Question about Dell F3534 Touchpad
Ntoskrnl.exe missing or corrupt- After a couple of install
I work in IT but this has me stumped-maybe hardware issue,
Hi Hope someone might be able to direct me as to what is wrong with my Laptop- About a month ago the battery stoped being recognised by the system & as soon as I unplug from the mains the laptop dies. Thats ok I was going to hold out until Dell had a sale as their Battery prices are outrageous. But then I get this message Ntsokrnl.exe is missing or corrupt after a couple of installs same thing
Things I noticed- Internet card not recognising any cable connection
Touch-pad is working really slow,Jumpy,freezes-up.
Keyboard is slow to respond & you really have to press the keyboard hard to get any characters to print. The mouse & keyboard work fine when I plugin USB mouse & keyboard but the internet card does not,
tried recover cd & I done a couple of new installs but same error pops up Ntsokrnl.exe is missing or corrupt.
My findings so far are a Hardware issue but all is well when I go to device manger & no other error. Touchpad/keyboard/Internet card.
Any help would be much appriciated.
    President:
  • 627 Answers
  • Kevin Smith Nov 14, 2010
    Sounds like the hard drive is getting ready to crash it acts like a bad sector on the hard drive where that file is it cannot read it because that sector is bad.
How can i reinstall the ntoskrnl.exe when it is corrupt
Assuming a couple of things:
1. Your OS is Windows XP
2. This is the error message you are getting -
"Windows NT could not start because the following file is missing or corrupt:
Winnt_root\System32\Ntoskrnl.exe
Please re-install a copy of the above file."
To reinstall notskrnl.exe, do this:
  • Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
  • After the setup files are finished loading press R to repair using Recovery Console.
  • When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
  • Login to the Administrator account by typing the password for this account, and then press ENTER.
  • At the recovery console command prompt, type the following command, and then press ENTER:
    For Uni-Processor systems: expand <cd-drive>:\i386\ntoskrnl.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
    For Multi-Processor systems:expand <cd-drive>:\i386\ntkrnlmp.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
    Note In these two commands, the <cd-drive> placeholder represents the drive letter of your CD drive, and the <hd-drive> placeholder represents the drive letter of the hard disk on which windows is installed.
  • If you receive a prompt to overwrite the file, press Y.
  • Type exit, and press ENTER at the command prompt.
  • You should now be able to boot up properly.
  • Oct 14, 2013 | Dell LATITUDE Computers & Internet
    Tip
    NTOSKRNL.EXE is missing or corrupt.
    Issue: NTOSKRNL.EXE is missing or corrupt.
    Related errors:
    Below is a listing of the full error message that may be related to this error.
    Windows NT could not start because the below file is missing or corrupt:
    C:\Winnt\System32\Ntoskrnl.exe
    Cause:
    1. Keyboard issue
    2. Miscellaneous corruption
    3. Corrupt boot.ini file.
    4. Missing boot.ini file.
    5. Missing or corrupt ntoskrnl.exe file.
    6. Windows NT installed on a partition bigger then 7.8GB
    7. Corrupted hard disk drive or severely corrupted Windows.
    Solution: Keyboard issue
    This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
    Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
    This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
    Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
    Microsoft Windows XP users:
    If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
    Microsoft Windows NT and Windows 2000 users:
    To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
    1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
    2. In the setup menu, type R to start the repair.
    3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
    If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
    1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
    2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
    3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
    4. Select the operating system you wish to fix, and then enter the administrator password.
    5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
    6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
    7. Type exit to reboot the computer.
    If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
    OS Loader v4.01
    Disk I/O error status=00000001
    Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
    Please reinstall a copy of the above file.
    If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
    Attempt to check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
    5. Once at the recovery console type chkdsk /r
    6. Once completed type exit and see if issue is resolved.
    If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
    Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
    on Dec 27, 2009 | Computers & Internet
    My ntoskrnl.exe file is missing or corrupt
    To repair missing system file/s orcorrupted system file/s, boot up with the Windows installation CD then -Press R to repair wheninstructed.Press 1 or Enter to repairthe C:\Windows folder.Then type chkdsk /r and then press Enter.The repair process willtake quite a long time.
    May 23, 2012 | Toshiba Satellite A135-S4527 Notebook
    I HAVE A GATEWAY DESKTOP COMPUTER WITH AN ERROR MESSAGE SYSTEM32\NTOSKRNL.EXE. HOW DO I FIX THIS PROBLEM?
    NTOSKRNL.EXE is missing or corrupt. Issue NTOSKRNL.EXE is missing or corrupt.
    Related errors
    Cause
    1. Keyboard issue
    Solution
    Keyboard issue
    This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or just disconnecting the keyboard from the computer.
    Before trying any of the below recommendations it's recommend that you load the last known good configuration.
    OS Loader v4.01
    Check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
    If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you reinstall Windows.
    http://www.computerhope.com/issues/ch000646.htm
    Mar 02, 2012 | Gateway GT5026E PC Desktop
    Ntoskrnl.exe is missing or corrupt solution
    Issue:NTOSKRNL.EXE is missing or corrupt.
    Related errors:
    Cause:
    1. Keyboard issue
    Solution:Keyboard issue
    OS Loader v4.01
    Oct 01, 2009 | Microsoft Windows XP Professional
    It keeps saying that ntoskrn1.exe is missing
    It is pretty much crashed....hard. Might want to reload the OS. Yes you can recover from that, but it is not worth the time and frustration to do it...Provided you can afford to lose whatever you had on the primary partition (C:\) drive. Let me know if you need other asst. It is a little complicated to explain. How many machines is this affecting? All of your E-Machines?
    Aug 13, 2009 | Computers & Internet
    Bootup failure
    Cause:
    1. Keyboard issue
    Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
    OS Loader v4.01
    Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
    Dec 05, 2008 | Acer Aspire 3624WXCi Notebook
    Error: windows root>\system32\ntoskrnl.exe
    Related errors:
    Cause:
    1. Keyboard issue
    Solution: Keyboard issue This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
    Miscellaneous corruption Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
    Corrupt boot.ini file This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer. Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
    Missing boot.ini file Microsoft Windows XP users: If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648. Microsoft Windows NT and Windows 2000 users: To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
    Missing or corrupt ntoskrnl.exe file If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
    Windows NT installed on a partition bigger then 7.8GB If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below. OS Loader v4.01
    Please reinstall a copy of the above file. If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
    Corrupted hard disk drive or severely corrupted Windows Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
    If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186. Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
    Oct 18, 2008 | Computers & Internet
    How do I...
    Related errors:
    Cause:
    Keyboard issue
    Solution:
    Keyboard issue
    OS Loader v4.01
    Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
    ACER DESKTOP COMPUTER
    Related errors:
    Cause:
    1. Keyboard issue
    best regards wish u give me a good rate ^^
    Aug 15, 2008 | Acer Computers & Internet
    Computers & Internet Logo
    151 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
