SOURCE: sir plzzzzzzzzz unlock phone imei
Please do read the ENTIRE PAGE prior to attempting to enter your codes
Nokia Unlock Codes Generated For Nokia 2610
These Nokia Unlock Codes are Generated For Nokia 2610 with IMEI: 011664009968298 (DCT 4) Locked to Provider TELCEL in Mexico and will only work with this phone!
#pw+937932455551546+1#
#pw+992302617025414+2#
#pw+257235174554445+3#
#pw+106064622452073+4#
#pw+093103111103414+5#
#pw+713440735156652+6#
#pw+383136406163440+7#
How to Enter your Unlock Codes
Recommended CODE :#pw+383136406163440 +7#
1.Remove SIM CARD !
2.Type #
3.Then press the * key 3times (you should get a "p")
4.Then press the * key 4times (you should get a "w")
5.Then press the * key 2times (you should get a "+")
6.Then enter: 383136406163440
7.Then press the * key 2times(you should get a "+")
8.Then enter: 7
9.Enter: #
SOURCE: code for unlock lg cu720 imei number is 011332001112261
Hi, you can unlock it with the following service that provides factory unlock codes for your phone model: http://www.fastgsm.com/en/lg/lg/cu720-shine/unlock-code-usim-locked
Hi
You can get the status of your handset from here:
http://www.amta.org.au/pages/amta/Check.the.Status.of.your.Handset
but generally speaking if you need a PUK code, then this is usually only available from your Service Provider as it is linked to the SIM card as explained here:
Mobile PUK codes how do find my PUK code
Hope this is helpful, if so would you please register that with Fixya
Cheers
