Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
When I shampoo The excess water that is to come back in bucket has never happen I bought it a long time agp at KMart didn't know why it doesn't work. I oly paid $100.00 so I don't want to spend to much money to repair. I just borrow my sons machine. Janet
I BOUGHT MY STEAM VAC AT WALMART BACK IN OCTOBER AND DIDN'T TRY IT OUT FOR A FEW MONTHS, JUST TO REALIZE IT DOESN'T WORK! IT REALLY UPSETS ME BECAUSE HAD I KNOWN IT WASN'T GOING TO WORK I WOULD'VE BOUGHT A DIFFERENT BRAND WHEN I HAD THE MONEY!!
Posted on Feb 03, 2010
I have just bought a vax vcwrs700 carpet shampooer at a garage sale. With it came a bottle of bissell x2 carpet shampoo. Woul you know how much shampoo I should know please?
probably a cap full from the bottle
make sure that you use the suds restrictor liquid as well or the suds will come up in the bucket and block of the vacuum flow
Oct 24, 2016 | Bissell Vacuums
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
I am at my daughters trying to clean her carpets and i want to know if i set it up right to shampoo her carpets . i only put water and solution in the small container in the back,but i didn't add it...
The smaller container in the back under the release handle it the cleaning solution resevoir. The larger one in the front is for the hot water. It has an internal bladder that holds clean water in this larger container, while returning the dirty to the outer bladder chamber. Both need to be filled with water at the very least in order for the machine to work. If either goes empty, the machine will stop working.
Sep 01, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
A solution to many "non-spray" problems.
The Scotchguard is going to be dicey inside the Bissell, yes, as you have learned the hard way.
I think the Bissell and the Hoover shampoos sold for their carpet cleaning machines are reasonably safe to use in the Bissell. My own personal favorite for use with the Bissell is the Hoover Premium Pet Formula, which is pricey but effective even if you don't own pets. I also pre-treat stained areas with Resolve Carpet Cleaner, a few minutes before using the Bissell.
I don't know what will happen with your home brew containing Dove. It may work well.
Jun 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Where to put shampoo
how do i put in the water and shampoo...???
May 06, 2009 | Bissell 1699 ProHeat Clear View Upright...
Having trouble shampooing
I found this on a website. Hope it helps others...
by Mainelyvacs in: Kirby
  • First a short explanation of how the Kirby shampoo system works: Kirby uses a “Dry Foam” type of shampoo. Basically, it spreads a shampoo foam solution on the surface of your carpet. This foam needs to stay on the surface of the carpet until it is completely dry (usually 1 to 2 hours depending on temperature and humidity) As the foam dries, it soaks up grease and dirt. You then vacuum the carpet and up comes the shampoo residue along with the absorbed dirt and grease. It does a very good job on the surface but will not extract stains from the bottom of the carpet or carpet pad. Several other brands such as Electrolux, Hoover and Koblenz make Carpet Cleaning machines that use the same system.
    So, you’ve read your manual, you’ve removed the carpet cleaning nozzle and the bag assembly from your Kirby, you’ve installed your shampoo tank and carpet shampooing nozzle tray and you start to shampoo but all you get on your carpet is a puddle of soapy water and no foam. Here’s a few things to look for:
  • Make sure you are using a Dry Foam Shampoo(preferably Kirby) and NOT an extraction shampoo, the Rug Doctor shampoo you had left over from your last rental will not work.
  • Make sure you have the correct mixture. If you are using Kirby Dry foam shampoo you simply fill the tank with water and put a tank cap full of shampoo in with the water. You can use other brands of “Dry Foam” shampoo, but the mixture ratio may be different, so read the label first.
  • Don’t reuse last year’s leftover mixture, it’s probably no good.
  • Make sure a family member didn’t pour any leftover mixture back into the empty shampoo bottle - further diluting a mixture will not produce any foam.
  • Don’t use shampoo that’s seen extreme temperatures.
  • Check the tank and make sure that the sponge filter is in place and if it is in place that it is not deteriorated. The sponge filter is located under the tank at the point where you attach the tank to the hole that you removed the bag assembly from.
  • Check the hose that runs from the tank to the nozzle. It should have a screen in the end that attaches to the tank (older models had a cloth screen with a metal retainer, models after 1989 have a 1 piece metal and plastic screen.
Apr 13, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Powersteamer powerbrush
Brand new out of the box and the bucket didnt fit flush and the shampoo or water not spraying?
Mine was the same lift up the bucket and look at the rubber washer / seal take it off turn it inside out and put it back on.
Wahoo the busket fits the was washes , you have your carpet cleaner back
Jun 26, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Won't spray. . .nothing happens when pull trigger. . .pump belt is ok. ..
I assume you've changed the flat belt and it's working o.k. So, the next thing to check is the bucket seat. When the bucket is set down into the machine, the bucket valve is opened by the center pin on the receiver in the floor of the machine. You should put clean water into the bucket and install it. Wait a couple of seconds and remove it. Inspect the receiver and see if there is any water in it. If not, check the valve in the bucket and make sure that the rubber seal is in place. Sometimes they come off and stay stuck in the receiver. This will not allow the valve to open. If the seal is stuck in the receiver, remove it and re-install it on the bucket valve and test again.
By the way, if there is no shampoo in the shampoo tank, and the mixture dial is set anywhere but off, the machine will not spray. The pump will suck air through the empty tank and will not pick up water from the main tank.
If there is water in the receiver after you remove the bucket, then the problem is likely in the heater. The heater is located in the center of the handle and you must open the handle by removing the hose storage rack and then the top of the handle. There are two screws behind the hose holder that are at the back/bottom of the handle and are recessed into the handle. Once the handle is open, the heater is obvious. You will find two clear hoses attached and they often become plugged at the connections, just inside the heater. You can clear this with a 1/8" drill bit. Remove the hoses and take the bit in you hand and gently insert and rotate. Once cleared, replace the hoses and reassemble. I hope this helps. Be careful. These machines are a maze of hoses and valves and can be difficult to reassemble. Be very observant whenever taking one apart.
One more thing. I have seen instances where the screws that hold down the hood in the area of the tank have broken through the plastic and will lift enough that the tank will not sit down far enough to allow the valve to open. Check here, too.
I hope this helps.
Jan 30, 2008 | Bissell 8910 ProHeat Clear View Upright...
Unable to Extract Water
1/ Is the diverta flap in the correct position.
2/ red lint filter in tank clean.
Sep 03, 2007 | Vacuums
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
82 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
