Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
Gaggia baby 18 momths old water coming through steam bit but no water coming through coffe bit any suggestions libby
  • 1,089 Answers
HI
If you have a pre-grind button on your machine, push it but don't put any coffee in the brew unit. Push any of the coffee buttons, and see if water will come out then. If it does not, then you have a plugged brew unit and the brew head needs cleaning. I have directions for cleaning.
Posted on Jul 14, 2009
My gaggia titanium keeps coming up with ventilate in the display have cleaned the whole machine out made no difference
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
Apr 19, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia Syncrony logic rapid steam machine leaks water from bottom
Check the chamber under the white plastic valve behind the brew unit, it might be blocked with coffee.
Apr 13, 2010 | Coffee Makers & Espresso Machines
Gaggia Coffee Delux Steam pressure probem
1: do you pres the switch for steam and wait until it is ready? 2: how long time machine needs to be ready for steaming?
solution 1 = if you don't press the steam switch on you will have very small amount of steam. solution 2 = if the machine gets ready only for few seconds to steam, than you must change your steaming thermostat attached in boiler(there are 3 of them: 1 security 2 coffee brewing 3 steam
i hope you fix it soon and enjoy in perfect espresso
Apr 04, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
We have just bought a secondhand baby Gaggia and we cant get the steam to come out the frother. It is an orange coloured machine .
Propably the steam pipe is blocked from dry milk. You can use a thin steel wire insert it in the pipe from bottom. If you manage to open it a little bit and start having steam then by boiling water and leave the steam pipe imerse in it it will melt the remaining dirt and by open the stem valve then the dirt will spoot out. If not then the valve is blocked or broken.
Jan 02, 2010 | Gaggia Baby Espresso Machine
Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Nov 26, 2009 | Gaggia Baby Espresso Machine
My Gaggia Baby C coffee maker has stopped pumping water
From what you have asked the only thing I can suggest is that the pump needs to be replaced. Do you hear the pump vibrating? The lines from the pump may be blocked. Have you tried to descale the machine.
Jun 06, 2009 | Gaggia Baby Espresso Machine
Water pump does not work
Try to open the steam knob and turn on the button to make coffee, when the water flow out off the steam pipe, close the knob and the button.
Jun 06, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Where to fix my Gaggia
If you are unfamiliar with semi-automatic machines you might have neglected to prime the machine: open steam valve with a small container at the nozel, press coffee delivrery button and wait til water runs into the container,the close steam valve and water should come through shower head. This is very basic. If no solution then the head group might be jammed with old coffee grinds. See coffeegeeks forum on subject.
Dec 30, 2007 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
301 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
