Question about Spidem Trevi Anthracite Espresso Machine
No water for brew
I have a Gaggia Trevi and the whilst the beans are ground and squashed, the point at which hot water should dispense does not happen. The machine will purge with steam OK and there is very hot water in the steam dispensing pipe, it just doesn't want to come out into the brew group!
    President:
  • 1,618 Answers
Remove the brew group and clean the shower screen at the top. This might be blocked.
Posted on Jul 15, 2009
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
Saeco Grind and Brew model IDR 008 TG first the grounds were backing up and door not opening to go into basket, cleaned the dispenser per directions.. now the beans do not even grind at all nothing is...
Your grinder needs cleaning- maybe oily beans got used and/or storing beans in refrig/freezer? Both are a problem for grinder. Also, grinder should not be set to "fine"- it will definitely cause clogging and the situation you point out. ----------- The powder from the coffee grounds seems to get caked in the grinder. The only way to get it out is to run hot water into the little opening where the grounds funnel into the filter basket. --------- This will help.Thanks.Helpmech.
Aug 25, 2011 | Saeco Vacuums
There is no water coming out of the machine at all. No error light come on but when you go to make a coffee with beans or pre ground it goes through the process but just dry coffee comes out. Also no water...
For the steam check the end of the nozzle to make sure it is not blocked.
For the coffee run a coffee using the pre ground method but without coffee grounds, if water comes out then grinder is too fine, if no water remove brew unit and clean top shower screen, you might have to clean tube leaving from shower to discharge.
Aug 29, 2010 | Gaggia Syncrony Compact Coffee...
Ground coffee will not dispense
The beans are hanging up in the hopper and not falling down into the grinder...... wiggle it, give the beans a push, or go to a bean that is not so sticky....
May 29, 2010 | Gaggia Titanium Espresso Machine
Spidem Trevi Plus coffee is not being dispensed.
The grind chamber is blocked, remove the beans and brew unit then clean the grinds chamber, then adjust the grind 2 numbers coarser and try again.
Nov 05, 2009 | Spidem Trevi Digital Coffee Maker,...
Gaggia machine sounds as if it keeps grinding but no beans are getting through the grinder. I have cleaned machine completely, emptied the beans, opened the grinder to the biggest setting and still no...
The grounds chamber/gate might be blocked you will have to clear it out. Remove brew unit and find discharge for grinder, then push gate back and clean.
Aug 25, 2009 | Gaggia Syncrony Espresso Machine
Gaggia Titanium dumps ground coffe inside unit
Hi
You have 2 knobs in the bean hopper. The small one is set to the most positive. Turn it back 1 click from the plus and that should take care of your problem. When you have a clean brew unit it will make the first coffee but a little coffee is left in the brew unit and when it tries to make the second coffee a full charge and the little that was left cause an over charge, and dumps the coffee without making anything.
Jun 17, 2009 | Gaggia Titanium Espresso Machine
Spidem Trevi Anthracite Espresso Machine Logo
214 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
graybeard32301
ray gallant
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
