I unplugged this computer to move it to another place and it was working fine. When I plugged it back in the on switch does nothing just as if it is not getting electricity. I have changed all cords to another outlet still no on computer. Is there a reset button somewhere?
    Problem Solver:
  • 19 Answers
You might want to change the internal battery, it is the small 3v battery. Most of the time it will solve your issue. Be sure to replace it with the same battery code eg.CR2032. It is the size of a nicle and on the motherboard. Be sure to discannect all power and discharge yourself from any static elec. before touching the motherboard
Posted on Jul 13, 2009
  • 26 Answers
I think power supply dead. Look like replace the power supply. Go ask computer store.
  • Julian Mazzeo
    Julian Mazzeo Jul 13, 2009
    i think power supply dead. Look like replace the power supply. Go ask computer store.
My acer monitor H243H says No Signal after I unplugged the DVI cable and plugged it back in. I can't switch the input because nothing happens when I push the input button on the bottom of the monitor. It...
Maybe your BIOS switched to VGA output, try plugging in another monitor which has VGA input and change settings in BIOS for default output to DVI.
Nov 05, 2013 | Acer H243H Monitor
I have a HP G60-235DX, It was working fine yesterday. Today I hit the on button and nothing happens. The indicator by the a/c adapter is on. I changed the on switch, but still nothing.
If your computer is plugged in and charging, unplug it and then press the power button, then plug it back in. If that doesn't work, remove the battery, then pop it back in and do as i said above.
Hope that helps.
Feb 10, 2011 | HP G60-235DX Notebook
I unplugged my computer from the livingroom and moved it to one of the kids bedrooms. After I plugged it back in, the tower doesn't power up. I've switched the power cords with the ones from the monitor...
Look on the back of the tower, up top on the power supply and there may be a reset button or a red switch. Switch it off for a few seconds and them back on. That might work.
Nov 02, 2010 | Dell Inspiron 531s Desktop Computer
Acer desktop PC locked up and now won't turn off or boot up
I've seen a similar issue on Acer Veriton 7900. When you unplug the power chord while the machine is still running the BIOS/CMOS gets bugged up. If your PC doesn't have a 3 year warranty you can clear the CMOS/BIOS. To do this, note the following...
1.) Unplug the power cord
2.) Remove the CMOS battery from the unit
[OPTIONAL] move the jumper on the mainboard to the 'clear position' It should be indicated on your mainboard.After 30 seconds move jumper back on original position
3.) Wait for 30 seconds
4.) Place CMOS battery back into its position
5.) Reconnect the power cord and attempt to power on the unit.
May 13, 2010 | Acer Computers & Internet
Monitor has no power light or anything.monitor was working fine,turned it off,unplugged it and moved it to another location with the same computer,and now nothing. no power light or anything.checked the...
First place to look will be the power supply section, look for bad caps with bulging top/bottomseal, blown fuse, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Feb 11, 2010 | Samsung SyncMaster 172N 17" LCD Monitor
I cannot boot up the computer. When I push the front power button, nothing happens. When I flip the switch on the back, or unplug it for 30 secs and plug it back in, the fan starts up and a yellow light...
I had this happen to my emachines T1842 about a year ago. I replaced the power supply and it worked fine. It was about 25 bucks but fixed my problem. Make sure the red switch on the back hasnt been messed with. it should be on 115. If you have moved it, it may have blown a fuse inside the power supply.
Feb 04, 2010 | E-Machines eMachines Desktop PC
No video on boot
Did you check your monitor. Try connecting your monitor to some other system and check it out.
ALso check for the capacitors around your Processor for bulging issues. If they are bulged check out if they can be replaced
Dec 06, 2009 | Gigabyte GA-945P-S3 Motherboard
Computer does not turn on
Check the switch of the power supply at the back (black button) First
If the power supply fan doesn't work or cpu fan doesn't work
Replace the power supply.
Thank you for using FIXYA
Please don't forget to rate my help
Have a great day!
Pablo :-)
Oct 16, 2008 | Computers & Internet
MOTHERBOARD wont boot up
verify that when you mounted the motherboard you placed all the mounting screws in the right places one misplaced screw and the charge sent through your motherboard will be pushed out and dispersed into the case
Aug 06, 2008 | ASUS A8S-X Motherboard
NO POWER AT ALL!
Does the power supply have its own power switch?
It is located next to where the power wire plugs into the back of the PC.
Jan 10, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
