Question about Dirt Devil Rampage Plus Robotic In Ground Pool Cleaner
I NEED PARTS FOR A DIRT DEVIL RAMPAGE POOL CLEANER AND NEED MANUA
It is not working right and I think it needs new rubber bottom. Thanks.
Here is the schematic for this vaccuum and you can buy the parts here also.
http://www.poolspapartsplus.com/p-240-dirt-devil-rampage-robotic-cleaner.aspx
Posted on Apr 03, 2011
  • Al Seaver
    Al Seaver Sep 08, 2011
    poolspapartsplus.com has gone out of business. try poolpartsonline.com instead.
  • 640 Answers
You can buy replacement rubber threads for this model from any store that sells automatic pool cleaners. They are easy to install and the instructions should be included in the packaging. This is something that you should easily be able to handle yourself.
Posted on Jul 28, 2010
Dirt Devil Rampage Robotic Pool Vacuum wont climb side and stays in deep end all the time?
If a pool vac is not climbing the side of the pool this is one of several things main things . a blockage in the pipe (try inserting garden hose to flush it. or insufficient vacuum at the skimmer box (Test with your hand) or a break inside the unit - if the third, you probably need to take it in for repair.
May 17, 2014 | Dirt Devil Rampage Robotic Pool Cleaner...
My pool cleaner seems to have to much bouyancy
Set a brick or weight on top of it and tie the brick/weight to the vacuum. that might help it.
Nov 17, 2013 | Dirt Devil Rampage Robotic Pool Cleaner...
Automatic cleaner won't do the whole pool? Keeps skipping big patches?
use the diagnostic system in accordign with the inst.manual or download free www. retrevo.com or www.fitness.manualsonline.com
God bless you
Jun 19, 2012 | Dirt Devil Rampage Robotic Pool Cleaner...
Brand new dirt devil will not make connection with the bottom of the pool
Check to make sure that the pool cleaners flapper is installed properly. If it is installed incorrectly or has debris lodged in the flaps, the pool cleaner will not be able to create suction on the bottom of the pool. Also, check and make sure that you have enough water pressure to power your cleaner.
Feb 17, 2011 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
Dirt devil pool vacuum wont move
If one of these pool cleaners is not working, you likely have an obstruction in the flapper. That would explain why you have suction and no movement. With the pump off, turn the cleaner upside down and check for any twigs, rocks, etc. in the flapper. If you don't see anything or see something you can't reach with your fingers, remove the base plate with a flat head screw driver and check there. The base plate is where the waste is collected.
Jul 09, 2010 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
Replacing the drive track.
The tracks for the Dirt Devil Rampage pool cleaner are the same as the AquavacTigershark. Simple look for the parts for the Tigershark. Its the same exact thing.
Jun 20, 2010 | Dirt Devil Rampage Robotic Pool Cleaner...
My dirt devil Rampage Robotic pool cleaner vacuum get stuck on the bottom drains
There is a ring that is designed to fit over bottom drains to prevent robotic pool cleaners from getting stuck. There are several different brands/kinds available and any of them should prevent the problem. Here is one example:
http://www.backyardcitypools.com/Automatic-Pool-Cleaners/NE290-Smart-Ring-Drain-Cover.htm
May 07, 2010 | Dirt Devil Rampage Robotic Pool Cleaner...
I need a new belt for my Dirt Devil RoomMate. Where can I get one? Advise
Your Dirt Devil M084000 uses Dirt Devil Style 7 Belt - 2 Pack. Part # 3400615001 according to the parts manual for this vacuum cleaner, as well as the Dirt Devil website.
Here's a link to the belts online at our store;
http://www.govacuum.com/ddp126.html
I hope this helps you! Please rate the review as helpful if this helped you find the belts.
Thanks,
Chris
Mar 20, 2010 | Dirt Devil M084000 RoomMate Upright Vacuum
Cleaner is not picking up debris from pool bottom
Have you check the filter/baskets to make sure that you don't have a large piece of debris that is preventing suctions? You will also want to check each section on the vaccum systematically to make sure that there are not cracks or noticable areas of damage that would prevent the pool cleaner from working. Is is not moving at all or just not sucking properly? Can you give me more details as to what it, exactly, it is doing?
Apr 19, 2009 | Dirt Devil Rampage Robotic Pool Cleaner...
Dirt Devil Rampage Plus Robotic In Ground Pool Cleaner Logo
308 people viewed this question
Top Dirt Devil Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Dirt Devil Pool and Spa Expert? Answer questions, earn points and help others
