidentally hit the 'reset' button the remote of my sanyo tv ...
Jan 6, 2010
Sanyo DS32224 TV Problem!!?
May 21, 2009
More results from answers.yahoo.com
Nov 29, 2015 | Sanyo DS31520 31" TV
Program direct tv remote o sanyo tv
press menu button, go down to parental,fav's & setup push select button,....go down to system setup push select button...go down to remote push select button...pick av1,av2,or tv press select button...pick tv press select...go down to sanyo and press select it will tell you what to do from there
Aug 10, 2014 | Sanyo DS32920 32" TV
I bought the Sentry RMC10 Big Universal remote, but I lost the manual. I am not able search code for a Sanyo plat panel tv, Model DP26640-26" Diagonal LCDHDTV
The codes for Sanyo TVs are as follows.
  • 004
  • 013
  • 049
  • 108
  • 110
  • 180
  • 209
If none of them work, you can try the manual code search feature.
MANUAL CODE SEARCH:
If your product does not respond after you have tried all the codes for your brand, or if
your brand is not listed, try searching for your code by following these steps:
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the CODE SEARCH button until the red indicator stays on, then
release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red Indicator
blinks off once.
4. Face the remote control directly to the device you want to control (TV, VCR etc).
5. Press the ON/OFF button repeatedly (up to 300 times) until the device to be
controlled changes channel. The red indicator blinks off with each button press.
6. Press and release ENTER to install the code.
Nov 28, 2013 | Sanyo Televison & Video
Default code for Sanyo GXDB remote for Sanyo TV
for sanyo tv....
1) press tv button
2) press and hold setup button till light blinks twice
3) enter code 10154 light blinks twice tv should work
Mar 31, 2012 | Sanyo 42 in. LCD TV
My Sanyo AVM-3651g 36" TV keeps showing the
On the remote that came with your TV, press the Display button, which is directly below the Volume Up button. Pressing it once displays the channel number and time, pressing it twice displays the channel number continuously, you must have accidently pressed the Display button twice. Just press it once more to remove the display.
Sep 02, 2011 | Sanyo Televison & Video
I need a code for my sky remote for my sanyo tv in order to get the volume working It is a sanyo 32" Model CE32LD33-B-01
with the tv on and sky off, press red button & select together, remote blinks twice.press tv then standby repeat this action until the tv turns off. when it goes off press select. press standby again and tv should start. your sky remote should then work perfect. as a tip with tv on and sky off press tv then back up this should then go to the freeview setup and you can watch those as well for free
Sep 09, 2010 | Sanyo Televison & Video
Whad code do i hse to control my sanyo dp19649 tv
Hi! I will be more than glad to assist you in this concern. this are the tv codes for sanyo. 542, 589, 590, 591, 592,
609. this is how to reprogram you remote to the sanyo tv. you need to press and hold the tv button that is on the upper portion of the remote, on the right side of the sat button. wait until all mode lights lit up, once all lights lit up, release it and then press number ex.. 542 then followed by the pound button, then you will see that the pound button will flash 3 times, it means that the code is program to the remote. note: while your doing the reprogramming of the remote you need to be in front of the tv about 2 to 3 feet away and the tv should be on.. granting u try all the code and none of them works.. try to scan the code of the tv by pressing and hold the tv button wait until all mode light lit up, then press 500 then pound, tv button will flash 3 times, lets say the last code is 500 and it did not work, press again the tv button and wait until all mode lights up, press on the re tv button if you have, but just incase u have only 1 red button for the power, press it once, then press the up button every 1 sec for 5mins. once the tv turn off then press the pound button and the tv button will flash 3 times, it means that you got the code for the sanyo tv, to check the code: Press the POUND (#) button twice. The mode button
flashes the number for each digit of the device code, with a pause between the groups of flashes. A quick flash is for zero. For example, if the code is 570, the mode button flashes five times, pauses, flashes seven times, pauses, and flashes once quickly... lets say that this remote works before with the sanyo and suddenly it quit working , pls call 1-800-333-3474 and ask for the replacement for the dishnetwork remote, remote is bad. please feel free to get in touch if you have any query..
Sep 07, 2009 | Televison & Video
Remote code for sanyo tv
there are several. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
CODES: 0049,0097,0110,0004,0268,0012,0108,0180
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 29, 2009 | Sanyo DS20930 20" TV
RCA universal remote
I programmed an rca universal remote by:
TURN ONTHE TV
HOLDING DOWN THE TV ANDTHEON/OFF BUTTON ATTHE SAME TIME.UNTILTHEON/OFF BUTTON STAYED ILLUMINATED.
PRESS THE PLAYBUTTON IT WILL BLINK,IF TV DOES NOT GO OFF PRESS PLAY EVERY 5 SECONDS UNTIL TV GOES OFF.
ONCE TV TURNS OFF HIT THE REVERSE BUTTON THE TV WILL COME BACK ON.
HIT THE STOP BUTTON TO SAVE THE CODE.
REPEAT THIS BUT HOLD THE OTHER DESIRED DEVICE INSTEAD OF THE TV.
HOPE IT WORKS
Igotthisinfo from google....then typed in rca universal remote...there was a sight for programming remote.
Jul 26, 2008 | Sanyo DS24425 24" TV
Sanyo HT32744 32" TV Logo
229 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
