Question about Brother MFC-5840CN All-In-One InkJet Printer
Installing cartridge First of all it was a Brother 540cn   Found directions to install cartridge on line.  Thanks anyway
    Problem Solver:
  • 9 Answers
Hi susi
pls. check the label on cartridge and first of all pls. pull out the safety strip on left side on cartridge
then pick the cartridge from label side and push in the printer gently
best regards
Posted on Jan 25, 2008
My ptouch 1750 gives me an error message that says "no tape!" but i have tape installed. help!
Hi, Make sure that the cartridge is installed and that there is no slack with the ribbon. You can turn the tape by advancing the tape in the center of the cartridge wheel, IN THE DIRECTION of the arrow on the cartridge. You can advance the tape by pressing 2 buttons: CODE and Space
Also if you installed a new cartridge, make sure that you removed the safety cover.
Hope this helps.
The owners manual can be found at this address:
http://www.ptouchdirect.com/ptouch/manual/PT1750.pdf
Have a good day.
Mac =)
Apr 22, 2013 | Brother P-Touch 1750 Label Maker
Brother 540cn Printer won't print and displays unable to print 50. The photo capture button also flashes
The error code 50 indicates a paper jam condition. Whether there's actually still paper jammed or not, it's sensors are still indicating a jam. Check again for a bit of paper, or there may be a faulty sensor.
Check out this link: Brother for further information.
Feb 10, 2013 | Office Equipment & Supplies
DCP-540CN install problem
I found the driver for your printer here:
http://welcome.solutions.brother.com/BSC/public/agreement2.aspx?c=us_ot&lang=English&prod=dcp540cn_all&osname=win_vista&viewmode=0&guid=6445891d-b426-460e-8c8a-d610e912fd29&dlid=dlf002712&flang=4&dlfileseq=1
(copy and paste in your browser)
Save the file first (540INST-B.EXE) to your desktop and then Run.
Hope this helps.
Jul 10, 2009 | Office Equipment & Supplies
I want to install ink cartidges and do not know where to begin. I have misplaced my instructions
To install your Brother machine#s ink cartridges, follow the steps
listed below:
1. Make sure that the Brother machine#s power is turned on.
2. Open the ink cartridge cover. This cover is located on right-hand
side of the Brother machine#s front panel.
3. Pull down the four lock release levers. There is one lock release
lever for each ink cartridge.
4. Take the ink cartridge out of its protective bag.
5. Carefully remove the yellow protective cap from the ink cartridge.
- DO NOT touch the side of the ink cartridge covered by the yellow
protective cap.
- Take care when removing this cover to prevent spilling ink and
staining your hands and clothing.
- If the cartridge cover comes off when you open the bag, the cartridge
will NOT be damaged.
6. Install each ink cartridge in the direction of the arrow on the
label.
- Please note that each color has its own specific position. These
positions are indicated by the colors of the four lock release levers.
Do not install an ink cartridge in the incorrect position, as this can
cause print quality problems.
7. Lift each lock release lever and push it until it clicks into the
closed position.
8. Close the ink cartridge cover.
- If the LCD shows #Install Black,# #Install Cyan,# #Install Magenta,#
or #Install Yellow# after you install the ink cartridges, please verify
that you have installed the cartridges correctly.
NOTE:
* DO NOT remove the ink cartridges from the Brother machine unless you intend to replace them. If you do, it may reduce the quantity of ink left in the cartridge, which may cause the Brother machine to miscalculate the amount of remaining ink.
* DO NOT shake the ink cartridges. If ink stains your skin or clothing, wash the affected area with soap or detergent immediately.
* DO NOT repeatedly insert and remove the ink cartridges. Doing so may cause ink to seep out of your cartridges.
* If you mix the colors by installing an ink cartridge in the wrong
position, clean the print head several times after correcting the
cartridge installation.
* Once you open an ink cartridge, install it in the Brother machine and use it up within six months of installation.
* Use unopened ink cartridges by the expiration date listed on the
cartridge package.
* DO NOT dismantle or tamper with the ink cartridge. Doing so can cause ink to leak out of the cartridge
Apr 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have a brother 115c, have installed a new cartridge in cyan, now it says there is no cartridge there, is there anyway i can get it to register the new cartridge?
My Brother DCP-115C I have replaced colours Cyan and Magenta both colours still will not print. Ihave gone through the cleaning procedures still will not print these colours
Jan 19, 2009 | Brother DCP 115C All-In-One InkJet Printer
Blank white 'line' on printed output
Some of the brother printer use a toner cartridge that does not have a drum, have u replaced the drum recently, or does the toner cartridge have it installed? If it has a seperate crriage for the drum, let me know.
Dec 11, 2008 | Brother HL 5140 Laser Printer
Replacing the cart holder on a Brother MFC 240C
Somethings that have worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
2. The cartridge holder in the printer has an "electronic eye" (light sensor) of some type for each cartridge.
Some users have found that putting either permanent marker/sharpie/black PVC tape either on the area of the ink cartridge that goes near the sensor or alternatively putting tape over the sensor itself allows printing to occur.
The problem with this method is that the printer will no longer recognise near-empty cartridges and so will not warn you to replace them and so the print head may be damaged. This is said to work on LC57 icartridges used with the following models: DCP-330C, DCP-350C, DCP-540CN, DCP-560CN, FAX-2480C, MFC-240C, MFC-440CN, MFC-465CN, MFC-665CW, MFC-685CW, MFC-885CW, MFC-3360C, MFC-5460CN, MFC-5860CN.
Sep 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
No cartridge found error
One or more ink carts aredodgy, fit gen new brother inks (x4)
On inks carts there is a flag inside them that normally floats, when it sits down due to ink level being low it blocks a photocell to stop machine from working, it needs to do this to stop any air getting in ink lines, so inks may appear to have ink in them but will not work, on some refill/aftermarket carts flag gets stuck
Oct 27, 2007 | Brother MFC-3240C All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
80 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
