Question about Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher fills and runs but the water does not drain out of the machine and I have dirty water that then mixes with clean water to rinse the washed dishes and stays in the bottem.
  • 51 Answers
There is a drain hose for your dishwasher that often gets clogged. Remove the drain hose and clean it out. reinstall the hose and your dishwasher will drain. The dishwasher should have a panel to remove and then comes out easily, just be careful not to pull it out too far. If this does not fixya then you may need to throw some parts at it, but hopefully not. Good luck
Posted on Jul 13, 2009
My Frigidaire dishwasher has dirty water.standing in bottom. Dishes are not clean
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 08, 2012 | Dishwashers
Filters clean, arms unblocked, salt and rinse-aid ...
Yes! you are already having the answer. check your water inlet flow. Clean the strainer at the machine water hose connecting end.
Check the drain filter also. Refer user guide for instructions on cleaning.
May 19, 2010 | Dishwashers
Even though dishes are rinsed, the drain filter is always filled with dirty water. dishes have soap reisdue and/or are not clean. we had a plumber look at it and he said the hoses are not kinked -...
It looks the main drain is choked. Give a try by keeping the machine discharge hose in a big bucket or tub and run the machine. Watch-out. the bucket should not overflow and soil your floor.
If you find every thing is alright check your main drain pipe.
May 20, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Gritty/sandy feeling on dishes from dishwasher
You could only check the basics. Since the dishes are clean, it means they went through the wash cycle. It also means that that the holes on the washer arm are not blocked. If they were salty and dirty the wash arms would be something to check. And since they came out feeling like salt is on them its possible they didn't rinse and its also possible the dirty water didn't drain.Were your drain and fill hoses checked or did the techs just check the dish washing machine itself? Its also possible the water for rinse is not hot enough. Before the rinse cycle comes around try running the hot water at your kitchen faucet. Any other issues may be within the cycling of the machine.
Apr 29, 2010 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
I have gritty debris on the dishes, it appears the small bits left on the dishes before loading get broken down and rinsed onto them as grit again! The dishes are not spotless going in but they are scraped...
1. it can be water backing upfrom maybe a garbage disposer like a clog ,or fill jet dry compartment completely.add nad fill then open and close the door 3 times then you will be able to add more what you are doing is taking out the air in the dispenser.once it is filled completely last thing is to make sure the water ghoing into machine is hot,then start the machine for best results. let me know if i have been of some help
Feb 24, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Not rinsing glasses clean
If the glasses are spotty from hard water try a rinse aid like Jet Dry. If they are actually dirty, depending on the brand of DW you may need to rinse them better before putting them in the DW. Not all brands are cerated equally, some do work better then others
Oct 11, 2009 | Dishwashers
My whirlpool dishwasher cleans well but once the rinse cycle is completed and drained the next day the washer has water in it. HELP!
it could be a bad fill valve.to chk this ,open the door and look for the inlet hole from where water comes in.if u see and droplets of water coming down the hole then it is the fill valve.when machine is off the fill should be closed and no water should come in.
other thing could be ,if u have hooked up the drain pipe of the unit directly to the food disposar instead of going through air gap mounted at the sink then some water from the disposar could flow back into the unit.units have chk valve valve built in drain pipe but some times they work 100%.also chk 2 c if water insinde unit is dirty or fresh to confirm above things.
Aug 22, 2009 | Whirlpool DU1055XTS Built-in Dishwasher
Dishes not clean enough. as if rinsing in dirty
If your dishwasher drains it's water to a garbage disposal, give the disposal a spin while the dishwasher is pumping out. Check around the bottom of the dishwasher to make sure something is not clogging the drain.
May 01, 2009 | Kenmore Dishwashers
Dihes not clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Whirlpool GU2400XTP Built-in Dishwasher Logo
192 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
