PLS!!!! befor.... something bads happens... pls!!!!!
SOURCE: my plasma tv
Do u loose picture and audio at the same time and when the led starts to flash on the front of the TV is it a red 5 ? If so there is an oscillating crystal that is getting really hot on the SSB. 27Mhz xtal. if need more specifics ill get the philips replacement part number.and where it is located of the SSB.
SOURCE: PLS HELP! WHAT IS
press volume + from tv and menu from remoteat same time
Testimonial: "EXCELENT ,IAM HAPPY,THANKS FOR ALL,"
For more details type in this site name "Electro-help" to Google search box [not in the address bar of your browser], and click search or press Enter. It is an electronic equipments service help site. Note the position of hyphen in between words in site name. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments. Pull up older posts. You can locate this site name, either at the bottom part of first search page, or at the top of second page. Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price and more.
Service mode to many brand TVs are given.
SOURCE: how to know if capacitors are bad on LG 42" hd tv
Put it on the ohmmeter (with the correct polarization for electrolytics, of course). This will let you test the cap for shorts.
Small capacitors should read "open". Large caps will show a "kick" of low impedance, but it will quickly climb and become very high. If the value remains low, you have a shorted cap.
If you want to test a cap to verify its value, you have to get fancier. Applying 60 Hz from a small transformer (less than the cap's rated voltage) and measuring the AC current will let you calculate the capacitance and show if the cap is still within its tolerance.
