Question about Dell Latitude C640 Notebook
Help cannot get into safe mode or pass windows screen just black screen with writing have tried all options f8 etc no luckmany thankssarah
  • msdell Dec 13, 2007
    I too have the same problem and do not have a floppy drive or original cds. can you suggest another solution please?
  • msdell Dec 15, 2007
    I too have a similar problem with no floppy drive and original cds! please advise how to get into safe mode..... thanks
  • 883 Answers
Must boot machine into DOS only from floppy disc. Once in, first run chkdisk.exe on hard drive to correct errors. If, after this produces no results, must repeat process, then re-install Windows.
Posted on Nov 16, 2007
How to put toshiba f20 into safe mode
when the computer first starts to boot up tap the f8 key this should bring up the options for booting into safe mode if not try f5.
May 02, 2011 | Computers & Internet
Window 7 every 20 minutes hang
Many things could be causing this, the first thing I would do is boot into safe mode and see if the issue continues.
Safe Mode
Just before the Windows 7 splash screen (black with windows logo) appears, press the F8 key to enterAdvanced Boot Options.
You should now see the Advanced Boot Options screen. If not, you may have missed the short window of opportunity to press F8 in the previous step and Windows 7 is probably now continuing to boot normally assuming it's able to. If this is the case, just restart your computer and try pressing F8 again.
Here you are presented with three variations of Windows 7 Safe Mode you may enter:
  • Safe Mode - This is the default option and is usually the best choice. This mode will load only the absolute minimum processes necessary to start Windows 7.
Mar 15, 2011 | Toshiba Satellite L305D-S5935 15.4-Inch...
INSPIRON 640M WILL NOT GO INTO SAFE MODE , IT GIVES OPTIONS BUT NONE OF THEM WORK , THEN IT GOES TO THE BLANK SCREEN.
Try going to safe mode manually. The steps mentioned below will help you accessing the safe mode
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Safe Mode/Safe mode with networking".
Step 5: Select that and HIT ENTER.
Jan 20, 2011 | Dell Inspiron 640m Notebook
Pass word of my window
Try restarting your computer. While the computer is restarting press and hold down the f8 key untill you are prompted with a black and white screen that has the option to boot in safe mode. Select boot in safe mode, Once your "safe mode" desktop appears go to your user accounts an change your password. Hope this helps
Jun 21, 2010 | Microsoft Windows XP Professional With...
How to go in safe mode?
to go into safe mode, turn on your computer and constantly press F8 immediately. You will press the F8 button at the first black screen, that is, when your computer displays its log.
While pressing the F8, a windows option will be the next screen to appear, amongst the windows option, you will see safe mode there, use your keyboard arrow key to scroll to safe mode and press enter.
By now,your computer should be loading on safe mode.
Good luck.
May 18, 2010 | IBM ThinkPad R51 Notebook
I cannot logon to my PC
Start your PC in safe mode, to do this repeatedly tap the F8 key as soon as you turn the power on. This will then bring up an "options" screen listing boot in safe mode, safe mode with network support etc. Just use safe mode. If it goes directly to windows instead - shut it off and try again til u get the safe mode screen. The arrow keys control the selection to choose.When it starts in safe mode a black screen will usually appear with a bunch of writing, this is normal, after that it may "hang" for as long as 5 minutes, before coming up with a login screen. Sometimes hitting enter or escape will bring up the login screen faster. When you have a login screen, login and disable the updates using the software control options for the software that is trying to update. You might also go to control panel, administrator options, then services and disable automatic updates temporarily. When your pc starts in safe mode - it starts with minimal drivers and does not run updates- this allows you to change settings. You can then reboot normally and it should start properly without updating before starting.
Aug 29, 2009 | Acer Aspire AM1610-U1201A PC Desktop
Cant get into safe mode. tried toggling f8/f7 together but nothing
the key to getting into safe mode....tapping F8 (only that key) super fast, not stopping until you hear a beep...and see the option to boot into safe mode.  The most common reason that it will not work is that it is not pressed fast enough or early enough.  You will know that you missed your chance if you see the windows loading screen......start pressing it right away when you restart your computer and don't stop pressing F8 until you see the black screen with the white letters giving you the option to boot into safe mode.
Good Luck!
May 08, 2009 | Acer Aspire 5100 Notebook
My dell 610 won't start
Unplugging all unnecessary devices such as printers, network cable, usb devices etc. and see if anything changes. Try rebooting it in Safe Mode:
To go into safe mode -- Press F8 key as soon as the pc restarts.
(You will have do again if pc starts in normal mode.)
You would see a black screen as soon as you hit f8.
Select Safe mode
On the black screen >> select the option that says
Mar 30, 2009 | Dell Latitude C610 Notebook
Compter won't open windows
first try that safe mode option and do log in . when you successfully log in restart your computer . this happen mainly when there is sudden loss of power supply to the cpu. shut down your computer properly by pushing the power button on the cpu
Jun 19, 2008 | Computers & Internet
Getting out of the initial set up
First try to Boot to Last Known Good Configuration.. do this by pressing F8 upon bootup...look at the prompt screen for the option mentioned OR
Attempt to boot up in Safe Mode....
Do This by pressing F8 Upon bootup, it will take you to a black Safe Mode Options screen... once there choose the first option.. boot into Safe Mode Only.. If you are able to boot into windows that way,, you can then check for problems... Like checking the device manager for errors, Check the Status of your hard drive.. etc.
Jun 04, 2008 | Dell Latitude C400 Notebook
Dell Latitude C640 Notebook Logo
27 people viewed this question
Alun Cox
