Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
I have a intex 15'x 48" pool and a8110 salt water chlorinator. Iwould like toknow what type and how much salt I need? It's my first pool. Any set up advice would be greatly appreciated. Thanks O.G/
  • 297 Answers
Beleive it or not all pools are not created equal
you can have 2 different brand pools the same size and they will have different water capacity
in your case since you did not tell what model pool we will go the average route
15x48 is an average of about 4000gl
that translates to about 100 pounds of salt
most important is to get a salt test kit and a chlorine/ph test kit both for about 10 bucks each
start with 75 pounds salt throwing it right in the pool then pushing it around to help dissolve it like with a brush
you want 98% pure pool salt, not iodized salt best to get this from a pool store 40lbs for 8-10 dollars
remember not to let them sell you thiungs you do not need or give bad advice
once salt is in and partially disolved turn on filter only for 24 hours
now check salt level with kit
it is imparitive to have your salt level at as close to 3000ppm as you can
you can be as high as 4000ppm but remeber the higher it is the more salt taste you will have any lower than 2500 then it is hard to generate chlorine when needed
try to find some of my other posts dealing with cloudy water and green water and you will read more info on filtering which is a major factor
If you have more questions I am at shhhucantcme2@yahoo.com
Posted on Jul 13, 2009
My intex saltwater system pool is cloudy
The chlorine level maybe too low and it is allowing algae to start growing.
Check the Ph level, it should be around 7.
Check the chlorine level in the pools water, use your chlorine test kit.
Check the salt levels, make sure it is at the correct concentration, too low a salt level and the Intex will not be able to generate enough chlorine.
Jul 03, 2012 | Intex Automatic Salt Water System for ...
Just purchased and installed Intex salt water system. It shows low flow and now, after 5 days of installment, the water is completely green (expecting Swam Thing to come out!) I need your guidance to...
Seems like you may not have the pump and the salt chlorinator in sync... If your water is dark green and not a big pool, you may want to drain and refill, if you have a large pool, you may want to shock and then try the following...
1.Make sure you have added the correct amount of salt...
2.Set your timer for your pump for 12 hrs.
3.Wait 15 minutes and then turn on your intex salt water system..
4.Set you hrs of operation on your salt water system for 10 to 11 hrs...
5.After running the system for 3 days, check your chlorine level..
If water clears and chlorine level is high, adjust the time.. You will have to re-sync the pump and chlorinator.. If the pump turns off before the chlorinator finishes it's cycle, you will get a "LOW FLOW" alarm..
I hope this helps and good luck.. Please rate and comment on the information provided.
Jul 26, 2011 | Intex Automatic Salt Water System for ...
Why would our salt water system not be producing chlorine? Intex it was installed less than a month ago. to a very green pool we have put in chemicals and gotten it pretty well cleaned but its still is...
first crack union at return see if chlorine present with test strip if ok then pool needs super chlorination its eating up your chlorine if no chlorine at return have salt level checked if ok check sensor and cell if unit is working must keep balanced unit will only maintain
Dec 25, 2017 | Intex Automatic Salt Water System for ...
Intex salt water chlorinator I added a higher flow pump and chlorine levels seem low no matter how many hours I run the chlorinator
your pump has nothing to do with chlorine generation.
You need to get a salt test kit that reads in #'s not colors.
Now get your salt to 3000ppm or as close to it as you can.
The amount of salt reccomended in the manual is just a starting point
any lower than 2800 and you will not produce enough sanitizer and over 3600 and your pool can go cloudy, taste bad, and rust metal parts
Jun 28, 2010 | Intex Automatic Salt Water System for ...
My water was crystal clear when delivered. I added the salt, ran the filter pump for 24 hrs as instructed. Turned on my Intex saltwater pump and within an hour water is green. Cannot find anything on...
I am not impressed at all with these salt water chlorinators.Shock the water and keep the filter running next day add a powdered chlorine.filter still running. check the balance with test strip in about four hours.If chlorine level is good start vacuming the algee off the bottom of the pool. Now throw away the salt generator and stay with the chlorine packs every week to two weeks continue to monitor with test strips
Jun 17, 2010 | Intex Automatic Salt Water System for ...
