Question about Bosch WFMC 3200 Front Load Washer
Water after wash cycle is completed and machine clean ater appears in tub sometimes a half gallon up to a gallon
  • 213 Answers
Re: water
You need a cold or hot water valve. one of them is not closing all the way after the cycle is done. turn off cold water at wall, if no water appears you know its the cold water valve. if water does apear you know its the hot water valve
Posted on Nov 20, 2007
0 characters
3 Points
How to Remove Mold and Mildew from Front Load Washing Machines Today...
How to Remove Mold and Mildew from Front-Load Washing Machines
moldy-smell-washing-machine-1.jpg Front-load washing machines are notorious for collecting mold.
I've had my front-loading washing machine for about four years, and it has some great advantages - it's quiet, fast, uses less water and detergent, and gently tumbles (rather than yanking) my clothes. In general, I've been so pleased with it that I was shocked one day when I opened the door and was nearly knocked unconscious by a fetid blast of moldy-smelling air!
How could a machine that's so wonderful, suddenly turn so horribly smelly?
Gaskets hold moisture.
The answer is in the way the machine is designed. Front-loading washing machines have watertight, airtight doors that seal with a rubber gasket. That rubber seal traps moisture in the machine and also provides the perfect nooks and crannies for mold and mildew to grow.
Top-loading washing machines, on the other hand, have a rather loose fitting metal door that easily allows the tank to dry out between loads.
The problem isn't helped by our laundry preferences. High sudsing detergents and liquid fabric softeners leave behind residues and films that invite mold growth. Cold-water cycles and mild, eco-friendly detergents don't quite blast away residues like their environmentally-unfriendly counterparts.
So, to keep mold at bay, front-load washers need just a bit more maintenance than top-loading machines.
How to Get Rid of Mold and Smells in Top-Load Washers
If you've got a stinky front-load washing machine, here's how to get it smelling fresh again:
    moldy-smell-washing-machine-3.jpg Cleaning gasket on washer.
  • Clean Gasket: Use a rag or towel to clean the rubber door gasket on a front-loading washer with either hot soapy water or a spritz of mildew cleaner. Make sure to wipe underneath and around it as well. Be prepared for some slime and gunk, and possibly a stray sock or two!
  • Clean Dispensers: Remove the detergent dispensers and give them a good scrubbing. If they don't come out, clean them as best you can, using a bottle or pipe cleaner to reach back into the crevices.
  • Run Cleaning Cycle: Next, run an empty wash cycle on the longest, hottest water setting (or a tub-cleaning cycle, if you have it). Add one of the following directly to the wash tub:
    • 1 cup of bleach.
    • 1 cup of baking soda.
    • 1/2 cup of powdered enzymatic dishwasher detergent (such asCascade Complete).
    • A commercial residue-busting washer cleaner (such as Affresh orSmelly Washer).
    moldy-smell-washing-machine-4.jpg Commercial cleaning pellets.
  • Repeat Cleaning Cycle: If the problem persists, repeat the cleaning cycle and consider trying a different additive. It might take several cycles to get the smell out.
  • Professional Help: If you've tried every way to clean your front-load washer and it still smells, you may have mold growing back behind the drum, or possibly a clogged drain or filter. A qualified repair person can dismantle the machine and clean it for you, or you can unplug the machine and carefully explore and clean it yourself.
Preventative Maintenance
Once your machine is clean, follow these tips to keep it that way:
    moldy-smell-washing-machine-5.jpg Allow washer tub to dry.
  • Air It Out: If possible, leave the door of the front-load washer cracked open to allow it to dry thoroughly between cycles. However, you shouldn't do this if you have children or pets who could be tempted to climb (and possibly become trapped) inside the machine.
  • Remove Loads Promptly: Be sure to remove wet clothes as soon as the cycle is finished. Set your washer to beep when it's done, so you don't forget.
  • Choose Detergent Wisely: Choose low-sudsing detergents specifically made for high-efficiency (HE) machines. When possible, choose powder over liquid; liquid detergents are usually higher in suds.
  • moldy-smell-washing-machine-6.jpg Clean washer dispensers.
  • Use Less Detergent: Read the labels and use no more than the amount recommended for each load. Experiment with using less detergent, until you find the minimum amount necessary (sometimes just a spoonful) to get your clothes clean.
  • Avoid Fabric Softener: Liquid fabric softeners leave residue that contributes to mold in front-load washers. Instead, use dryer sheets or dryer balls to soften your clothes.
