Question about Getac Computers & Internet
I just purchased a GTAC P470, how do i release the dvd drive from the locked position
  • 130 Answers
Have a look for a latch somewhere?
If not look for a hidden screw.
-Tom.
Posted on Jul 13, 2009
Tip
Troubleshooting Laptop Optical Drive Issues - CD/DVD Not Ejecting
Symptom
My laptop's CD/DVD tray won't eject when I hit the Eject button.
Diagnosis & Solution
If this happens while the operating system is running, there is a possibility that the drive may be blocked or disabled in software. In order to eliminate this possibility as the root cause of the problem, restart the laptop & hit the CD/DVD's Eject button. If your CD/DVD's tray did not eject, there is a possibility that the drive is not properly seated in the bay.
When the CD/DVD drive is not properly seated in its bay, it might not be connected to power. If the drive is in a swappable bay, try removing it & re-installing, & make sure that the release latch snaps to the locked position when it is installed. However, if the drive is permanently mounted, it shouldn't break free of its connector unless it is not secured in place. This can happen if the CD/DVD drive is secured with a single screw which was removed in an earlier repair & never replaced. The drive can function & stay in place for months without being secured, because it's a tight fit & the power/data connector tends to hold it in place. But occasionally, it might become loosely connected with the power/data connector.
If the tray doesn't eject even when the CD/DVD drive is seated properly in its bay, then the last resort is to power down the laptop & use the emergency release pinhole on the front faceplate. You can do this with the drive installed in the bay, but if it's the swappable type, it's easier to do with the drive out & on the table. Straighten out a length of a paperclip that's just thin enough to fit through the hole, & gently insert it. Listen for the release click & try to feel it through your fingers. When the tray releases, it may spring out half inch, or it may barely move at all, so you have to get a hold of the front of the tray to pull it out.
If a disc has come apart in the drive, either because it shattered or a stick-on label lifted off, getting all the bits out of the CD/DVD drive & getting it working again isn't a high probability, so don't test it with a disc of any value after attempting the repair. If it's an electrical/mechanical failure of the ejector mechanism, repairing it yourself isn't practical.
Please Vote for this Tip if you found it helpful.
M. Omran
on Oct 31, 2010 | Computers & Internet
The shift interlock button wont release the gear shift to go in park or drive
Its a simple fix - you just need to put your right hand underneath the dash, under the ignition switch with the stuck key, and feel around for the stiff transmission-shift-lock cable, and just giggle it about a bit. Try all directions, don't be aggressive with it; and eventually you will be able to turn the key to the LOCK position. Good luck
I took the cover off the steering column by removing 4 screws. (I had to remove the dash by removing 2 screws behind the Hood release and yanking the cover off. This is how you gain access to the two forward most bolts on the steering column cover.) From hear you should see the shift interlock on the top right of the sterring column. Pull the white lever to release the key lock. Turn the key to lock and remove your key.
I would then purchase a new interlock and replace it.
Mar 23, 2012 | 1999 Isuzu Rodeo
Dvd won't eject. It lights up flashing like wants to open. I tried to eject dvd every way possible ie., computer link, etc
All CD / DVD drives have a Eject Pin Hole. The only thing we need is a paper clip to use it
All we have to do is bend it at the first curve 180 degrees (straitening it out). Then take the second curve and bend it 90 degrees. Now we need to locate the Eject Pin Hole.
Laptop - Notebook CD / DVD drives:
The trays on laptops/notebooks are spring loaded, so all that is needed is to release the locking mechanism. You do not have to insert the paper clip as far as with a desktop CD / DVD drive, as you are not connecting to the gearing under the tray. Gently insert the paper clip into the Eject Pin Hole. Once you feel it make contact, gently push in and the tray will eject immediately. Once done, gently push the tray back inward until it locks back into place.
