Question about Frigidaire FRS23H5AS Side by Side Refrigerator
REFRIGERATOR TOO COLD
Describe your FrigidFRS26R4A Side by Side aire Refrigerator Problem Hello, My FRS23R4CWO, SIDE BY SIDE MODEL IS FREEZING ALL THE FOOD ON THE TOP OF THE REFRIGERATOR. WE HAVE DONE THE FIVE CLICKS TO TURN ON THE MANUAL DEFROST AND USED A HAIRDRYER ON THE VENTS, TOP AND BOTTOM BUT IT IS STILL FREEZING. NOT SURE WHAT TO DO NOW.
5 Suggested Answers
SOURCE: GE model gss side by side refrigerator
I ASSUME YOUR TALKING ABOUT THE COILS BEHIND THE BACK OF THE FREEZER ..IF SO YOUR UNIT IS NOT GOING THROUGH THE DEFROST CYCLE BECAUSE OF A BAD HEATER OR BAD DEFROST TIMER OR BAD DEFROST T STAT .YOU CAN FORCE IT INTO DEFROST BY PUSHING THE FRESH FOOD DOOR SWITCH THREE TIMES IN 15 SECONDS IF YOU HAVE AN ADAPTIVE DEFROST TYPE OF DF CONTROL(ELECTRONIC TYPE).
Posted on Apr 02, 2008
  • 2468 Answers
SOURCE: refrigerator is freezing food
your damper door located between the refrige and freezer compartment is iced up fully open,you need to defrost it, then see if this closes when the cold control is adjusted
Posted on Jan 17, 2010
Sea Breeze
  • 4655 Answers
SOURCE: freezer runs constantly. food freezes in bottom
I see this happen a lot on these models. The defrost control board is part of four operations. If you changed the Defrost control board then one of the two thermostats is not responding to changes in temperature settings. For freezer if turning the thermostat warmer should cause the compressor not to run as much and open the damper and regulate. If the only place the thermostat setting is placed to off and it responds only to off I would believe that thermostat is the reason. I believe you are on the right track to repair but if you have a look at the wiring diagram you see the connection and point I'm trying to make here. Let me place the diagram and send you a link shortly, Thanks, Sea Breeze
Posted on Feb 20, 2010
imufo2
  • 3773 Answers
SOURCE: It has been freezing food in some places in the
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 12, 2011
My refrigerator keeps freezing things...,.changed the gaskets around door and still have the freezing probkem
Most fridges have a cooling vent above or on the side of the top shelf. This is where most of the cold air comes from, so keeping food away from here may preventfreezing. ... Some side-by-side refrigerators (particularly older models) feature a vent that funnels cold air from the freezer into the fridge.4 Aug 2015
How to Prevent Your Refrigerator From Accidentally Freezing Food ...
refrigerators.reviewed.com/features/how-to-prevent-accidental-food-freezing-in-fridge...or try this link... refrigerator keeps freezing things Google Search
Oct 23, 2017 | Refrigerators
Refrigerator side freezes
if the food in the fridge side is freezing it sounds like the damper door isn't closing,the way it works is cold air is produced in the freezer side,the evaporator fan blows the cold air from the freezer to the fridge side and it blows through the damper assy. if the damper door isn't closing youll have sub zero air constantly blowing into the fridge sidethe part number is 5304482075 but it's around 200 dollars.you can go here to sears and look up the parts or call a tech in to check it out
http://www.searspartsdirect.com/partsdirect/part-model/FRIGIDAIRE-Parts/Refrigerator-Parts/Model-FRS26R4AB0/1428/0165000/R0108022/00005?blt=06&prst=&shdMod=FRS26R4A
Jun 17, 2014 | Frigidaire FRS26R4A Side by Side...
My frigidaire side by side freezes
Hello orpheusingjap - From what you have describes it sounds like the damper door might be open causing the temperature to be too cold. Use a mirror to look at damper door at the rear of compartment and use a hair dryer on damper door to deice for 5 to 10 minutes. Allow 24 hours and if the temperature is still too cold, then I would have a professional look at the damper door for replacement.
Dec 09, 2012 | Frigidaire FRS3R5EMB Side by Side...
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Electrolux ESM6600SA Side by Side Refrigerator getting too cold after a clean
Hello John Wood - From what you have describes it sounds like the damper door might be open causing the temperature to be too cold. Use a mirror to look at damper door at the rear of compartment and use a hair dryer on damper door to deice for 5 to 10 minutes. Allow 24 hours and if the temperature is still too cold, then I would have a professional look at the damper door for replacement.
Oct 05, 2012 | Electrolux Refrigerators
The food on the refrigrator side is freezing. the water line is not working so i assume its frozen as well.
Hello Tina,
The problem with it freezing in the freshfood section is going to be because the air damper that opens and closes to let cold into the ref. section is stuck open and too much cold air is entering into the ref. compartment. This is a fairly common occurence with the GE refrigs. and by replacing the fresh food air damper which is located in the upper left corner of the fresh food compartment it will open and close properly and not allow too much cold air to enter where upon it freezes everything.
GENE
Sep 30, 2011 | GE PSW26MSR Stainless Steel Side by Side...
My frigidaire side by side refrigerator had problems from day one. We. had it looked at once and worked fine for a while. We don't use the ice maker as our water is not good. The arm is in the upright...
I sounds to me like too much cold air is entering the freshfood compartment and freezing the items their(disregard the icemaker as the problem) I dont know what model you have so i dont know if it hasa damper in the upper left corner of the fresh food section that is stuck open and allowing too much air cold air ..or if it doesnt have a damper and its the thermostat that is sticking and not turning off the fan that circulates the air but it will defiently be one or the other based on if it has a damper or not.
GENE
Aug 31, 2011 | Frigidaire Refrigerators
Fridge side is getting very cold to the extent basic products are freezing. temp usually 2-3 deg now down to -6 to - 8.
On the top left corner of the fresh food (ref) section is damper door that opens and closes to let cold air into the the fresh food compartment when it needs cold air. That damper is stuck open letting in air all the time,that damper needs to be replaced. This is the part number for it 12571701 it could be purchased from your local appliance parts store or online at;
apdepot.com
assuredparts.com
appliancepartspros.com
repairclinic.com
I hope this helps you to keep your produce from freezing,
Gene
Aug 11, 2011 | Amana 26 cu. ft. Side-By-Side...
Frigidaire FRS23H5AS Side by Side Refrigerator Logo
122 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Sal De
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
