I HAVE A 204 CHEVROLET COLORADO AND THE HEATER FAN WILL NOT COME ON ON ANY SPEED
This same thing just happened to my 04 colorado. the problem is in the wiring harness or the resistor for the blower motor. I found my problem in the harness. Take the few screws out of the glove box hinge and the cover under the glove box and the motor will be exposed. disconnect the large white coupling and look to see if the pins or holes are black, like they had been burned. If they are, you may be able to clean them and put them back together. If they look normal, the small black box that is bolted to the plenum has gone bad, this is the resistor. The entire harness, with resistor can be purchased on gmpartsdirect.com
