How to prepare jukebox for moving long distance
SOURCE: When moving our jukebox (Wurlitzer One More Time
Try www.victoryglass.com they should have parts for your jukebox. Try in the reproduction section.
Regards
Alan Hood
ami-man
UK
SOURCE: Wurlitzer 3600 Jukebox turntable problem
The 3600 has a hub that is supposed to play dinked and undinked records. They had 33rpm and 45 rpm records back then, so to change the record speed the undinked (small hole ) records pushed down the hub flat when it landed on it, which changed the gearing. When a dinked (big hole) record lands on it falls onto the larger part of the hub. So if the hub is down and stuck there that's your problem. After the hub has been pushed flat (because of a small hole record) it is supposed to rise up again when the record is returned to the carousel. Have a look under the turn table and push up the centre rod.
SOURCE: need manual for Wurlitzer jukebox 1015 45
I suggest that you check out the Victory Glass wedbsite for a manual.
Regards
Alan Hood
ami-man
UK
SOURCE: Wurlitzer Jukebox 1015 OMT won't play CDs
email me at [email protected] for the manual and service programme
I also need to transport my Whirlitzer one more time jukebox in a couple of weeks ... can you share any information regarding what worked and didn't work for you? I recall someone mentioning something about shipping bolts? What size are those? I would like to find some! [email protected]
