Cameras Logo
What does a lightning bolt and setting symbol mean when displayed together
I have a triangle error symbol in the lower right hand side of my printer, it has a lightning bolt inside of the symbol........what does this mean?
Canon printer light blinking error is a common error. Each printer features a flashing light to indicate its functionality. With Canon printers, you have flashing green and orange lights to inform you of any existing problems. It is suggested to carefully observe the number of flashes or the pattern of blinking lights as this will help you to understand the problem. And depending on the pattern, you can follow our canon printer troubleshooting guide mentioned below to solve that issue.
What does triangle with lightning bolt mean on Canon printer?
The orange triangle with the lightning bolt comes on when the printer is plugged in. The white light above the power button is on, but the printer is otherwise dead.
What does the orange triangle mean on my Canon printer?
When a printer error occurs, the Alarm lamp flashes orange as shown below. The number of flashes indicates the type of error that has occurred. Count the flashes and take the appropriate action to correct the error. Power Lamp Flashes Green.
What does the triangle symbol mean on my canon printer?
Seeing a yellow triangle with an exclamation mark usually indicates that a hardware device needs to be updated. If you are seeing the mark in Device Manager, we recommend checking the device status of the printer driver.
What does the flashing yellow light mean on Canon printer?
When an error occurs in printing such as the machine is out of paper or paper is jammed, a troubleshooting message is displayed automatically. Take the appropriate action described in the message. When an error occurs, the Alarm lamp flashes orange and a Support Code (error number) is displayed on the computer screen.
1helpful
I accidentally broke the battery chamber on my Fujifilm Z33wp camera, were can i get a new one, and also the flash doesn't work, what can i do to fix the flash
In my experience regarding the flash; make sure to check the settings of the camera that you did not deactivate the flash. It is usually a lightning bolt symbol displayed in the lcd screen; it is usually activated in full auto mode. If you do not see the lightning bolt or the symbol with the lightning bolt crossed out this also means it is deactivated.
If the camera still does not fire the flash then you may need a repair and the authorized FujiFilm service center that I deal with is Photo Tech Repair Service in NYC. www.phototech.com They can also probably get you the battery door that is broken. Contact them and tell them you were referred by Paul
Good Luck
How do i set the flash on my vivitar cam. model 8025
Touch the lightning bolt icon in the function area until the flash icon and the letter A appears on the left side of the display. This activates the automatic flash.
Touch the lightning bolt icon again until the letter A disappears. This forces the manual flash mode.
Touch the lightning bolt icon again until the eyeball appears on the left side of the display. This activates the red-eye reduction feature.
To turn off the flash function touch the lightning bolt icon repeatedly until the no-flash symbol (lighting bolt in a circle with a line through it) appears on the left.
This is all described in the manual.
2helpful
The flash will not work. I think something needs to be reset but not sure how to do that.
On the Navigaton direction button on the back of the camera the "Right direction" button has a little lightning bolt sign.
Repeatedly press this button while the camera is in picture taking mode to go through the flash settings sequence. (Watch the display while pressing this button)
Settings:
1 No Flash, Lightning bolt circled with slash across it.
2 Auto Flash, Lightning bolt with an "A" beside it.
3 Auto RedEye remover, includes an "eye" symbol.
4 Flash Always On, Lightning bolt alone.
5 Unknown, I don't know what the S mode is, I haven't used that one before (something to do with ISO virtual film speed setting).
Have fun.
IS THIS CAMERA WATERPROOF AND HO DO U TURN ON THE FLASLIGHT
No, the camera is not waterproof.
Touch the lightning bolt icon area until the flash icon appears on the left side of the display. This will activate the flash.
Touch the lightning bolt icon area again until the flash symbol appears on the LCD screen. This forces the flash function.
Touch the lightning bolt icon area again until the eyeball icon appears on the left. This activates the red-eye reduction mode.
To turn off the flash, touch the lightning bolt icon area again until the no-flash icon (lightning bolt inside a circle) appears on the left.
This is covered on pages 13-14 of the manual. If you've misplaced your manual, you can download one from the manufacturer's web site at http://vivitar.com
1helpful
How do you use the flash on a vivicam 8025?
1helpful
FLASHING AMBER UNDER LIGHTNING SYMBOL
Is it an amber lightning bolt? (I am assuming thats what you mean by UNDER lightning symbol)
That is the charging symbol for your battery, it means your battery is being charged by your power adapter.
Compaq laptop
its not charging try any other power adopter....
I need to turn the flash off on my D-395 digital camera and I have no idea how.
Greetings punknarumi,
There should be a symbol on your camera that looks like a lightning bolt in one of the displays. Simply choose that option until you get an option with a circle with a slash through the lightning bolt. This is the flash off setting.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 16, 2008 • Cameras
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
