Question about Microsoft Windows XP Home Edition
Nic ethernet card not working via rj45 port seria port ok to web
  • 565 Answers
Is this a recently installed card? If so, the "usual" procedure is to install the drivers first, then shut down the computer, install the card, then reboot and let the Windows "found new hardware wizard" run. (Otherwise you may end up with a generic driver.) If you installed the NIC in another manner, uninstall the driver first.
Of course, manufacturer's directions should be followed when possible.
If it is an existing card, you can go to the manufacture's website and download the latest driver. Before installing the new driver you need to uninstall the old driver (it may have become corrupted) through device manager (right click "my computer", select "properties" select the "hardware" tab then "device manager". Then check the box next to "network adapters". Right click your NIC and select "uninstall".
Posted on Jul 16, 2009
Network interface card
Most any standard PCI NIC will work for you, as long as you have an available port on your PC. Here is one from newegg.com at a great price. It's a Rosewill and I've bought that brand often.
Rosewill RC 404 Ethernet Card 10 100 1000Mbps PCI 1 RJ45
Jan 28, 2014 | Acer Aspire AM5641-U5520A PC Desktop
Missing link between DSL Cable and D-Link Systems HD Media Router 1000 (DIR-657)
What is the Time Warner modem? Make, Model? If you have a Ethernet port RJ45 connect the wireless device via a ethernet cable. You may need a splitter if there is only one Ethernet RJ45 port. Example: http://www.amazon.com/StarTech-RJ45-Splitter-Cable-Adapter/dp/B00009XSZE
Apr 24, 2013 | D-Link Computers & Internet
Integrated ethernet card on Compaq Model SR1650NX apparently failed. What is best inexpensive PCI Ethernet Card to use, if any?
you can buy just about any PCI NIC card from ebay or even walmart and they should work. make sure they are compatible with your OS. it will say on the box.
Jun 11, 2012 | HP Compaq Presario SR1650NX...
Im having trouble installing the ethernet controller for a hp pavillion media center a1620n. i have tried the manufacturers site for the driver and it did not work. can someone help please?
You can try to used this :
http://cgi.ebay.com/Ethernet-10-100M-NIC-PCI-LAN-Adapter-Network-Card-RJ45-/280630007091?pt=COMP_EN_Hubs&hash=item4156da1533
Thanks
Jun 27, 2011 | HP Pavilion a1620n (882780664494) PC...
Nic card not working? How to troubleshoot? Is there a plug and play nic card that can be installed onto this desktop PC?
Hello Sqis,
You can purchase any nic card which is compatible with WinXP or 7.
Insert the card in PC Slot of the motherboard.
Install the driver for the card and it will work.
May 05, 2011 | HP Compaq Presario SR1650NX...
Rj45 socket repair
Your laptop has a card slot, it will take a pcmcia expansion card.
It may be cheaper to buy an ethernet card with a rj45 port, rather than trying to repair the laptops built in port.
I found some from about £10
http://www.amazon.co.uk/PCMCIA-RJ45-Ethernet-Networking-Expansion/dp/B000Q8FO70/ref=sr_1_2?ie=UTF8&s=electronics&qid=1280865787&sr=8-2
Aug 03, 2010 | LG LU20 Tablet PC
I am not able to connect to internet because i don't have ethernet controller therefore i need ethernet controller
The ethernet controller is a hardware device either as part of the motherboard -where you will have an RJ45 connector visible to you at the outside of the case -or as a Network Interface Card (NIC) which would be installed as a PCI card which has it's own RJ45 connector.
If yours is a driver problem you will need to specify which brand/model computer or NIC you have for a link to that manufacturer to download drivers from that site. If you encounter problems or have more specific information please post again here. Steve Medley
Jan 26, 2009 | Computers & Internet
Emachine model t3302 ethernet card
This is how the wireless world works. You buy a wireless router with a four port switch. Your DSL or cable connects to that. A cable called a Rj45 connects the DSL or cable to the back of the wireless router. You also buy a wireless network card for your PC. After running the software for the router & the wireless nic card including setting up a home network through windows your daughter will be able to connect that computer to your network from any room in the house. Below is a link to a wireless router:
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10005578
You can connect up to four computers to the wirless router. A computer that does not connect to the router by a Rj45 must use a wireless network card. Linksys WMP54G Wireless-G PCI Adapter Retail: http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=252286
As you will see there is a big differance between a NIC card & a wireless card.
Jan 01, 2008 | E-Machines eMachines Desktop PC
Setting up an MN700 Base Station with dialup
1. disable all ICS and all Proxy settings on all machines 2. connect the NIC to the MN700 using Port 1 3. set up the MN700 and the wireless connection 4. switch the MN700 to Bridging mode 5. enable ICS on the host computer The basic object is to have the working connection for your dial-up, then set up the base station as an access point only, then share the working connection via ICS through the NIC. Quite similar to having a switch box, but you're going wireless with it. You don't need to feed the MN-700 any of the normal info like your Internet Service Provider's IP/DNS, etc., because your computer already is sharing that info.
Feb 19, 2006 | Microsoft MN-700 Wireless Router
Microsoft Windows XP Home Edition Logo
166 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
