The back of a remote control is sticky try every cleaner it does not go away how do we take care of this I can send the picture the only thing we do they use is a paint thinner
If it is a "physical" sticky button, try buying a can of tuner/control spray cleaner from Radio Shack. Make sure the printer is powered down or unplugged. Try spraying around the separation between the button and the area immediately around it and right away push the button a few dozen times. This worked with my sticky microwave button; hope it works for you.
Dont know what tv you have but. You can remove the batteries from remote and if volume still goes down you ruled out the remote as the problem.. Or just take remote to another room. If the problem still exists then Im guessing either a sticky button on the tv volume down or as I have seen to many times.. People clean their tvs with windex or some cleaner and it drips down into the tv messing up the control buttons. Hopefully its just a sticky button..
Hello, Common faults are: some buttons not working, not working at all, corroded battery terminals. Often buttons are sticky because of some dirt accumulated over the years from the sticky little hands of your kids? The hardest part of repair is often to open the covers. You do not need much experience in electronics repair to repair a remote. Also it is perfectly safe as there is no way to get an electric shock as they work with batteries.
step 1Test your remote with Digital Camera Check your batteries first or buy new batteries. Once you have good batteries, you can test with a digital camera by pushing the buttons and having camera on and pointing to the infrared led. You should see red light if the remote is working. If no light comes up you obviously have a dead remote but do not despair and procede to the next step
step 2Open the remote control but there is a catch or a few catches. Remove the screws if any. Sometimes screws may be hidden under a sticker or rubber feet. Often there are no screws at all but just plastic catches hidden so you have to be clever to open it without breaking the case. Use something blunt and flat toclick the covers open. This is often a challenge but should not be too difficult.
step 3Take a picture of every phase so you remember how to re-assemble Since you are using a digital camera you might as well take pictures of the disassembly so re-assemly will be easier.
step 4Pull everything apart Did you take a picture of the keyppad layout? Sometimes keypad is just one rubber membrane but sometimes the keys fall away like pieces of a Lego puzzle. And if the buttons are marked with numbers and functions you may struggle to re-assemble them in right order? Use a small plastic takeaway box or similar to store the bits so you don't lose parts.
step 5Inspect the circuit board and repair dry joints Remotes are often dropped on the floor and may develope dry joints on the battery contacts or circuit board. Inspect the contacts and circuit board under good light with a magnifying lense or if lucky you might have a microscope or just a very good eyesight? Solder all suspicious joints. If there is a sign of water damage you can use methylated spirits and toothbrush to...
step 6Wash the covers and the buttons Use a smal bowl or similar to wash and contain all the parts so you don't lose bits down the drain. Use old toothbrush to clean all button holes and buttons. Warm water with dishwash liquid does the job. Take particular care with those small buttons and clean them properly. If you can leave the bits to soak overnight they come clean easy. Ultrasonic cleaner would be goo...
step 7Rinse, drain and dry the parts Rinse with warm water. Use a drainer to contain all the parts without losing small bits down the drain. As extra security use sink plug. Dry with a paper towel. Wipe the buttons dry individually as they may still have some dirt which makes them sticky when in use.
step 8Repair case and re-assemble If there is damage to the case or buttons you need to do the required repairs. Use hot glue or super glue depending on fault. Let dry overnight if you had to glue something. Re-assemble bits in reverse order and make sure you have the buttons in right place and right way around. Small nicks and dents on plastic cover can often be repaired by heating carefully with a h...
step 9Test with Digital Camera Test every button as before. Sometimes you have to push two remote buttons simultaneously as with recording buttons on my Panasonic VCR. Once you have completed test with your camera you can use the remote.
step 5Inspect the circuit board and repair dry joints Remotes are often dropped on the floor and may develope dry joints on the battery contacts or circuit board. Inspect the contacts and circuit board under good light with a magnifying lense or if lucky you might have a microscope or just a very good eyesight? Solder all suspicious joints. If there is a sign of water damage you can use methylated spirits and toothbrush to…
step 6Wash the covers and the buttons Use a smal bowl or similar to wash and contain all the parts so you don't lose bits down the drain. Use old toothbrush to clean all button holes and buttons. Warm water with dishwash liquid does the job. Take particular care with those small buttons and clean them properly. If you can leave the bits to soak overnight they come clean easy. Ultrasonic cleaner would be goo…
step 8Repair case and re-assemble If there is damage to the case or buttons you need to do the required repairs. Use hot glue or super glue depending on fault. Let dry overnight if you had to glue something. Re-assemble bits in reverse order and make sure you have the buttons in right place and right way around. Small nicks and dents on plastic cover can often be repaired by heating carefully with a h…
step 9Test with Digital Camera Test every button as before. Sometimes you have to push two remote buttons simultaneously as with recording buttons on my Panasonic VCR. Once you have completed test with your camera you can use the remote. Hope this help in solving the problem and Take care......
Ensure nothing sticky has been spilled on the TV or the remote, causing the volume down button to stick. Remove batteries from remote to rule it out. Carefully inspect TV volume control for a sticking button. If you find it is sticking, get electrical contact cleaner from Radio Shack and spray the button. Ensure TV is unplugged first.
This type of problem may be caused by a dirty video head, people some time try to adjust tracking to take care of this problem this is a mistake. Now to clear up this issue first you put the tracking control mid way in its setting, then you clean the heads of the VCR you can use a head cleaning tape (follow the instructions on the cleaning tape box)for this or if you have experience you use a chamois swab type cleaner (follow the instructions on the package of swabs and liquid cleaner). one the heads are cleaned you acn then try to adjust track to obtain the best picture. If you can not you may have video head problems or a problem in the drum motor (servo) mechanism. In which case I advise taking the unit to a TV repair shop.
Try it with rubbing alcohol first - just keep it away from the optics, and you may get lucky.
The only thing that ever seems to work with these is an abrasive cream cleaner (jif/cif or similar) - you just have to use lots of cream and be careful not to polish the optics - unfortunately the stickiness will come back quicker than before though.
I haven't tried myself, but i have heard that once you have carried out the cream cleaner routine, you can paint the unit - ask your hardware shop what sort of rubbery paints they have - ideally oil based and not acrylic. It wont last as long as the original finish or like quite as good, but it should stop the stickiness for a while at least.
Try and keep your binoculars out of the sun - most of the stickiness is either caused by that, or contact with a damaging chemical such as most insect repellents, or petroleum products.
Hope this helps :)
