Question about Symbol LS2208 Handheld
I would like to transmit EAN-13 bar code without check digit, but closed by ENTER.
    Scholar:
  • 74 Answers
If you would like the LS2208 to transmit only the first twelve digits of an EAN-13 barcode followed by an enter you will have to write an Advanced Data Formatting rule using barcodes from the LS2208 Product Reference Guide found here: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=114420371&stateId=1%200%20114410810
The barcodes you will print and scan in the order they are listed are:
Begin New Rule
EAN-13 (from the Critera pages of the ADF section)
Send Next 12 Characters
Send Enter key
Save Rule
If all other barcodes require an enter key make sure you scan Scan Options, Data Suffix, Enter (from the same manual or from the Quick Start Guide) before scanning the ADF rule above.
Posted on Jul 13, 2009
  • aksudhakar Feb 14, 2011
    this is not working
  • Symbscanners Feb 14, 2011
    If this is not working your barcode may not be an EAN-13. If the barcode contains 13 characters and you would like to drop the last character try dropping the EAN-13 statement from the rule listed above.
UPC code85948500222
Hi. I'm not sure if this will help you, but I found this website:
UPC Database Item Lookup
According to this website:
"Enter the all digits printed on the UPC bar code, including any numbers to the right or left of the bar code itself, even if they don't line up with the main row of numbers. This should be 13 digits for an EAN/UCC-13, 12 digits for a Type A UPC code, or 8 digits for a Type-E (zero-supressed) UPC code. Anything other than 8 or 12 digits is not a UPC code! (And just because it's 8 or 12 digits doesn't mean it is a UPC.) You must enter every digit here.
If you have a barcode scanner that outputs plain numbers, you should be able to use it to enter the UPC number here."
So, apparently you need more digits to complete the bar code #. But if you have the full barcode, you should be able to enter it on the website linked above, and find the image of the frames that you are looking for. I hope this helped. Thanks!
Oct 23, 2014 | Datalogic QuickScan QS6000 Plus Bar Code...
Honeywell
Scan "do not expand ean-8 to ean-13" in your programming guide.
Jan 18, 2013 | Honeywell Voyager 1200g Barcode Scanner...
How do i program the LS2208 not to send the EAN-13 check digit and send ENTER key / carriage return
LS2208 needs a ADF Rule added to it to send the "Enter" on the end of all code. Scan123 is also an easy solution. Download it if you don't have it. Basically in Scan123 select the type of scanner you are working with, then select the ADF Rules tab. Make a new rule that says ANY Code, Any Length, and then under actions I put Line 1 "Send all that remains" Line 2 "Send Numeric Key <Enter>. Save the rule. Then select the Symbologies Tab, Select UPC/EAN Tab and select what options you want. Then select the Print Icon, Tick Symbologies , ADF Rules & Programming BarCodes boxes. Print them out and then scan them into your scanner. Job done
Feb 15, 2011 | Symbol LS2208 Handheld
Cannot find a way to configure ls2208 to perform expansion of upc-a to ean-13 barcode. I need this characteristic enabled in order to transmit a complete ean-13 barcode when it starts with a "0",...
http://www.fixya.com/support/t1857832-need_convert_upc_barcode_number_ean_13
have a look there. it will explain.
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
Oct 01, 2010 | Symbol LS2208 Handheld
I have an IT3800 scanner and use it in a gift shop. My products have "regular" barcodes, those with 5 digits added and ISBN barcodes. My scanner stopped scanning the extra 5 digits. I went to the IT3800...
What you need is to turn on Digit Addenda for the types of barcode you are trying to scan. Here is the user's guide:
http://www.geoti.co.kr/DATA/hhp/IT3800_3900%20Users%20Guide.pdf
Please check page 7-30, where you will find the codes to turn on the supplements for EAN 13 barcodes (those with 13-digit). Also, if you don't want the scanner to insert a space between the main code and the additional digits, you have to turn off addenda separator (page 7-31)
There are similar configuration codes for other symbologies (like UPC A) throughout the manual.
Hope it helps!
best regards!
Rafael
Sep 01, 2010 | HHP IT3800 Handheld
We need to convert UPC-A barcode number to EAN-13
Most scanners will convert UPCA to EAN13 as you scan if you have that setting checked. A 0 will be added in front of the UPCA to make it an EAN13. Nothing else changes. You can read about this stuff on Wikipedia.
Mar 24, 2009 | Symbol LS2208 Handheld
Ean 13 problem
you are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
Sep 30, 2008 | Symbol LS2208 Handheld
GP5385 incompatible with EAN 13
Dear Akiong, Please try to reset your scanner configuration, using some utilities from it's manual book (usually available at it's case/box), restore it by scanning it to factory configuration,or scan a label that would enable all symbologies.
Aug 24, 2007 | PSC Quickscan GP5385 Handheld
Symbol LS2208 Handheld Logo
1,582 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
