Question about Sony Televison & Video
KDF-E42A12U - Three Standby flashes???
I have this TV and recently replaced the lamp. It worked fine for two weeks but now switches itself off and the standby light flashes 3 times.
Any ideas?
  • 261 Answers
There is the possibility that you might have a defective ballast, it might not have enough voltage to keep up with your new lamp, and that's why it switches off and makes the 3 indicator lights flash, letting you know that the bulb is defective, but it's not the bulb, it's the ballast
Posted on Jul 14, 2009
Kdf-e50a11e diagnostic codes
3 blinks is indicating the lamp has burned out. Aftermarket lamps tend to fail quickly. Only use oem replacement lamps for your sony. You can get replacement lamps from www.tvrepairworld.com
Feb 07, 2012 | Sony KDF-E50A11E TV
Where can I find easy to follow instructions to fit a new projection lamp in my Sony TV model KDF E42A12U
Send me a email asking for the KDF-E42A12U lamp replacement instructions I will email the instructions to you. slinteriors@yahoo.com
May 04, 2011 | Sony KDF-E42A12U 42" LCD TV
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have a Sony LCD projection TV product code KDF-E42A12 which is almost 3 years old. It was working fine but suddenly made a 'clunk' noise and went blank. When switching it on the TV wont start but goes...
Three blinks means a lamp door error. There are two switches in your TV that put the TV into protect when either the lamp is not properly seated or the lamp door is loose.
First open the lamp door on the TV to check the lamp. A defective lamp sometimes could also cause the TV to generate this error code. If you see either a shattered or cloudy bulb then you will need to replace the lamp. The "Clunk" sound you hear was most likely the lamp shattering.
If the lamp is okay, you will need to check the switches for the lamp and lamp door. They are called the T1 and T2 boards. The T1 board is visible when you have the lamp door open. It is on one of the sides inside the TV on next to where the lamp door opens. You should see the switch which is a little board (about 1" by 2") with a very little (about 1/2" by 1/8" ) coming out on the side of the board. There is another board almost exactly like it called the T2 board near where the lamp goes into the TV. This could have also become loose. If you see the metal pieces are loose or missing, the boards need to be repaired. You could either replace the boards if the metal piece is missing or just repair the boards by setting the metal pieces in the correct potions where they make good contact with the switch when the lamp and lamp door in set properly.
Also you could just bypass the switches by making a solder bridge (solder across) the connection to the T1 and T2 boards that will trick the TV into thinking the Switches are closed and bypass this error.
Oct 12, 2009 | Sony KDF-E42A12U 42" LCD TV
Kdf-50e2000 turning off
Symptom of weak lamp in TV that needs to be replaced in your Sony KDF-50E2000
Lamp replacement procedure is written in user manual of TV.
Let me know if you need copy of user manual.
Thanks.
Oct 09, 2009 | Sony KDF-50E2000 50" HDTV
Sony Grand Wega KDF-E50A10
The lamp light does not have to flash on this set for it to be the lamp, and most likely it is just that, the lamp. These sets when the lamps get weak they will do exactly what yours is doing.
Sep 07, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KDF E50A10
If standby light flash 3 times that means Lamp Cover is open or not fixed properly on its place.
Please make sure lamp cover is fixed securely.
Have you replaced its lamp recently?
Thanks.
Sep 04, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
TV switches itself off after 1 minute standby flahes red to green
there seems to be a possibility that your ballast might defective.. i recommend you replace it. It might not have enough voltage to keep up with the new lamp
Jul 02, 2009 | Sony Televison & Video
Sony TV Keeps switching off
How old is your TV?
2 times blinks shows error of High Temperature of Lamp.
This model has 4 fans and all should be work properly.
Nov 08, 2008 | Sony Televison & Video
Televison & Video Logo
109 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
