Question about KitchenAid KGRC707 Gas Kitchen Range
Apparently a common problem......the oven takes
Apparently a common problem......the oven (Kitchenaid Gas) takes hours to heat up......what's going on?
SOURCE: Kitchenaid Superba Gas Range
It appeared to be something to do with the plenum and cleaning - repair man came - cleansed and it was okay. MK
Posted on Aug 31, 2008
  • 57 Answers
SOURCE: Gas over not lighting
It is likely that the ignitor needs to be replaced. If the range does not sense the proper amount of resistance in the ignitor, it will not turn on the gas valve for the lower burner. If the broiler is still working, it would further this thinking, as it has a separate ignitor.
Posted on Sep 22, 2009
milten1
  • 1304 Answers
SOURCE: oven takes too long to heat up on Jenn Air gas oven
its your ignitor
located under the bottom pan or panal in your range
ive included the part number form appliancepartspro.com AP2994573
they run like 70 bucks
Posted on Oct 13, 2009
TheMobilian
  • 8220 Answers
SOURCE: kitchenaid oven won't fully heat
Most of the time even though the ignitor is glowing it is weak and you cannot tell it unless you do a amp check.
I have repair photos: HERE
Posted on Feb 17, 2010
taran_2005
  • 10515 Answers
SOURCE: My KitchenAid KGSS907SSS Gas Kitchen Range locked
To start with, kindly provide few more details :-
1. Do you see any problem with the door? what he actually did to resolve the door problem?
2. Do you see any error message?
3. Is this ' not heat ' issue a new one or have you experienced the same issue earlier?
4. Did you run the self clean function again?
5. How long this problem of self cleaning was there?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 06, 2010
Gas kitchenaid gas stove code F02. Turned off breaker seemed to cool down at first now getting warmer. Can't open oven door, like it is cleaning. What do Ido now?
Shut off the breakers and GAS make sure the oven has completely cooled... This may take a significant time
without the aid of the cooling fans...
While you are waiting the requisite HOURS....
Look up your model number on reputable parts sites..
I will list below.
The most likely failure point is a simple heat sensor... (thermal switch" which SHOULD HAVE released your door IF INDEED it
was cool enough (this is VERY critical).
My KGRS807SSS00 Model Overview from PartSelect com
http://www.appliancepartspros.com/
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Don't hesitate to call KITCHAID themselves...
They ARE SUPPOSED to be GOOD....
I DISAGREE... but that just my opinion... as a
disappointed OWNER of their "STUFF"
ServiceBench
Dec 26, 2016 | KitchenAid Kitchen Ranges
Just purchased a KitchenAid KGRI801PBS00 and oven will not turn on, also not a high flame coming from burners? Oven fan will turn on, however it will not heat?
If you purchased this used you may the previous owner may have used the self cleaning feature and thus thethermal fuse is now blown, a known issue with Kitchen Aid ovens apparently.
The good news is that the fuse is a part that you can purchase online and replace yourself
Oct 14, 2011 | KitchenAid KGRI801PBS Gas Kitchen Range
My Kenmore propane oven is taking long then time needed to bake something
A very common problem when gas(both propane and natural) oven takes longer to heat properly is going to be a weak igniter . Since its weak its not fully opening the gas valve and not enough gas is flowing to produce the proper flame size/heat. By replacing the oven igniter it will heat as its supposed to .
GENE
Sep 24, 2011 | Kenmore Ovens
I bought a kitchen aid gas range 4 monthes ago. The model no is kgss907sss. The oven takes more than 1 hour to preheat to 375F. Sometime it even can't reach the temperature forever.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 12, 2010 | KitchenAid KGRS807S Gas Kitchen Range
My stove does not maintain a consistent
This is most common with electric ovens and the bottom element goning bad...but I will also include the most common problem for gas ovens also when this happens, as you did not specify which you have...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
If you have a gas oven...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
May 04, 2010 | Kitchen Ranges
Oven set at 350, won't get there. kitchenaid mod#kgrt607hwho.
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 30, 2010 | KitchenAid KGRT607 Gas Kitchen Range
Oven takes too long to heat up on Jenn Air gas oven
you need to look at the oven igniter to see what color it is. if it is orange it needs to be replaced. it should glow white hot in order to ignite. hope this helps.
Oct 13, 2009 | KitchenAid KGST307 Gas Kitchen Range
Kitchenaid KEMS308 display is saying "enter probe temp or remove probe" No probe is plugged in or has been used in a while. This message came up after cooking for about 3 1/2 hours at 300 degrees. Now...
Apparently this is to do with moisture having affected the oven adversely (I got this error message after baking 50 potatoes with all the steam that generated. Have a look at this page http://www.howtomendit.com/answers.php?id=162257 ....the solution is to set the probe for 160F then turn the oven on for 15 minutes or so at 450F. This apparently should dry out the probe position and all work again.....I am trying it now.....
Sep 07, 2009 | KitchenAid Architect® KEMS308SSS Stainless...
KitchenAid KGRC707 Gas Kitchen Range Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
