Question about GE GSH25JFR Side by Side Refrigerator
Clicking noise on GE Refridgerator
I'm responding to osmium2's answer regarding a clicking refridgerator (4/21/09). Our refridgerator (GE GSH25JFRE WW - almost 3 years old) clicks for 5 to 45 minutes prior to the motor starting. Also the controls on the door all stopped working (the lights in the freezer dim if you press the dispenser and a couple of times such attempts shorted out the fridge altogether and I had to unplug and plug back to get it started). I checked capacitors C29 and C30 and they were in fact bulged at the top as osmium2 had described. I'm not an electrician but would like to attempt the fix myself. Where do you get such capacitors (how do you describe them to the retailer) and how do you install a capacitor on a board (take it out and put it in)? Thx - Jay
SOURCE: Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Posted on Sep 07, 2007
  • 87 Answers
SOURCE: GSH22JSRE SS not cooling
I would strongly advise seeking a competent fridge guy. If it is the compressor (which sounds like a distinct possibility) they should be able to identify it very quickly. They would then be able to give you a cost on replacement. Alternatively you could try throwing it back at where you got it from and see if there is an extended parts only warranty. Some manufacturers now have three or even five years warranty on major components (ie compressors). Although there is no guarantee of this, its always worth a try, you might get someone sympathetic to your plight, due to the young age of the cabinet. Hope this is of some if not limited use.
Posted on Sep 11, 2007
the dr
  • 447 Answers
SOURCE: Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Posted on Dec 02, 2007
SOURCE: PDS22SBSALSS Clicking Noise/ Temperature Control Panel
It is possible to change out that relay...if your unit has one. This is usually a small plastic box on top of the compressor...but not a round tubular thing...which is the start capacitor. Just make sure you are careful...take out the plug. If you're messing with the has terminals which do contain hazardous voltage. Discharge with a screwdriver across the terminals. Generally, the relay is the thing which gives the symptoms you're facing. Change both and you've probably got it...they're cheap. Not all models have both.
Posted on Feb 06, 2008
  • 1606 Answers
SOURCE: ge gss25ifrf ww side by side fridge clicking
Sounds like the main control board is bad . Pt # WR55X10656 . This board is located behind the 8 " X 10 " , panel just above the compressor compartment . The compressor relay , is what you hear clicking , cutting the compressor , on/off . Even the dispensor board , is operated by the main control board .
Posted on Sep 19, 2009
Where is the power button on ge arctica refridgerator model PSs26mgtb/ww
There isn't a power button that I know of on that model I know that it will stop running if the control board shorts out
GE Refrigerator Main Control Board WR55X10942
Aug 06, 2016 | GE Refrigerators
Why does 15 amp 250 volt fuse in my lg refridgerator keep blowing
the 15 amp fuse is blowing because the current draw to run the compressor exceeds 15 amps
that problem could be from a failed start/ run capacitor or a failed compressor motor (I am betting on the capacitor)
the best answer is to get a fridge technician to check it out as the capacitor is a cheap fix while the compressor unit is as costly as a new fridge
Jun 25, 2015 | LG Refrigerators
My ice maker on the freezer side door stopped working so I changed out the motherboard CCA in the back of the refridgerator & it started working again but the water did not. I need to replace the...
Blake are you talking about the dispenser control board? The ice maker tells the water control valve to come on for the preset amout of time to refill the ice trays most times about 7.5 seconds. and filling ice maker with tap water will test icemaker. If water freezes and the ice dumps the signal is sent to the water control valve Click here=> WR57X10050 here is a service manual=> PROFILE ARTICA SERVICE MANUAL CLICK HERE Have questions you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE model number GTS18DBMBRWW keeps clicking but
its your RTX overload contactor on the compressor body,getting weak and trying to hold contacts in to power the unit
Dec 16, 2009 | GE Refrigerators
The compressor is not running and there is a clicking noise coming from the circuit board panel on the back of the refridgerator
You have to replace the main control board . The clicking is the compressor board relay , which the only repair , is to replace the main board .
Sep 11, 2009 | GE Refrigerators
Not cooling at all
refridgerator not cooling making clicking noise from back
May 03, 2009 | GE Profile Stainless Bottom-Freezer...
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
GSS22KGMC WW side-by-side refridgerator not cold anymore
I have no idea to this day, what caused the complete lack of cooling in my freezer and refridgerator. However, it seems to be working fine now. All I did was turn the compressor and fan totally off, let it rest for a few minutes, and then turn it back on. It seems to have "re-booted the system, and now everything is working normally. The ice-maker is once again making ice! It has been three days or so now, and so far, so good!
Dec 25, 2008 | GE PSS26SHRSS Side by Side Refrigerator
GE GSH25JFR Side by Side Refrigerator Logo
221 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
