Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
SOURCE: NEED CODES FOR A GE UNIVERSAL REMOTE TO WORK FOR
Go to www.jascoproducts.com/support/universal-remote-codes.asp and open the appropriate WORD or Adobe document for the correct code.
SOURCE: need codes for rca tv using ge universal remote
Here Are Some codes 000, 003, 004, 005. 006, 007, 019, 096, 098, 099, 100, 101, 102, 103, 129, 179, 181, 188, 190, 203, 212, 233. For t.v.'s............Hope this is help full.. : )
SOURCE: lost my manual - need tv codes
Hi! The code of a GE Universal remote for a RCA TV are 0031, 0004, 0048, 0054, 0094, 0100, 0102, 0107, 0129, 0191, 0005, 0009, 0000, 0162, 0163, 0342, 0003 ,0015, 0022, 0096, 0113, 0125, 0179, 0187, 0188. In case none of these works for your TV you can try these steps for you to program your remote conrol.
1. Manually turn on the TV.
2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
3. Press and quickly release the desired TV button. The red indicator blinks off once.
4. Press the ON-OFF button repeatedly (up to 300 times) until the TV to be controlled turns off. The red indicator blinks off with each button press.
5. Press and release ENTER to install the code.
SOURCE: NEED CODE TO GE UNIVERSAL REMOTE RC24912-D FOR RCA
The code to programme your remote with RCA TV
3 digit code are
000, 003, 004, 005, 007, 009, 011, 031, 048, 054, 078, 082, 083, 094, 096, 098, 099, 100, 101, 102, 103, 107, 113, 129, 133, 167, 179, 181, 187,188, 191, 194, 342
4 digit code are
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
thanx
SOURCE: GE RC24914-E 1022
tengo un control general electric 24914-e y quiero el codigo para programar una tv marca toshiba
000 003 004 005 007 009 011 015 048
082 092 094 096 098 101 102 103 107
113 125 129 167 179 187 188 191 194
OK.
