Question about HP Photosmart M425 Digital Camera
Camera was dropped now it is saying that there is a lense error HELP!
My camera was dropped and now the lens will only detract half way. It says lens error and restart camera. It is a Cannon Power Shot SD1100 IS. Thanks.
Posted on Aug 03, 2009
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
My EX-S5 says lense error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 10, 2009 | Casio Exilim EX-S600 Digital Camera
Lense error
May 26, 2009 | Canon Cameras
My coolpix l18's lense will not retract. It says "lense error"
hi there, i am sorry but there is no reset button that can fix this problem. the gears on the lense have been dis lodged and needs to be reposition. the camara would have to be picked down completly for the lense to be removed and this is nothing you can do unless you know what you are doing. once re-posistioned the error code will go away and your camara will work as normal.you will need a technition and i cant do it for you because i am all the way i the caribbean (barbados to be exact) good luck and let me know if you get it repaired please.
Mar 14, 2009 | Nikon COOLPIX L18 Digital Camera
I dropped my Nikon L18 and it now says lens error when I turn it on. And the lens wont go back in.
you jammed the lense neds to be taken to a camera repair person It needs a new lense assmbly .
Jan 01, 2009 | Nikon COOLPIX L18 Digital Camera
Fuji finepix a600
If the camera was on when it was dropped you probably jamed the lense coil. The lense coil is what helps the camera smoothly pull in the lense and back out. Now, just to specify, what exactly are you having a problem with? Will the actual lense not go back into the camera when you turn it off; or can you not get your camera off zoom?
Let me know~
Olivia
Oct 30, 2008 | Fuji FinePix A600 Digital Camera
Focus error displayed after a drop its one of the finepix range there basicaly all the same
have you tried to gently pull and twist the end of the lense when it is extended?
unfortunatley when these cameras are dropped they can cause the lense to become unaligned and create a focus error if twissting dosent help it would need to be sent away for repair to have the lenses realligned but it wont be covered by warrenty
Sep 11, 2008 | Cameras
HP Photosmart M425 Digital Camera Logo
156 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
