Question about Air Tools & Compressors
Need a unloader valve for a ProForce model no. vpp0200604 air compreesor
  • 98 Answers
Need to know the desired pressure for your compressor, please dont exceed the compressors capabilities
Posted on Jul 21, 2009
Need piston rod for rep0200604 compressor
A search of your model number turns up a powermate compressor. Unfortunately the piston rod is not available as a seperate part, you have to order the entire pump/motor unit. The only place I could find it was at this link: http://www.ereplacementparts.com/powermate-vpp0200604-single-stage-oil-lubricated-air-compressor-parts-c-117046_117047_117049.html.
Dec 23, 2010 | Coleman Proforce 6 Gallon Air Compressor
Service ride control
rear compressor use to come on often(heard "minor" left rear air leak after stopping and shutting car off). The compressor always came on at start up. after a well loaded family camping trip, the compreesor stopped comming on. when we arrived and I unloaded the cargo, the compressor came on and raised the rear end of the vehicle after unloading the "camping stuff" the compressor came on and re-leveled the car. After trip home and unloaded, the compressor no longer comes on, although car is level and rides nice, but when people used to get in the back seats, the compressor came on and slightly raised the vehicle. I found no blown fuses. would dealer codes say bad compreesor or is there a way to check the compressor? also if I replace the shocks with ones that do not require the compressor, will I be able to ever pull a heavely load car or tow anything without dragging/sagging? any information or insight would be much appreciated... thanks in advance
Feb 04, 2010 | 2003 Cadillac Escalade
Compressor wont restart because of head pressure
Piston air compressors have to unload to permit a restart, the two mot common types are an unloader valve or free air unloaders.
with an unloader valve this system uses a check valve mounted in the discharge line as it enters the tank, when the pump stops this check closes and does not permit the tank pressure to return to the pump. a unloader valve also opens to allow air pressure in the discharge line to vent, this valve is either on the pressure switch or on some models is on the pump, and is a centrifugal type.
Free air unloaders or head unloaders are a set of fingers that hold open the intake valves on the cylinders to permit the piston not to pump air against a head load, and once the pump is running the fingers retract to allow the pump to function as normal.
Jan 19, 2010 | Air Tools & Compressors
Will not fill with air where can I get parts?
Below is a link for parts to a Coleman compressor model #VPP0200604. Not positive but I think that is what you have.
However before you buy anything how do you know what the problem is? Is the motor running? If the problem is that it's just worn out you may find it difficult to get parts for rebuilding it. What you have is whats commonly referred to as a throw away pump. The second link show the pumps replacement cost, around $85.00. If you do manage to get rebuild parts for it they will cost at least that much.
You can get a Senco at Home Depot which is a couple grades up from yours for around $125.00.
Your compressor is really not worth the effort to rebuild it.
If on the other hand your compressors motor is not starting up please include any details in a response to this and I'll try and troubleshoot it for you.
Hope this helps.
http://www.mastertoolrepair.com/vpp0200604-vp0200604-p-14827.html
http://salestores.com/colema14.html
Nov 16, 2009 | Coleman Proforce 6 Gallon Air Compressor
I need a part for VPP0200604 PRoforce air compressor
that made by powermate which is out of business no part. you can check with pramc co which owens that division know. 800-445-2276
Oct 14, 2009 | Coleman Proforce 6 Gallon Air Compressor
6 gallon proforce air compressor not building any pressure
You might have a broken valve. You'll need to pull the head apart. But make sure replacement parts are available first. Does this unit have an unloader valve on it ? That could also be your problem. You probably should check this first
Mar 31, 2009 | Coleman Proforce 6 Gallon Air Compressor
Broken Part. Need Replacement
If you refer to the oil filler plug, item #6 in the diagram linked here, it's listed as obsolete.
If refer to the intake filter, It's item #3 on the diagram, it too is listed obsolete.
I would contact Master Tool Repair at 757-410-2879. They can cross the part to another once they know the thread size of the old part.
Mar 15, 2009 | Coleman Proforce 6 Gallon Air Compressor
40 hp ingersoll rand rotary screw air compressor keep shutting
I have a ingersoll compreesor that keeps shuting down on high discharg air temp
Nov 12, 2008 | Ingersoll Rand Stationary Air Cooled...
Air Tools & Compressors Logo
124 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
