Question about SIIG SATA II-150 PCI (SCSA0012S1) Serial ATA Controller
I have a Dell Optiplex 755 SFF. I installed the SIIG SATA II-150 PCI card and the won't boot. The PC starts recognizes the new hardware and ask to press any key to continue but it just sits and do nothing. Remove the card and the PC boots without no issue. Any suggestion....
  • 102 Answers
Go into the bio's and turn the on board off
Posted on Jul 13, 2009
Pci ide controller drivers
Probably need new motherboard + win 7 or 8
Dec 12, 2013 | SIIG 2 Port eSATA II PCIe Pro - 2 x 7-pin...
I used my pc and turned off normally next day when I turn the power on the sign in screen I could not type anything the keyboard is not recognizing at all. I tried different USB port turn the system off...
It would seem that you are experiencing the Usual Dell USB controller failure. You will need a new motherboard or a PCI USB card fitted. The latter is the cheapest and the most reliable.
Sep 05, 2013 | Dell OPTIPLEX 980 SFF Desktop Computer...
How can I attach a Samsung hard disk HD080HJ/P to a Dell Optiplex 755 Core 2 Duo E4400 PC computer? There seems to be no master/slave settings on the hard drive.
Newer sata drives do not rely on the master/slave settings that old IDE drives used. Remove the old drive from the bad computer and plug it into an available slot in the new computer. Boot the new computer. Under My Computer/Computer the second drive will show up with the next letter available. Alternately you can buy an external hard drive dock that connects via usb and use that to transfer your files.
Dec 01, 2012 | Samsung (HD080HJ/P) 80 GB SATA Hard Drive
I had dell optiples 755 working fine, one day i
Do you mean your motherboard optiplex 755 not working?
If you mean it, and you have to do troubleshooting and found that the motherboard does not work, it is clear your motherboard problem.If you want to fix it you must change the motherboard to another (new)Your have to make sure that you change the motherboard that can support all the hardware on your computer, especially processor, ide slots, SATA, display card (if using) and ram your.If you choose a motherboard that can support all existing hardware on your computer, your computer should be fully functional.
I hope the tips provided to be helpful,
thank you
Jun 30, 2010 | Intel Desktop Board D845WN Motherboard
Is SATA ii compatible with Dell 755?
Yes the Dell Optiplex 755 desktop uses SATA II connections.
Jan 06, 2010 | Dell Optiplex 755 Desktop Desktop Computer...
What model 2 or 3 Port FireWire PCI card (low profile) Adapter?
I could not find any product that would fit a SFF case. The best suggestion i have for you is to get the riser card adapter that will fit standard PCI cards in the Dell Optiplex 7xx models. here is the link and partial discription.
The Dual Full Height Riser from Dell™ enables you to fit two PCI card in its slots. This product has been tested and validated on Dell systems and is supported by Dell Technical Support when used with a Dell.
http://accessories.us.dell.com/sna/products/Controllers/productdetail.aspx?c=us&l=en&s=dfh&cs=22&sku=430-2598&~lt=popup&~ck=TopSellers
I hope this helps you. Best Regards, -md
Nov 10, 2009 | Computers & Internet
Doesn't recognize new SATA disk. Have checked that disk is goodand can be accessed with a USB controller. Also, the SATA card BIOS does come up but shows no device on either channel.
Check all your bios settings, make sure SATA is enabled. Also see if the drive can be installed on another machine.
Make sure your OS version can support SATA also.
Good Luck.
Sep 16, 2009 | SIIG SATA II-150 PCI (SCSA0012S1) Serial...
Dell opti plex 755 ..its a company's computer and they have installed windows from another shop so now it boots well opens windows but the mouse and keyboard does'nt work it says found new hardware how can...
Windows usually supplies the needed drivers during the original installation of windows and should have enabled both devices. You may have to do a new install of Windows to fix.
Aug 19, 2009 | Dell Optiplex 755 PC Desktop
Configuring dell optiplex 755 sff
on the back of each device their should be a jumper on the right side next to where the ribbon cable plugs in. Remove the jumpers and replace them into the slot thats for "Cable Select" Their should be a picture on the top of the device if they aren't labeled. You can also put the jumper for 1 as "Master" and the other as "Slave"
Apr 20, 2009 | Dell 16X DVD±RW Serial ATA Internal Drive...
Dell Optiplex GX620 will not recognize firewire controller card
1394 drivers should be native to XP, you may be able to correct this by running an SFC scan
Take out the IEEE1394 card
Insert your Windows CD (if you do not have it order a backup from dell)
Exit out of 'install screen'
click Start
click Run
type 'sfc /scannow'
press enter
you should see a progress bar, when finished restart the computer
this compared critical windows files on harddrive vs CD, and replaces missing and corrupt files
Feb 03, 2009 | Dell 2-Port IEEE 1394 FireWire CardBus PC...
SIIG SATA II-150 PCI (SCSA0012S1) Serial ATA Controller Logo
366 people viewed this question
Top SIIG Computers & Internet Experts
Eric Sutherland
PC Tech101
Level 1 Expert
Are you a SIIG Computer and Internet Expert? Answer questions, earn points and help others
