Question about Crosley CE35100AA Electric Kitchen Range
I have a Crosley Gas range, CG34700BDQ, since 2004. After several power outages in our area, the oven and broiler do not work--the "lock" light comes on when bake or broil is pressed. The clock works. I tried clearing the Sabbath mode and 12 hr turn off, but this does not fix it.
  • wmjphelan Jul 13, 2009
    Yes, in a way.
    I was hoping for a solution that I could do myself.
    I received a solution that I cannot do myself, but it gave me some good ideas on on how to get it done.
  • 1,000 Answers
The power outages concerns me as it could cause an issue with the control board. However, before I would consider replacing the board, you should check the door latch switch to make certain it is showing a closed latch condition. If the switch is bad, the control board will not allow the oven or broiler to ignite.
I have attached the wiring diagram for range, you can use an ohm meter to check the switch and determine if the switch is bad.
Good luck and let me know.
Regards,
Posted on Jul 13, 2009
Hotpoint broiler does not light
Most ranges these days have electrical ignitors. More than likely your ignitor is burned out or was shorted out by a surge, which would be a rare occurance. Pull the racks out of the over, get a flashlight and locate the ignitor. It will be right next to the broiler itself where the gas comes out. They are made of graphite and fragile and you should be able to either see a break in the graphite pieces or a section that stands out, normally white in appearence.
Apr 24, 2012 | Hotpoint RGB745 Gas Kitchen Range
How to use kenmore gas range during power outage
just use a match to light top burners, the oven will not work or pass gas if you have a electronic ignition range
Feb 06, 2010 | Kitchen Ranges
Inglis Niagara oven not working since power outage
try pushing cook and hold button once until lock comes on, then push cook and hold button again. The lock should be removed.
Aug 13, 2009 | Maytag MER6772 Gemini Electric Kitchen...
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
Mar 30, 2009 | GE Kitchen Ranges
Maytag gas oven
if your clock and broiler work then you need to replace the lower oven ignighter remove the oven racks then the bottom plate of the oven its easy then the flame spreader after that you will see a burner bar at the back of that will be the ignighter and just because it glowes dont mean its good just replace it
Jun 13, 2008 | Maytag MGR5751AD Gas Kitchen Range
GE spectra xl44 not work
I have the Ge Xl44 stove the burners and broiler work fine but the over will not heat up. How can I resolve this problem?
Jan 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag MGR4410ADW
You probably need to replace the the ignitor. Even though it glows red does not mean that it is working propery. If it does not draw at least 3.5 amps the gas valve will not open. This can be check with a amp meter.
Feb 20, 2007 | Maytag MGR5751AD Gas Kitchen Range
Crosley CE35100AA Electric Kitchen Range Logo
87 people viewed this question
Top Crosley Kitchen Ranges Experts
Vitaliy Gins
Vitaliy Gins
Lawrence Oravetz
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
