Question about Toshiba 42HL167 42 in. LCD Television
My tv goes off and on. When it goes off I can unplug it and start it. Sometimes it will stay on and sometimes it does not.
    President:
  • 563 Answers
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 13, 2009
Why does plasma TV have no picture?
What brand and model # is the tv? This is very important as far as researching your problem. You probably aren't the first or the only person with this problem. There are typically four to 5 boards including an x main, a y main, power board and others. Sometimes easy stuff like capacitors or fet's go bad and you can fix it yourself pending your soldering abilities. Sometimes whole processors go bad or entire boards and these need to be replaced. Sometimes people want to fix sometimes they want brand new
Jul 07, 2015 | Televison & Video
My Phillips 42PF7320/79 Flat Panel TV won't turn on, screen stays black but green pwr light is on, after a lil while the green light flashes a couple of times then goes off itself completely
This idea may be worth a try. Look at the buttons on your remote. If you see a button that is marked "TV" give that button a push and then give the "Power" button a push. Wait for a while! sometimes this takes a while to turn the TV on or off. You may have to do this a couple of times depending if the power was off or on when you started doing this. If you started with the set off, sometimes it takes a while for the set to turn on.
Jan 04, 2015 | Televison & Video
Magnavox 42 LCD 42mf438b/f7 turns on/off by itself sometimes screen goes blank tv unresponsive to remote
I have exactly the same problem with a Magnavox LCD 42", very similar model 42MF437B/37. I don't have a solution. If you unplug the TV and plug it back it starts working, sometimes for hours, sometimes for less than 5 minutes, before it turns off again. Does anyone have any real solution?
Jul 08, 2009 | SNK Magnavox 42MF438B/27 42 in. LCD TV
My Philips 20PT633 has started shutting off mid program.
Consult your technician there is a semiconductor problem inside your tv. Probably lose connection, and need to resolder.
Jun 08, 2009 | Philips 20PT633R 20" TV
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Tv not turning on from standby goodmans lcd 32"
problem is with power board, it seems a problem that is endemic to these sets, you can sometimes manage to reset by unplugging set for 30 mins repowering and sometimes it will come back on otherwise look at replacing board
Jul 23, 2008 | Televison & Video
Menu,sound problems
First thing is try to take out the batteries out of the remote control Then if the problem persist, unplug the set for a couple of hours if not over night. If that dosent work then check to see if any of the front panel buttons may be stuk .. If all of this was checked its time to call in a repairman as you have a microprocessor circuit or EEPROM fault or the five volts going to the reset is too low. Good Luck
Jul 26, 2006 | Philips 27PT6441 27" TV
Toshiba 42HL167 42 in. LCD Television Logo
351 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