  • Dry Gaskets: Use an old towel to wipe around and underneath the door gaskets and the inside of the door on front-loading washers. Ideally, you should so this after every cycle, but at the very least it needs a periodic wipe down to remove any water or mildew trapped in the folds.
  • Use Bleach: About once a month, run a hot water bleach cycle. I usually take the opportunity to throw in work towels, fabric shower curtains, and muddy gardening clothes, along with that nasty gasket-cleaning towel.
Good Luck
Feb 27, 2015 | Washing Machines
How to clean a wash machine
Regularly clean the top and door of the washer to prevent the buildup of dirt and detergent. When you wash very linty materials, remove lint from the tub after removing the laundry. Soap deposits may cause laundry to smell bad. To solve this problem, fill the tub with water and add 1 pound of water softener or 1 gallon of white vinegar; then run the machine through the complete wash cycle. If the deposits are really bad, wash the inside of the tub with a solution of household ammonia and mild detergent. Rinse thoroughly and wipe the tub with liquid bleach. Caution: Rinse the tub thoroughly before wiping it out with bleach. Ammonia and bleach can combine to form a very dangerous gas.
Finally, run the machine through a complete wash cycle before you put any more laundry in.
on Jan 16, 2010 | Washing Machines
Brovos Maytag Showing a Error F1 is this an easy fix?
The code is caused by a water sensor. You can temporarily just dump about a half gallon of water into the tub before adding the clothes, and then have another half gallon for mid cycle. This stops the code from popping up. Try the half gallon thing and you will see.
I would try to run a few loads of towels with just water (no detergent or anything) to try and flush out any excess detergent residue you may have. I don't know if you are able to set your own water level on this machine, but if you are, I would just run an empty load or two.
Hope this helps...
Jul 23, 2011 | Maytag Bravos MTW6600T Top Load Washer
5 month old Whirlpool Cabrio washer has moldy smell. Tub seems to empty well. Any ideas?
Smelly washers are common. Cabrio washers are HE and therefore use less water. By using less water, it doesn't rinse ITSELF as good as an older non-efficient machine. Things you can do to solve the problem. Buy a cleaner from Whirlpool called Affresh. It's 3 tablets that you throw in the washer without clothes and run it on the longest heavy duty cycle possible. Use the hot water setting and the longest duration. For existing smells use all 3 tablets. Then use 1 tablet every month to prevent reoccurring odors. You can also try the same type of cycle on hot water with a half of a gallon of bleach in the tub, or try it with a half of a gallon of vinegar. One of the 3 should do the trick.
May 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Brown sludgy marks and particles on clothes.
fill the tub with only water! use pinesol and bleach! half a gallon of each run through wash cycle 3 times before ever letting it spin out! then complete all cycles that should do it! if not them you need to remove and clean under tub and re install
Jan 13, 2010 | Hotpoint Washing Machines
I have a strange odor
It is normal for all models of washing machines to have a gallon or two of water left inside the bottom of the washer and in the drain pump. This is not the cause of odor. The smell is being caused by residue left on the inside of the plastic outer tub.
The best way to clean a stinky washer is to use a washer cleaner that is able to be used with clothing in the washer. The added bulk of the laundry will raise the water level to include the splash area 3-5 inches above the normal waterline. This splash area always has the worst buildup.
After the odor is gone you'll need to change washing habits to keep it away.
Oct 19, 2009 | Washing Machines
Incomplete wash cycle.
It sounds as if you have something acting as a flap causing the restriction. You should take the hose that leads from the tub to the pump off and see if there is anything just inside the tub. I have noticed that alot times you could have a coin that blocks the opening. You may have to remove the inner tub to remove anything in there
Dec 30, 2008 | Maytag SAV3655A Top Load Washer
Removal of washing machine soap dispenser - Indesit
hi sue,
i've check the web and i found thatt you just have to pull the soap dispenser towards you. if some clips are rising when you pull it, gently press it down and continue pulling it.
tnx 4 using fixya,
Sep 13, 2008 | Washing Machines
Washing machine filter for roper top loader
it has a self cleaning filter mounted under the tub. if you want to clean out the tub and filter thoroughly then:
  • run a cycle with no clothes using hot water and a gallon or two of bleach.
  • after the tub has filled up add a teaspoon or less of dish liquid like palmolive. this acts like a surfactant for the bleach.
  • make sure you also run an extra rinse cycle to make sure you have all the bleach out of the machine before putting clothes in.
Aug 04, 2008 | Roper RAS8445KQ Top Load Washer
Bosch WFMC 3200 Front Load Washer Logo
80 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Richard Roth
Richard Roth
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
