Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool side by side - freezer keeps shutting
Whirlpool side by side - freezer keeps shutting down only works agian if i unplug an plug in again then it only last a few hours and then cuts out again
  • 53 Answers
Your thermostat is defective and require replacement to settle this problem.
Posted on Jul 13, 2009
Our refrigerator is only about six years old. The problem began after the refrigerator was unplugged for about six weeks and then plugged back in. The freezer side works just fine. The refrigerator side...
Maybe corrosion in the cold control. Could be a fan shutting down. When fresh food side is warming up , is fan running in freezer? My guess with the information given. A simple repair.
Mar 28, 2011 | Refrigerators
Water is collecting in bottom of refrigerator
if the freezer is on top and water is under the bottom draws you have a plugged drain in the freezer.remove everything out of the freezer, shut down the machine or unplug it,remove the back inside wall of the freezer,with a hair dryer melt out all the ice.you'll see a drain hole under the evap coil,you have to blow that out,i use a steamer,you can try a turkey baster or something like that so you can blow out the line,when you think you have it cleared out,pour a half cup of hot water down the hole,if it goes down then it's clear,if not you have to blow it again until the water goes down,you can get a piece of copper wire like a ground wire from an electrical wire,slide it into the hole around 4 or 6 inches and cut it long enough so you can wrap it around the heater,when the heater comes on the copper will heat up keeping the drain from freezing up again.let me know how you make out
Nov 20, 2010 | Whirlpool Refrigerators
Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
Feb 05, 2010 | Freezers
Whirlpool refrigerator side by side freezer won't freeze
your over-load/contactor is defective, un plug it from compressor and shake it if it rattles its bad
Oct 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Have a whirlpool side by side refriferator estate model. Freezer won't get cold. Cleaned off underneath,fan is turning, Unplugged for awhile and plugged back in. Keep hearing clicking noise coming from...
Plastic box you're referring to contains the start components for the compressor. The clicking sound sound you hear is the protective overload shutting the compressor off because it won't start.
Two possibilities
1. The components inside the plastic box (cover) are defective and need replaced. You can remove them, by snapping off the cover and pulling them straight off. Most appliance parts houses will be happy to test them.
2. The compressor has failed internally.
Note: In my personal experience when dealing with whirlpool Estate models, 99% of the time it has been a failed compressor.
Oct 28, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Shuts down, interior lite on tho, plug back in and works - stops
You have a bad thermostat ( the piece where you adjust the coldness of the refrig ) . Once it gets to temp and shuts off , it will not tell the system to start again . Next time not running , tap on the t-stat . If it starts , this tells you the thermostat is bad .
Aug 25, 2009 | Avanti 651WT Top Freezer Refrigerator
Freezer keeps going down. brand new
Hi, did you connected plug correctly, green, (ground) black, (hot) white, (neutral) facing your (any) receptacle, pin on right, hot, pin on left, neutral, pin on top, ground, connect plug in like manner, check plug for correct wiring, or could be your motor overload relay, if your days are hot, overload relay will keep compressor off. put you thermostat to max, and try. or maybe you got low voltage, in building, common during summer months, low voltage sometimes damages, motor overload relay, and wiindings. check receptacle with digital multi-tester, check for accurate voltage, some motors won't start when, voltage drops to low, but fans would. unplug for an hour, and retry, then let me know what happened, then i could tell you exactly what's problem are. good luck.
Aug 11, 2009 | Refrigerators
Whirlpool Ref shuts down
It sounds like to me its your defrost timer(usually under 20.00) that is bad. Yhe are very inexspensive and easy to get to.You can purchase one AT YOUR LOCAL SEARS or online with your model # Glad to be of service
Jan 08, 2009 | Whirlpool Refrigerators
Freezer defrosting?
need more info is it a side by side what model does work and then shut down every thing sotp running exept lught then repl the thermostat but again i need the model tosee what type of thermostat it is
Oct 19, 2008 | Frigidaire FRS266ZDSB Side by Side...
Freezer keeps beeping and switching off
Next time this happens unplug it for about 10 minutes. When you plug it back up you should be able to turn it back on normally. This resets the board, much like restarting your computer. If the problem happens again, you will probably have to replace the board. You also want to make sure you have a good ground on the circuit and a steady power supply without too much fluctuation. Hope this helps.
Oct 04, 2007 | Whirlpool GS6NBEXR Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
152 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