Desktop CD / DVD drives:
Gently insert the modified paper clip into the Eject Pin Hole until you feel it make contact with the gear underneath the tray. Firmly pressing inward, you will notice the tray to start to move out. Press inward until you have enough room to get your finger under the tray and then pull it out the rest of the way. If you can only get a small portion of the tray out, you can use the other end of the paper clip to gently pry open the tray enough to get your finger under it. Once done, gently push back the tray to the closed position. It will close firmly when the system is powered up.
Mar 14, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
Compaq cq60-419wm - my dvd/cd drive is not working, not even recognized as being there by the computer (not listed as a drive available under My Computer)
If it's not recognised, look for a little latch on the underside of the laptop that releases the drive completely. If you can manage to slide the whole unit out, push it back in firmly until the latch clicks into the locked position again. Power the laptop up and try again.
Nov 17, 2009 | Computers & Internet
Just purchased the windtunnel T series pet version...I cannot turn the carpet height adjustment knob to save my life. Is it locked somehow? or is there a way to get it moving?
with the vacuum in the upright position push the handle foward then reach foward and slide the lever to the proper position that also works to ingauge the power drive or to release the handle thanks hope this helps Don the Vacuum Doctor Alb N.M.
Nov 01, 2009 | Hoover U5753-900 WindTunnel Bagless...
Want to upgrade hp compaq nx6120
To upgrade a HP (Compaq) NX6120 you will require -
  • T8-9 mm screw driver
  • P1 Philips-head screw driver
Q.1. Increase the RAM size. (Can you please guide, what is the maximum size it can support w/o any problems & which make & model to buy)
A.1 To Upgrade the memory you require to purchase a
333 MHz, 200-pin, PC2700, DDR SDRAM SO-DIMM with the Maximum size of 2GB.
The memory can be purchased from any good local computer store as of 27/03/09 the price on Buy.com for 1GB stick was $47.99
Installation
Important Notes
When handling a RAM, all way hold the edge of the RAM, also use care to prevent touching the RAM on the motherboard. Touching the RAM could damage or destroy the RAM.
  1. Turn off the laptop.
  2. Disconnect any USB/Power cables attached.
  3. Slide the battery lock to the unlock position.
  4. Slide and Hold the battery release to the unlock position.
  5. Slide the battery out from the laptop.
  6. Loosen the captive P1 Philips-head screw that secures the memory cover to the bottom of the notebook.
  7. Using you fingers gently lift the memory cover from the edge of the laptop, at the finger groves on the laptop case and remove it.
  8. Push both arms outward simultaneously to release the expansion memory board to the spring tension position.
  9. Grasp the edge of the RAM and pull gently to remove it.
  10. Place the RAM in a static dissipative bag
  11. Take the Ram from the static dissipative bag
  12. Grasp the edge of the RAM and align it to the empty board receptacle.
  13. Gently press the RAM down to latch the arms.
  14. Slide the battery cover back into the clips on the laptop.
  15. Tighten the captive P1 Philips-head screw.
Q.2. Increase the Hard disc capacity. (Can you please guide, what is the maximum capacity of hard disc it can support w/o any problems & which make & model to buy)
A.2 The maximum hard drive all depend on the type of windows you will be installing and the chipset on the Laptop. The standard chipset for the HP NX6120 is Intel 915GM and does not any limit set
To found out what type of chipset is installed open Device Manager using the steps listed for your particular operating system.
  • Windows Vista: click Start » click Control Panel » click System and Maintenance » click Device Manager
  • Windows XP: click Start » click Control Panel »System icon » click the Hardware tab »Device Manager
  • Windows 2000: click the Start button » click Settings »Control Panel » double-click the System icon » click the Hardware tab » click Device Manager
  • Windows 95, Windows 98, Windows 98 SE, and Windows Me: click the Start button » click Settings » click Control Panel » double-click the System icon » click the Device Manager tab
  • Click the + sign to expand the System devices entry.
