Question about Waterstone 4055-ORB Oil Rubbed Bronze Towson Deck Mounted Soap Dispenser 40
I have an Oil Rubbed Bronze Deck Mounted Soap Dispenser. It is similar to the one listed at http://www.faucetdirect.com/index.cfm/page/product:display/productid/06341/manufacturer/hansgrohe/finish/oil%20rubbed%20bronze&source=cj?source=cj. However, It is too short next to my vesel sink (7.5 inches above countertop). Is there a converter, adapter, extender to make the soap dispenser a few inches taller? BTW the holes have already been drilled into the granite.
  • 297 Answers
No there is not. it is designed the way it is.
Posted on Jul 22, 2009
The suction cups on my oil rubbed bronze soap dish are no longer tight enough to sick to the wall of my shower. it's been fine for over two years until now. can you buy new suction pieces or do i have...
Sometimes this happens when the suction cups are somewhat dirty.
Wet the suction cups, leave for some time, and wipe with a clean cloth until the suction side is shiny. If it is not shiny at places that suggest those places are not cleaned thoroughly. Wet again and wipe again until you get a shiny surface.
Check the wall where it was attached. If you see any patches wet the area and wipe with a clean cloth.
You can apply just a tad bit of oil (I use coconut oil) to the suction cups.
Try this - and let us know the results.
Thanks for using FixYa!
Sep 05, 2011 | Allied Brass Soap Dish - 432.ORB - Oil...
I have a Grohe liquid soap dispenser and the washer is leaking soap at the base of the unit. can this washer be replaced?
it is not available from Grohe but if you take it apart it is probably generic enough to be found at your local hardware store. assuming this the problem. it may just need to be tightened up a little. either way here is a link, w/an adobe file (specification sheet), regarding the specs about 1/3 down the page on the left. you can also purchase the soap dispenser here. hope this helps:)
http://www.faucetdirect.com/grohe-28-751-deck-mounted-soap-dispenser/p54966
Jul 26, 2011 | Grohe Soap/Lotion Dispenser 28.857.AV0
How can I disconnect the Moen "Brandtford" Towel Ring from it's "locking clip"?
Look underneath the part that is mounted to the wall there should be a real small screw that is holding the cover on. After you remove the cover you can get to the mounting screws.
Apr 13, 2011 | Moen YB2286ORB Brantford Towel Ring In Oil...
We have oil rubbed bronze bath/shower hardware.
there are two screws, where you push to close the drain
take out those screws , you will find a chain or something similar, that is loose. tight it or conect it back
May 14, 2010 | Home
Soap dispenser pump not working
I have the same problem after just about 6 months of use. I have checked to make sure it's full of soap, before you ask...I've run hot water through it while pumping and had success in pumping just water out. Then when back in the soap, nothing happens. Soap comes up about half way into the tube and sits. I now use it as a soap dispenser, dip stick style.
Nov 29, 2009 | Moen 3910S Sand Line Art Deck Mounted Soap...
1-3/4'' rubbed bronze pipe
you normally do not put a soap dispenser in the bathroom,,that is why there is no extension like you are asking for.
Oct 16, 2009 | Plumbing
Pegasus Estates 861 360L towel ring installation?
there is a groove on the top of rhe towel ring that the mount has an indentation that this groove sits in. The tiny screw pulls the groove into the mount in turn, holding the ring in place
Jul 14, 2009 | Waterstone 4055-ORB Oil Rubbed Bronze...
Nut in oil tank of 1991 toyota corrolla is stuck
You might want to repost this because it is listed in the plumbing section. You will probably get more answers on the car side.
Mar 20, 2009 | West Brass NEW Oil Rubbed Bronze Instant...
Peeling paint coming off of oil rubbed bronze basket strainer
Bronze is more expensive than standard mass production is worth, i supposed if you want them made out of any mat. you can call kohler and pay for it, i've been to their plant and they do some pretty awsome custom work.
Rubbed oil is just a color and somtimes "you get what you pay for" if you buy a cheap basket strainer they usually do exactly what you're saying.
You can buy more expensive strainers that have a better finish, I know Kohler and Moen have lifetime warranty finish on many of their higher end products.
Mar 03, 2009 | Mountain Plumbing Mountain Basket Strainer...
Waterstone 4055-ORB Oil Rubbed Bronze Towson Deck Mounted Soap Dispenser 40 Logo
136 people viewed this question
Top Waterstone Home Experts
Donni Steen
Tom Chichester
Are you a Waterstone Home Expert? Answer questions, earn points and help others
