Question about Vacuums
I don't have a manual for the used vac i bought.Where can I download one for free?electrolux 2100 vac
  • 26 Answers
Hope find you some info on this internet... http://images.google.com.au/imgres?imgurl=http://www.pdfoo.com/thumb/small/p35/426/t-19616.jpg&imgrefurl=http://www.pdfoo.com/pdf-426/vacuum-cleaner.html&usg=__hmY1tS_jd-O3C1jxRyzDou6kxLA=&h=120&w=93&sz=2&hl=en&start=19&sig2=PXnXvgeXyZCyhm_zMvmTrQ&um=1&tbnid=v_TbfJLC1bYi_M:&tbnh=88&tbnw=68&prev=/images%3Fq%3Delectrolux%2B2100%2Bvacuum%2Bmanual%2Bbook%2Bdownload%26gbv%3D2%26hl%3Den%26sa%3DN%26um%3D1&ei=xjFbSrWKEZ-KtAO579yGCw
click this.. or copy then paste on your address site.
Posted on Jul 13, 2009
I need the Manual for #2100 Electroluks vacc
Service manuals for the Electrolux vacuums, including the accessories, are only available to the franchise owners and service techs.
Also, having said that, I don't recommend fixing the switch yourself. Replacing the switch involves disassembly of the canister, which is a bit complicated. Putting it back together correctly, without crimping wires. even more so.
I used to be an Electrolux service manager and have seen vacs brought in in pieces. Customers had succeeded in dismantling the machine, but were unable to reassemble it. Or had cracked or broken a piece. This makes the repair more expensive.
Or machines were brought it that had been reassembled incorrectly and wouldn't work. Or worse had shorted out due to crimped or incorrect wiring.
I strongly suggest taking the vacuum to a repair shop that is familiar with the older Electrolux vacuums, in this case the plastic models.
Mar 06, 2014 | Electrolux hose 2100 series diplomat
I would like to download a manual for an Electrolux 2100 vacuum cleaner.
Go to http://www.aerusvacuums.com/support/manuals/.
Go to "Older Models" and click on 2100. Click on "download". Save to appropriate file.
Dec 20, 2010 | Electrolux Vacuums
Have an electrolux 2100 canister vac, it has lost suction power thru the years. no clogs in newer hose or in sweeper. even with new bag, filter and belt only increases power minimally.
Have you ever over the years replaced your brushroll ? Have you tried dropping a coin thru the hose from one end to see if it comes out the other end ? Have you taken the wand loose from the elbow ( the swivel part of your carpet sweeper) to see if there was a blockage ? Does the motor make a strange noise ? Have you ever had a tune-up on your vac.
You might think about taking your vac to your Aerus/Electrolux shop.
Joe
Nov 19, 2009 | Electrolux Vacuums
I was given an Electrolux vacuum model 1401-B. I would like to download a manual for it. Do you have one? Thanks, Carolyn
Carolyn, The 1401B is one of a family of US built LUX models , now sold by AERUS Electrolux. It shares common info with the MARQUISE, Super J , Olympia and 1205, etc so if you come across a used manual for any of them you will be in good shape.
Try an AERUS Electrolux dealer but the manual may be out of print.Also try a local vac shop
Quick rundown, :
Set the dial at front between medium and fine and don`t adjust, this is the bag fill control, NOT a suction control.
Only use genuine 4 ply filter bags from a pro vac shop, not grocery store grade as this is a vac which filters thru its bag.
Hang the hose for longer life, obstructions can be blown out thru plugging the hose in the blower port under the slide door behind the handle.
Inspect the power head for hair and thread and remove any visible.
When you wheels squeak while vacuming spray the axle shaft behind the neck with a drop of WD 40.
If you feel air venting thru the hose behind the handle or if it is crushed and kinked there or at the vac replace the hose for better suction. The weight of this vac weras out hoses. When the castor below the body cracks and it will, match it with a small SHEPARD castre at the hardware store.
If your rewind is sluggish, pour a tablespoon of talc or baby powder in a tissue and run it up and down the lenght of the vac cord end to end. Then drop the tissue into the vac bag fro fresh scent.....
Enjoy the vac, this one is a great one 30 year plus life span, parts are still available keep it in good repair
Oct 10, 2009 | Vacuums
I have an Electrolux Aerus 2100 canister vacuum. When I
it might be that the hose connections are bad.or it might be a sensor in the vacuum. call a electrolux vac shop and get it looked at.
Jun 24, 2009 | Vacuums
Protection light on my Electrolux 2100 vac is on
the carpet attachment pushes on a smsll switch to turn on the vac look for the pin
Apr 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
I have Electrolux canister vac. The suction end pops open everytime it loads up.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=689886
Generic problem for all Vacuums
Posted by wmcox on Jun 20, 2008
I have Electrolux canister vac. The suction end pops open every time it loads up.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In the door there are vacuum lines that could be pinched or bent and are not letting air through to the bag, the system is designed that if the bag get to full or the air flow is restricted it will pop the door open and save the motor from burn out. This is repairable and nor to expensive and to check with the local vacuum cleaner dealer in your area or to call the Electrolux cust serv @ the factory for further information. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 20, 2008 | Vacuums
Dust....dust....dust
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113662&thid=662824
Posted by Kitkatman on Jun 11, 2008
I recently bought a house with an older Electrolux Central Vac system. I'm unfamiliar with them, so I'm not sure how to deal with this: I cleaned up some mortar dust with it, and noticed not too long after that when I went into the garage, there was a fog of dust. The hose from the unit is venting into the garage. Is this normal? I have since used it for everyday household cleaning and each time I go back to the garage to a cloud of dust. Is there anything I can do? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that the unit you have may have to be vented outside as I am not familiar with this particular unit, or it could very well be that it is missing a filter or the filter you have inside already is shot and is in need of replacement or on some central vacs there are paper filter that go over the cloth type filter. Again, I am not familiar with this older unit but feel free to contact the Electrolux Factory or Manufacturer and give them the model # and the serial # for the unit and they will have a breakdown of if it should be vented and what type of filtration it should be using. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Jun 11, 2008 | Electrolux Central Vacuum
Replacing on/off switch of electrolux
In yhe side of you canister there is a ruber molding on each side. Open the door to access the bag and you will be able to pull these two molding straight out this will allow you to split the canister.
Apr 24, 2008 | Vacuums
Vacuums Logo
128 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