Look for the chipset name in a string similar to the following: "Intel® 955X Memory Controller Hub - 2774". In this example, the chipset is an Intel® 955X Express Chipset.
If the chipset is in the 800 range please visit Intel website to install Intel® Application Accelerator.
http://www.intel.com/support/chipsets/iaa/sb/cs-009293.htm
I have included a list below of all of the main operating systems with their HDD support
  • Windows Vista - 2TB,
  • Windows XP - 2TB,
  • Windows 2000 - 137,
  • Windows Me - 137,
  • Windows 98 SE - 137,
  • Windows 98 - 80,
If you are install any other Operating Systems please see to OS guide.
To Upgrade the memory you require to purchase a 2.5" (inches) IDE HDD also know as a 2.5" (inches) PATA HDD with the maximum size above.
HDD can be purchased from any good local computer store as of 27/03/09 the price on Amazon for 250 GB was $79.61
Installation
  6. Loosen the captive P1 Philips-head screw that secures the HDD cover to the bottom of the notebook.
  7. Loosen the captive P1 Philips-head screw that secures the HDD.
  8. Grasp the Mylar tab and pull the HDD toward the outside edge of the enclosure.
  9. Lift the HDD out of the bay to remove it.
  10. Place the HDD in a static dissipative bag
  11. Take the HDD from the static dissipative bag
  12. Place the HDD in to the HDD bay with the connectors match up to connectors on the in the enclosure
  13. Gently push the HDD toward the inside of the base enclosure until the connector is seated.
  14. Tighten the captive spring-loaded P1 Philips-head screw that secures the hard disk drive
  15. Slide the battery cover back into the clips on the laptop.
  16. Tighten the two captive P1 Philips-head screw.
Q3. Want to Install DVD writer. (Can you please suggest whether it supports it or not & which make & model to buy)
A3. Yes the HP NX6120 does support DVD write but unlike the another question the DVD drive must be the pre fixed to suit the HP NX6120.
A DVD can only be purchased from HP or at selected online store as of 27/03/09 the price on getpartsonline.com for a
Dual Format Laptop DVD±RW Drive was $99.99
Installation
  8. Remove the T8-9 mm screw that secures the optical drive to the base enclosure.
  9. Insert a paper clip or thin metal rod into the manual release hole on the front bezel of the optical drive and press firmly.
  10. Grasp the side rails of the drive tray to pull the optical drive out and remove.
  11. Push the drive tray back into the optical drive
  12. Insert the optical drive into the base enclosure until the connector is seated.
  13. Replace the T8-9 mm screw that secures the optical drive to the base enclosure.
Mar 27, 2009 | HP 378248-001 keyboard for Compaq nc6110,...
Acer Laptop DVD drive stuck in 'open' position
The solution turned out to be just pushing the DVD drawer in and popping it out a few dozen times. Probably not the best solution, but the DVD player works and it slides smoothly now.
Dec 25, 2008 | Acer (KV.16X04.007) DVD Drive
Acer Aspire 5920 DVD region locked!!!!!
Actually, the answer isn't nice at all. It's not the software, it's the drive itself. You can only change a drive's region 5 times before it is completely locked. I'm not sure if it's possible to flash the drive's bios and start from scratch, but I'd imagine if it were possible, you wouldn't want to do it yourself because it involved opening the drive itself.
That sad thing about this is that you cannot change the code again, that disk drive is completely locked now.
Sorry to be the bearer of bad news.
Caid.
Nov 21, 2008 | Acer Aspire 5920-6727 Notebook
Stuck disc drawer rca model drc8312n
If there is a tiny pin hole in the front a straightened paper clip does wonders. Simply insert to release the drawer. At least that's how it works on computers ;)
Mar 28, 2007 | RCA DRC8312N DVD Recorder/VCR
Computers & Internet Logo
79 people viewed this question
Top Getac Computers & Internet Experts
David Payne
David Payne
Are you a Getac Computer and Internet Expert? Answer questions, earn points and help others
