Question about Kirby G4 Bagged Upright Vacuum
Change fan unit - Kirby G4 Bagged Upright Vacuum
  • 357 Answers
Here is a free online manual. The fan is also available for purchase. :0)
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302
Marci
Posted on Aug 07, 2009
How to dismantle the Dyson DC08 fan unit?
The fan / motor is not designed to be taken apart.
Jun 29, 2014 | Dyson DC08 Cylinder Bagless Canister...
I have a 18 yr old Admiral DH359 demudifier. When I turn on the dial (switch) it gives a humming noise buy the blade does not rotate. After about a minute or two it shuts off because of condenser over...
The problem with your unit is the fan. The engine behind the blades have gotten spoilt hence its inability to roll the blades. Usually when the engine of a fan is spoilt as a result of the coil the engine still tries to move but due to the bad coil the engine hums but does not come to a start. The fan is meant to be the main component which regulates the temperature of the unit if the fan does not cool the unit then the unit will overheat and go off. Simplest solution is to extract the entire fan plus its engine and get ? replacement for it. If you have the required expertise to open and reassemble the unit you can do this yourself otherwise get an expert to carry it out for you. Hope this solution has been helpful?
Jun 23, 2011 | Vacuums
How can I fix my Lasko E20739 tower fan, when the motor stops running?
That fan has an electronic (computerized) control board which sometimes malfunctions. Nothing new there, right?
The problem is that the cost of the repair can excede the price of a brand new replacement, with a warranty to boot.
You may take it to a service depot and get it checked out, provided you get an estimate and this is done free of charge.
May 25, 2011 | Vacuums
Our Gen3 Kirby still works but is extremely loud not - I am currently only using with the wood floor attachment (no brush) - thoughts?
this could be the impeller fan next to the motor shaft under your attachment hose connection.
to determine this, remove the hose from the unit, and turn the fan shaft with your hand looking down inside the unit. You should see blades on the impeller fan, and they should all look squared off and curved. If any of them are broken or worn, it will make the unit louder than normal.
Also, the hose attchment has an increased noise more than using the brush attchment anyway because it increases the suction for the hose more than on the carpet. IE the motor runs faster giving you more suction.
An Impeller fan for the G3 Kirby will run about 18-39$ for the fan. More for labour.
Good luck,
Mark
Nov 07, 2010 | Kirby Generation 3 Bagged Upright Vacuum
My Hampton Bay ceiling remote model no. UC7030T does not work. How can I get another one. My fan will not work without it.
First, be sure you did not change one of the dip switches in the hand held unit while changing batteries. You would have to see if the switches in the hand held unit match the switch positions in the fan receiver.
This is one of the many sites you can go to for remotes:
http://www.lightinguniverse.com/fan-accessories_84.html
Hampton Bay fans are sold exclusively by Home Depot. I would check on line or stop by one of their stores to see if you can pick up a HB remote. Once you get a new remote you have to again make sure the dip switches are in the same position. Paul
Oct 11, 2010 | Vacuums
The vacuum has started making a much louder noise. like something is coming apart or is stuck/clogged. Noticed the fan type blade has several cracks, some bigger than others. could this be the problem?
Yes, this is very likely. The fan is made of plastic, because a metal fan would be so heavy that it would make the motor burn out unnecessarily fast. Sucking up things like loose change, pebbles, screws, etc. can crack the fan, and unfortunately this requires the front part of the motor to be disassembled. I'm pretty handy with Kirbys but I wouldn't attempt this type of repair myself. Best to leave it to a professional.
Do be sure to remove the em-tor unit (the plastic part that attaches to the blower in back) and check to make sure no large items are rattling around in there. Just unhook the bag clip from the handle, grasp the em-tor unit at the base and turn firmly but gently. When it pops off, all the things that were too heavy to get sucked upward into the bag will fall out. This might help, but it is not recommended to run a Kirby with a damaged fan. It is bad for the motor.
May 24, 2010 | Kirby Heritage II Vacuum
Poor suction
This vaccuum has a Fan Blade inside connected to the motor that spins to create the suction you feel. After a few years of use (and misuse) the blades on this (plastic) fan will be broken off, thus damaging the unit. These Fans are replaceable if you can find where you can purchase a new one. Now, if you have any knowledge of repairs at all, it's not that hard to replace to fix. If you don't feel capable of this though, I suggest you refer to someone more qualified to do this repair.
Oct 10, 2009 | Vacuums
Motor problem
First six pictures HERE will let you know how to remove shell to see the motor. I would not recommend starting it before you get the screw out (you will need to remove 5 more screws from the front f the unit to get the fan case off). The fan case is glued so you may need to use screw driver and pray the fan case of the unit. If fan is damaged - remove it from Kirby as damaged fan is out of balance and Kirby will vibrate like crazy. Shaft has opposite thread so you have to turn it CLOCKWISE.
If the fan does not come off easily you may have to remove this part and access the rear of the motor where you can use a wrench to hold the armature (you will see where you can hold it right behind the commutator. Removing slide bracket assembly memorize where the wires are plugged in and how it is engaged with the transmission.
God Luck
Rocky
Nov 10, 2008 | Kirby Generation 3 Bagged Upright Vacuum
How do I change the fan on my model 2HD kirby
Generic problem for all Vacuums
How do I change the
posted by Rogor on Apr 18, 2008
How do I change the fan on my model 2HD Kirby
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
1st you need to remove the head with the revolving brushing by dialing off the belt and undo the Kirby lock @ the top o the bell housing. Remove the head and that will expose the fan and the fan housing. The fan housing is held on by a couple of screws and once you removed the screws then you need to separate the fan housing from the motor section, it is held on by a Kirby fan housing sealer that is clear – so try to separate the fan housing with a knife or screwdriver, once the fan housing is off the Kirby fan is screwed on I believe either clockwise or counter clockwise and un-screw the fan and follow the reverse situation on installing the fan but you need to use the clear Kirby Fan Housing Sealer to re-seal the fan housing and let it dry and wipe of the excess clear sealer before putting it back together again. Always remember on the Kirby vacuums – use genuine Kirby parts on the repairs, it does make a difference. Then go back and place the Kirby head back on the vacuum – lock it on place and then re-dial the belt onto the Kirby fan shaft, plug your vacuum in the wall outlet and test run the vacuum.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
www.A-1Vacuum.com 1-800-657-1874
Apr 18, 2008 | Vacuums
Kirby G4 Bagged Upright Vacuum Logo
114 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