I set my hours and it is working but i thought intex salt water
it can take up to 10 minutes for that second light to come on.Until then you are probably not producing chlorine
Jun 07, 2010 | Intex Automatic Salt Water System for ...
I have a 18ft x 52 intex pool with salt water chlorinator.green
although you may or may not have enough chlorine in your pool you must also realize that a pool need turned over at least 3 times a day.
an example is if you have 7000gl of water and a 2000gph pump you need to filter at least 10 hours or so.
More important than chlorine is the actual circulation of the water you can have all the chlorine in the world but if you do not have the circulation the water will become cloudy or green this also happens when you have no swimmers for days at a time
the filtration time is over and above the chlorine generating time your 4 hours a night for generating chlorine sound like you are guessing sometimes it may be 4 and sometimes 2 or 6
it depends on # of swimmers a day sun and what was in the pool to start
It is important to have a test kit for ph and chlorine and keep chlorine at 1.0to 1.5 now set your ph
ph will rise and fall with your chlorine level one you have them set good at the first time then ph should stay safe enough and re level as chlorine is kept right
also remeber that the wrong ph causes more problems than wrong chlorine levels
Also make sure your salt is no more than 3000ppm and no higher like some people recommend and no lower than 2500 test kits are available for 10 dollars
all of this can be found on intex.com either in a video or pdf files for water capacity and approximate time for generating chlorine.
to be sure always use test kits
Jul 12, 2009 | Intex Automatic Salt Water System for ...
I have an intex chlorinator and an intex 24' x 48" round pool. I added only 250 lbs of salt, but the table said 290 lbs. I never got a "low salt" reading. When the water level got low I added water and...
high chlorine can cause problems too it will give false readings for your ph and alkalinity.
The most important thing to remeber is that there is a sequence to follow.
First buy a test kit for salt about 11 bucks for 10 tests. you need to have the ppm's at 3000
if it is to high drain 20% water re-fill and filter/curculate for 6 hours then test again. once at 3000 then go for your chlorine it should be between 1.0 and 1.5 with a test kit now with those 2 in line go for ph adjustment ph should be as close 2 7.6 as possible. Ph will cause more problems like cloudy water or algea more than anything else.
another thing you need to realize is that the intex salt system sucks. Once you set it for the # of hours to chlorinate you are basically guessing as to what is needed. Yes there is a guidence chart as to hours to run but it is over kill and lets too much chlorine be generated start with 3-4 hours of generating but remember also that at 4 hours generating that is nowhere near enough filtering
you will need to shut power off get it out of sleep mode and continue to filter
on avberage a pool should be turned over 3 times a day my pool 7000gl and the 2000gph all in one intex salt pump needs run at least 10 hours a day alone without the chlorinator
my pool only 18' so with your total gallons it will be longer
one last thing to consider is that when in chlorine generating mode the filter slows down because of all the electronics. You can not hear it happen but if you put your hand in front of the discharge you can tell
Jun 27, 2009 | Intex Automatic Salt Water System for ...
Our pool water is yellow and think it is because low chlorine
Add more salt and no salt strips only chlorine
There is also some chlorine called super chlorine that would work better
Jun 01, 2009 | Intex Automatic Salt Water System for ...
No chlorine reading
Salt is sodium chloride, you can only measure salt levels now as your CL (cloride) is bound to a NA (sodium). Table salt =NACL, Your Intex system will tell you if your salt level is too high or too low but your old test equipment for free chlorine will continue to tell you no chlorine as it can't react with the chloride any longer as it is bound to the salt. That is why they tell you you never have to add more because the salt stabilizes it. Your chlorine is there it's bound to the salt. Use the pool it's fine and it makes your water feel really soft! Just keep the salt level right and your fine> It's confusing as they call the unit a chlorine generator! I had the same issue, called Intex and they told me the above.
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
453 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
