Adapter does not work, need replacement adapterNO
    Genius:
  • 1,550 Answers
Check on radio shack
Posted on Jul 13, 2009
How to reseat memory in Dell laptop
well this is not a certain fix for read write error but here goes
take out battery
unplug from wall adapter
no fuzzy clothing
roll up sleeves wash hands very clean
open memory panel(underneath)
GENTLY open wing at end of first mem module
place on clean tissue on table face up on right of machine
do same on lower one put on left
inspect gold fingers(do not touch with your fingers)
if ABSOLUTELY filthy rub GENTLY with soft red clean pencil eraser and glow softly over table
replace memory in opposite direction(right goes in first and lower) then left
close mem door
plug in adapter(no batt)
start machine
let us know what happens
Jun 02, 2012 | Dell Inspiron 1525 Laptop Jet Black
Touch buttons on x box 360 not working
If buttons of your controller is not working we need to check the ff: Wireless controller: 1. Check the wireless adapter if properly connected. 2. Reseat the wireless adapter. 3. Check if you are getting stable green lights in front of the xbox for connection notification. TIP: It will be better if your wireless adapter is the wireless-N adapter. 4. You can check other wireless device to connect to xbox to isolate adapter issues. 5. If adapter is failing, replacement is needed. Wired controller: 1. Controller needs to be checked. 2. Controller needs to be tried to a friends xbox. If working,port might be faulty. 3. If controller seems not to work with a different xbox.controller needs to be replaced. Thanks for choosing www.fixya.com
Dec 05, 2011 | Microsoft Video Game Consoles & Games
A/c adapter is not working all of a sudden. Do I need to replace it.
Does the adapter wiggle around when it is plugged into the computer? if so it may not be the Adapter itself but the connection in the computer. if you know a friend with a similar adapter ask to use theirs. if not theres a chance the adapter is burnt out. also. does the computer work on just battery power? or does it NEED to be plugged in? if so then it could be a battery issue and not the adapter at all. hope this helps
Jun 07, 2011 | Toshiba Satellite P205D-S7438 Notebook
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
Will not turn on, something to do with the power adapter connector. Have had it repair once, but it seems to be doing the same thing. I use to be a computer tech,but did not work on laptops, so do not know...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
Sep 19, 2010 | Sony VAIO Notebook
My lonovo laptop won't charge. how do i fix it?
if ti works with the adapter plugged but the battery do not charge to work without adapter ..than the battery is dead and you need to replace it ..If it do not work without battery and just with the adapter ..it means tha adapter has an issue and try to check the plug ..the cable and the adapter itself..before buying another verify at the store with the laptop to see if the adapter is to blame ...and not the plug into the computer ..so you do not end up with 2 working adapters ..and still no charge ...If it is the plug itself ..then you have to change it ...you can get a spare part on the ebay..or just go to a repair shop ..cause they are pretty universal ...
May 12, 2010 | Lenovo Ideapad U350 Laptop Notebook
My Dell D 600 will not charge the battery and a message appears at start up that says Ac adapter not recognized What do I need to do to get my computer to charge the battery
If the AC adapter is not recognized by the system, the battery charger circuit is disabled. Things you can check:
  1. In the barrel of the connection to the computer, the small wire in the center is the sensing wire. If bent or broken, then the adapter will need to be replaced.
  2. If the pin is not bent or broken, try a different AC adapter (Any D-Series Dell adapter will work) IF that adapter works, replace the AC adapter.
  3. If a known good/new adapter doesn't resolve, then a motherboard needs replacement.
Jan 10, 2010 | Dell Latitude D600 Notebook
Ac adapter dont work it isnt the laptop itselfs its the ac adapte
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
The adapter is a sealed unit and is very difficult to open and repair. Usually you need to replace the power adapter.
Oct 19, 2009 | Toshiba Satellite A135-S4527 Notebook
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
