Question about Welding Tools
Not a mig a 225 amp lincoln weldanpower just a light spark, 240 volt not working either,but sometimes it will work for a short time ,just need a wiring diagrahm and some resistance numbers or some one who knows what excites them there is no capacitator that I can find if you say there is one tell me where it is located motor goes fine [stick welder]
  • 33 Answers
Check the brushes
Posted on Jul 21, 2009
What type of switch/Trigger wood i need for my mig 125 volt input 25 amp input/79 amp out lincoln quick weld
Check repair manual. Try ebay you may find a replacement. Or a site thefind.com. Otherwise your welding supplies store.
Mar 08, 2015 | Lincoln Welding Tools
Lincoln hd 140 barely sparks
Try switching the a,b,c,d back and forth a couple of times a corrosion builds up and causes a week contact so there isn't enough voltage to work . This has happened to me a couple of times . The first time the fan was running and I had no wire feed action and then a local repair guy told me that corrosion is very common with the portable Lincolns . You shouldn't even have to take it apart to clean it just switch it back and fourth and that does the trick. Good luck.
May 06, 2014 | Lincoln Electric Lincoln Easy MIG 140...
My wire feed welder wont slow down. I was welding some thick galvanized pipe and went to turn the wire feed down and it didn't work
the speed feed rheostat(control) is shorted or you've got a short on the board if it has one. Hopefully just your switch. Check for a short from the switch to the drive motor. Remember, electricity can and will kill you. Be safe
Bryan
Nov 04, 2013 | Lincoln Electric Lincoln Easy MIG 140...
I have the lincoln 180 my wire is being fed but not getting any spark any ideas?
First make sure you have a good ground clamp and the line well tight to the machine. This problem is a common one.
Jan 07, 2011 | Lincoln Electric Lincoln Easy MIG 180...
Ave a power mate 225 amp 240 volt welder that wont arc
Sounds to me like the Power Controller has gone bad. These are a real tricky, dangerous, things to fix yourself, I recommend that you call the service rep, for Power Mate,and cut your losses.
Feb 24, 2010 | Welding Tools
I have a brand new lincoln 180 mig welder when i hooked it up to 240 volt power it was feeding the wire just fine but when i tried to weld the wire would just stick , so i checked the power and found i was...
Have you tried it on another outlet, say at a friends' house, etc?
Reset button on the welder tripped? Double check the breakers and all connections. If it was working before, it should work now. Try some different breakers to check for good juice. Good luck!
Feb 16, 2010 | Lincoln Welding Tools
Fan noisey and switch broken
go to this site link. look at the bottom right of the pdf page - 30 amp 240 volt toggle switch
http://literature.puertoricosupplier.com/~Pending~/PH8754.pdf
Oct 23, 2009 | Lincoln Electric K1170 AC-225 Stick Welder
LINCOLN 225 WELDER OLDER MODEL ABOUT 1985. 16HPENGINE. AFTER GETTING GOOD AND WARMED UP IT STARTS MISSING SOMETIMES BACK FIRES EVENTUALLY DIES. REPLACED COIL REBUILT CARB ,NEW FUEL FILTER AND LINES....
check plug and wire. you will want to do a compression test while you have the spark plug out and make sure you have no blow-by that will cause it to miss.
Oct 08, 2009 | Welding Tools
Century mig welder. The wire speed is spinning at max speed as soon as the machine is turned ON. Will only stop when machine is OFF.
My Century 225 mig has lost its power ...with adjustments to max it leaves a high weld deposit and low penertration.
What is the fix ?
Aug 14, 2009 | Lincoln Electric LE 83180 Century...
The wire feed on my welder will not work.
Maybe you can get lucky like I did . Some times the acr volt selector switch gets corrosion in it and wont let the circuit board know to send power to the wire feed motor. You can cycle this arc volt. switch in my case it is the a,b,c,d,e, switch back and fourth a few times and this will brake the corrosion and your wire might feed again as mine did . This corrosion build up happens from not using and or sollecting the switch much usually on a welder at hm that gets very little use. it is common good luck .
Jul 24, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Welding Tools Logo
320 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
