Question about ASUS WL-500W Router (WL500W)
With no security I can log in. When i put in
With no security level I can log in. When i put in security WPA i can no longer log in.
    Scholar:
  • 132 Answers
Do you have any security setup on the router? Is it configured for WPA? If not, then that's why you can't login.
If so, if possible, reset the router and reconfigure it. Make sure you have the updated firmware first for the router.
Posted on Jul 13, 2009
Can you help me setting up a password for my wi-fi connection using netgear router
How do I secure my network?
Log into your router using the "How do I log into my router?" instructions earlier in this article.
  1. From the left-hand menu, select Wireless Settings from the Set Up section.
  2. In the Name (SSID) field, enter the network name you want to use.
  3. Under Security Options, select a security encryption level. NETGEAR recommends WPA-PSK + WPA2-PSK for the best protection.
  4. In the Passphrase field, enter your chosen network password.
  5. Click the Apply button to save your changes.
For more details, see Securing Your Network: WPA+WPA2 (Recommended).
How do I change or reset my wireless network password?
Log into your router using the "How do I log into my router?" instructions earlier in this article. From the left-hand menu, select Wireless Settings from the Set Up section. Enter a new wireless network password into the Passphrase field under your security selection and click the Apply button to save your changes.
Jun 05, 2011 | NetGear WGR614 Wireless Router
Have a router but not software for linksys, have reset the router but don;t know how to put in new password
Welcome to fixya
No proplem you don't need a software cd to secure the router. Please follow the steps
Click the below link
http://192.168.1.1
Now it will ask for username and password
Enter username = ( blank) and password = admin
If you can't login using this credentials then you will have to reset the router
If you logged in . Then click on Wireless > Wireless security
On this screen select
Security Mode : WPA Personal
WPA Algorithm : TKIP
WPA shard Key : "enter a password here"
Group Key Renewal : set to default
Click on save settings. After that restart router .
Now your wireless network is secured and you will have to type the WPA shared key inorder to connect to router when it prompts
Thanks
Vote me If it helps
Feb 07, 2011 | Linksys Wireless-G WRT54GS Router...
Whats a wpa key? I have tried connecting to my router on my wireless device and my wireless device ask's for a wpa key? is it the same as a lan key?
WPA <<===>> WIRELESS PROTECTED ACCESS
You need to use an Ethernet cable to connect a computer to the router, and then access the web-server inside the router, and then run the "Wireless Networking Setup Wizard". When you do, you will set:
* the SSID ("network name") -- pick anything you prefer
* the encryption-level (hint: use 'WPA')
* the password for the network -- pick anything you can remember
Then, from a wireless device, do a "View Available Wireless Networks".
Select the SSID, and enter the password, to make a connection.
Feb 01, 2011 | D-Link DIR-615 Wireless Router
I want to put a code to prevent other people using my internet
Please reset your Router or Modem-Router to factory defaults by keeping the reset button pressed for 10 seconds while the router is powered. Then, connect the router to the modem, and connect a computer to the router with an Ethernet cable. Run the Setup Assistant on this computer. The software is not strictly required to configure the Router or Modem-Router, you can also use the built-in web based configuration tool on http://192.168.2.1.
Then in the user interface find BASIC.From there in th Wireless Network Name put a name for your network.There are three wireless security modes, including WEP, WPA-Personal, and WPA-Enterprise. WEP is the original wireless encryption standard. WPA provides a higher level of security.Use WPA-Personal and in the Pre-Shared Key :use a strong mix key.
Nov 15, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Lost paperwork to my berklin wireless router, need to know how to put a security password to log on. i live in an complex and there are some people i believe are hacking in. my computer is new and running...
Hi here is the answer if you want to setup wpa/wpa2 security then follow the below seps
1. Connect the computer to one of the four LAN ports on the router.
2. Open a web browser on the computer.
3. In the address bar of the web browser, type http://192.168.2.1
4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
5. Click on Security in the left-hand column under the Wireless heading.
6. Use the drop-down menu and select "WPA/WPA2-Personal (PSK)".
7. Select either WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2 as your Authentication; doing this will set the Encryption Technique automatically.
8. Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length. Note: The PSK (Pre-Shared Key) is case-sensitive ("A" is different than "a").
a. Unchecking the Obscure PSK box will allow you to see the security key that has been typed.
9. Click the "Apply Changes" button to save the settings.
Any/all wireless computers that connect to this network will be required to have this Pre-Shared Key (password).
Sep 26, 2010 | Computers & Internet
I want to put a password in to secure my wireless
You need to log into the wireless router either by a computer that successfully connects wirelessly or by physically connecting with an ethernet cable. Once connected, log into the router by open a web browser (Internet Explorer, Mozilla Firefox, Google Chrome, Apple Safari), and typing the router's address (usually 192.168.1.1 or 192.168.0.1) into the Address (or URL) line. The default usernameand password is usually "admin" & "admin" or "admin" & "password". Once successfully logged in, look for a tab or link that says "Wireless" or "Security". You'll be able to change whether security is enabled or disabled, and the password associated with it. Your security options are WEP or WPA (or WPA-PSK). WPA-PSK is the most secure, but WEP is also an acceptable choice. Select the security option of your choice and either enter text into the passphrase generator or choose your own password and type it into one of the security key text fields. If you use a password that is not a plain english combination of letters and numbers, be sure to write it down so that you can enter it as needed on other wireless devices that need to access your router (ie-pda phones, game consoles, laptops, desktops, etc). Be sure to save changes so that the security settings and password is saved.
Let me know how you make out.
Aug 18, 2010 | D-Link AirPlus DI-524 Wireless Router
How to lock d-link wireless so that no one can use my internet
Hello you have different level of security on it.
If it is open and without any security surely others will pirate and hack your Network system.
You can log onto the default IP is http://192.168.0.1
Specify user name and password for your router, the default is `admin' (optional) and password is blank (nothing). or at times it is ' admin '
There are 2 common mode of security that can be enable
1st is :WEP Encryption
2nd is : WPA-PSK Encryption
The wpa-psk is most stable and secure network
You can also use 128 bit encryption password
Hope this might help you
I am attaching link for manuals and downloads of the dir 300.
First link:
http://www.dlink.com.au/tech/Download/download.aspx?product=DIR-300&revision=REV_A&filetype=Manuals
Second link:
http://support.dlink.com.au/Default.asp
If you need further assistance revert back
Regards
uttam
Feb 24, 2010 | D-Link DIR-300 Wireless Router
Need to enable security -- had a power failure -- the computer with direct cable connection has internet access, but my laptop with a wireless connection no longer works -- says the network "is unsecured...
Log in to the router, check Wireless settings, Security is in the same area. I find that WPA-PSK[TKIP] is the easiest type to use, as you can use pretty much any sort of password longer than 7 characters. This can be done with the wired connection.
Nov 09, 2009 | Linksys Wireless-G Broadband Router
I would like to reset WPA key code
First, log on to the Router using the username and password.
Then, go to the wireless settings and reset the WPA key.
Next, click Apply.
Oct 11, 2009 | Computers & Internet
How do I enable wpa encryption? I have an
To set up the correct security protocols for your router:
1 Click Control Panel > Device Security.
2 In the Login User ID field, enter your User ID. Create an ID that contains multiple casesensitive
characters as well as numbers. It cannot be longer than 64 bytes.
3 In the Login Password field, enter your Login Password. Create a password that
contains multiple case-sensitive characters as well as numbers and symbols like “_ + )”.
4 Re-enter your Password.
5 Click Apply.
6 Once the settings have been accepted, click Restart and log back into the
Configuration Utility using your new User ID and Password.
7 Select Wireless > Basic.
8 Change the SSID to a user-friendly name and click Apply.
9 Navigate to Wireless > Security.
10 Select WPA-PSK from the ESS Authentication options.
11 Select TKIP from Encryption Status options.
12 Click Apply and then click Restart. Your wireless security configuration is now
complete.
Mar 26, 2009 | Arris WR850G Router (DHWR850G)
Open Questions:
ASUS WL-500W Router (WL500W) Logo
106 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
