Question about Sprint Protege 475712 Phone
Need to know how to get phone off dnd
Phone was accidental put on dnd and we can not get it off.
  • 5 more comments
  • Anonymous Nov 27, 2007
    dnd won'turn off and cant't get ringer to work because of this.
  • cdpeplow Nov 27, 2007
    dnd won't shut off so ringer is inop
  • Anonymous Jan 30, 2008
    how do I turn on the ringer of the 900mhz cordless phone
  • Anonymous Feb 02, 2008
    dnd was put on phones. How do I fix it?
  • tlwalker Mar 04, 2008
    dnd is on my screen
  • bkskrony Mar 21, 2008
    my hand set reads 00:DND how do i remove this?
  • ert erter Mar 21, 2008
    my pohne is tuck on DND mode
    whenever I press the button to turn it off it rings incessantly!
    HELP!!! @_@
Thank you for your help
Posted on Mar 24, 2008
Press featrure 69 and feature again
Posted on Feb 02, 2008
How do you put phone off of DND?
Posted on Jan 28, 2008
Press dnd button twice, should work
Posted on Jan 14, 2008
I have an issue with my FWD/DND function. Until yesterday, I was able to receive "in" calls. Apparently I accidentally hit the FWD/DND button! At first I wasn't getting ANY calls (never used...
I don't know about a "user guide" but the Operating Manual would work wonders. http://www.public.carl.airpost.net/Pana/TDA/200_TDA_OM_06-121.pdf
The FWD/DND button has 3 steps of keypress, Off, FWD, DND. The idea is you press it until it stops flashing or being lit and you have nothing set. If that doesn't work, try Call FWD/DND cancel, *7100 on the intercom.
Carl
Mar 10, 2011 | Panasonic KX-T7633 Corded Phone
How do I put my phone on DND?
You get a chance for that to work next time :-)
Panasonic features are in the system, not the phone. If you have a TA series, from the phone, pick up the handset and press the FWD/DND button and dial 4#. (you may also dial 71 in place of pressing the button).
Cancel is 0# in place of 4#, but you also have CF to voice mail issues, where 1+VM EXT is all calls and 2 is BUSY/NA.
If you have a TD or TDA or TAW system, you get lucky, because the FWD/DND button works in 3 modes. For DND it's 7101 or *7101. The button will light with a solid red light and when you press it, it either flashes or goes off. The system gives you both FWD and DND settings.
Carl
Apr 05, 2009 | Panasonic KX-T7730 Corded Phone
Cisco ip phone 7940 does not ring for incoming calls.
It sounds like you have enabled Do No Disturb accidently. This can be turned on and off by pressing the DND softkey button along the bottom of the LCD display. You might need to press the 'more' softkey to display all options.
Jan 27, 2009 | Cisco 7940 IP Phone
Need to set up DND
You would have to have know the type of telephone system.
go into prog 39 and put code 498 on that port(000*015)
info@ameritelnj.com
Tony
Jan 16, 2009 | Toshiba DKT2020SD Phone
Function
If your main system cabinet (in some closet somewhere) is plastic, you have the NEC Electra Professional Level I system and the DND cancel procedure is <FNC>, 60, <FNC> when the phone is idle. If your main system cabinet is metal, you have the NEC Electra Professional Level II system and the DND cancel procedure is <FNC>, 69, <FNC> when the phone is idle. You can also press "42" while hearing intercom dial tone. The most common cause of accidentally setting DND is by dialing "40" while hearing intercom dial tone (Level II system).There is a slim chance your main system is not the Electra Professional series. If either of the above do not work, let me know.
Jan 15, 2009 | NEC ETW 16DC-1 Corded Phone
Features
Not sure how you set this feature but here is the solution:
To set DND you would have pressed your feature button, 60,and then feature button again (if you were forwarding to another extension you would have had to enter an extention after 60 and then the feature button. This sets your DND or call forward.
To eliminate press feature, 69 and then feature again this should cancel the call forawrd or do not disturb.
Oct 01, 2008 | NEC Dterm DTP 16D-1 Corded Phone
"Do Not Disturb"
On the base unit, press the "Do Not Disturb" button. This button is located on the front right corner of the base unit. The button light should turn off indicating that the DND feature is deactivated.
Feb 05, 2008 | GE 25952 Cordless Phone
Sprint Protege 475712 Phone Logo
724 people viewed this question
Top Sprint Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Sprint Lands Phone Expert? Answer questions, earn points and help others
